My CCSB build
Old Oct 5, 2012 | 06:56 AM
Diesel_Brad's Avatar
Diesel_Brad
Well, got the drivers rear door cut in with no issues. BUT the passengers front rocker came back with a Vengeance. I am not sure if it is POR15 not liking PPG product or if there is some sort of contamination. Gonna give it a try again tomorrow. This will be the FOURTH time I will be painting it
Old Oct 5, 2012 | 06:57 AM
Diesel_Brad
A little more progress today.
Got new hood wet sanded and fitted.
Drivers new rear door wet sanded and realized it needed more work(did that and primed again).
FINALLY got paint to stick to the passenger front rocker.
Windshield frame cleaned up, vari-primed and primer surfacer
And got 4 strikers back in so doors dont flop around
Old Oct 5, 2012 | 07:00 AM
Diesel_Brad
Getting closer. Still need to wet sand and get drivers rear door on.
Got it pulled outside so I can thoroughly clean the garage as to keep dirt to a Minimum in the paint. I hope to be painting come monday
And Finally got paint to stick to the passenger rocker
Old Oct 5, 2012 | 08:38 AM
Diesel_Brad
Ready for some paint in the AM
Old Oct 5, 2012 | 08:39 AM
Diesel_Brad
White is down, waiting for it to flash off so I can tape off and do Opal
Old Oct 5, 2012 | 08:40 AM
Diesel_Brad
Got the Opal on
Old Oct 5, 2012 | 08:42 AM
Diesel_Brad
And 3 coats of clear. I have to redo the hood and white on both front doors front doors due to bugs and water
Old Oct 5, 2012 | 08:43 AM
Diesel_Brad
Double post
Old Oct 5, 2012 | 08:44 AM
Diesel_Brad
Well today I wet sanded the hood and both front doors and got them reshot. Turned out WAY better this time. Roof tomorrow?
Diesel_Brad
Nope. Had to go switch title on Bronco today
Old Oct 5, 2012 | 08:45 AM
Diesel_Brad
Just finished the roof, visor and cowl.
Old Oct 5, 2012 | 08:47 AM
Diesel_Brad
Tires back on and out in the sunlight
  #28
Diesel_Brad
New windshield went in last night.
Got the drivers and passengers front floor POR15'd tonight(I scraped off all the original soundeadner? off the floor)
Picked up some peal-n-seal from Lowes tonight too.
Then Purple Powered & power washed the carpet. Figured i would give that a couple days of laying in the sun to dry
Old Oct 5, 2012 | 08:48 AM
  #29
Diesel_Brad
Used the Lowes Peel & Seal. It is in the roofing isle. Same thickness as Dynamat. Used almost 5 rolls to do floor and back wall. Still need to do roof and doors
  #30
Diesel_Brad
I bought 12 rolls for $192. It looks like I am only going to need only 10. But I will let you know when I am done. Kinda wish I had the dashed pulled, to do the firewall
