1978 - 1996 Big Bronco
simple upgrades. ideas
Old Feb 10, 2012 | 11:37 AM
ErrorS's Avatar
ErrorS
regarding the LEDs, these are the ones I used originally: WLED-x5 (194 type) Wedge Base bulbs Specifications
They're much brighter than stock, I loved them but I just bought a set of these: High Power SMD WLED-xHP5 (194 type) 360 degree Wedge Base bulbs Specifications
and they're brighter than the ones I had before. I was worried they wouldn't fit as they're a tad taller, but they did. I might even be able to fit xHP9s but I'm not sure
also, I did the TRE flip and it was totally worth it, I have 5.5'' Deavers in front with a 4'' drop pitman arm and my steering links are straight across.
Old Feb 10, 2012 | 12:35 PM
BASHAM's Avatar
BASHAM
Thanks for the info.... pleade everyone feel free to post links to any and all good tutorials. Its gonna be nice not to seach hundreds of threads if the good ones are "here" got a few more im gonna post later a bumper build and winch install
Old Feb 10, 2012 | 11:39 PM
GruesomeJeans's Avatar
GruesomeJeans
BASHAM if you plan to do all these lights and fancy winches, then i suggest a yellow top Gel Cell battery, mine cost something like $230 but i don't have to worry about acid leaks. And it is pretty powerful. In regards to the LED lights, do you have to but new sockets for this to work? I had some amber LEDs once and i was going to use them but they had a thin 2 prong square connector, not the round one i have now.
Old Feb 11, 2012 | 03:47 PM
ErrorS's Avatar
ErrorS
you mean the twist on? Like for the gauge cluster I think I remember my 78 being normal 194s with twist lock connectors.. the bulbs just pull out of the twistlocks and you put the new ones in.
and so far with batteries, I've had amazing luck with this deep cycle battery from Walmart. Bought it for my boat like 10 years ago, used it in my F150 and now it's in my Bronco. The next battery I buy will be gel, I think, if this thing ever fails?
Old Feb 11, 2012 | 04:49 PM
BASHAM's Avatar
BASHAM
Im guessing mine are the twist style havrnt taken the dash off yet just finished all my suspension and now need to replace the rear brakes and then more sanding and paint exterior....when the weatger starts to warm up i will move inside and start on the lighting and trim.... dont have a haynea manual my semi had 194 bulbs i still have those but i want green not red
Old Feb 11, 2012 | 05:16 PM
Encho's Avatar
Encho
The Southernmost Mod
Links to most of the upgrades i ever wished or wanted, also for maintenance procedures:
Cajas:
Writeup: E4OD Removal/Installation - FSB Forums
Kits y piezas:
Kit sector shaft seals: D7AZ-3E501-B
Mejoras Y accesorios:
https://www.ford-trucks.com/forums/1...to-manual.html
Reviews - Gateway Tire Buckshot Mudders Bias Ply Mud Tire Reviews by Offroaders.com - - - - - - - - - - - - - - - Review Engine Powered by ReviewPost
IST Products
Engo Winch Sale - 9K Winch for only $289 with Free Shipping - Jeep Wrangler Forum
https://www.ford-trucks.com/forums/1...-question.html
Brians Truck Shop
https://www.ford-trucks.com/forums/1...rover-kit.html
E4OD Mega Monster Transmission Complete Rebuild Kit: 1989-95
DB Electrical - FORD TRUCK 4.9L 5.0L 5.8L STARTER M/T 92 93 94 95 96 97 3223 SFD0012
https://www.ford-trucks.com/forums/8...ering-box.html
AEM - EDIS-8 install - Ford Mustang Forums : Corral.net Mustang Forum
https://www.ford-trucks.com/forums/6...ering-fix.html
https://www.ford-trucks.com/forums/1...cs-inside.html
https://www.ford-trucks.com/forums/7...th-pics-2.html
FOUR WHEELER Magazine's Project M.P.G.
Herramientas buenas y a buen precio!!
olbeasthitch.com: The Leading Ol Beast Hitch Site on the Net
https://www.ford-trucks.com/forums/9...s-fenders.html
https://www.ford-trucks.com/forums/9...hese-work.html
https://www.ford-trucks.com/forums/9...ilar-book.html
https://www.ford-trucks.com/forums/9...-steroids.html
https://www.ford-trucks.com/forums/9...stroker-2.html
https://www.ford-trucks.com/forums/9...insulator.html
https://www.ford-trucks.com/forums/9...o-traffic.html
https://www.ford-trucks.com/forums/9...p-by-step.html
https://www.ford-trucks.com/forums/8...-the-dash.html
www.oemaxle.com
Totally Stainless
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
https://www.ford-trucks.com/forums/1...4-bumpers.html
https://www.ford-trucks.com/forums/1...ine-paint.html
https://www.ford-trucks.com/forums/1...2-19-10-a.html
Iron Bull Bumpers - Ford
HeftyFabWorks - Custom bumpers, rock sliders and more for your truck or vehicle
https://www.ford-trucks.com/forums/1...-still-on.html
https://www.ford-trucks.com/forums/9...l#post10104170 y https://www.ford-trucks.com/forums/1...-filter-2.html
https://www.ford-trucks.com/forums/9...uestion-2.html
GT40P engine in Bronco - GT40P heads AND GT40P HEADERS that WORK - FSB Forums
https://www.ford-trucks.com/forums/1...rans-mods.html
Mantenimiento:
https://www.ford-trucks.com/forums/1...ng-column.html
https://www.ford-trucks.com/forums/1...-draining.html
https://www.ford-trucks.com/forums/1...mad-power.html
https://www.ford-trucks.com/forums/1...dangerous.html
https://www.ford-trucks.com/forums/1...nts-cheap.html
https://www.ford-trucks.com/forums/1...um-wheels.html
https://www.ford-trucks.com/forums/1...wer-drain.html
https://www.ford-trucks.com/forums/1...1-f-150-a.html
https://www.ford-trucks.com/forums/1...nny-leaks.html
https://www.ford-trucks.com/forums/1...ans-flush.html
https://www.ford-trucks.com/forums/1...e-harness.html
E4OD MLP adjustment? - FSB Forums
https://www.ford-trucks.com/forums/9...-u-joints.html
https://www.ford-trucks.com/forums/1...ent-specs.html
https://www.ford-trucks.com/forums/1...placement.html
https://www.ford-trucks.com/forums/1...-oil-leak.html
https://www.ford-trucks.com/forums/9...-problems.html
https://www.ford-trucks.com/forums/9...lush-dity.html
https://www.ford-trucks.com/forums/9...od-an-efi.html
https://www.ford-trucks.com/forums/9...-for-50-a.html
https://www.ford-trucks.com/forums/9...ts-in-4wd.html
https://www.ford-trucks.com/forums/9...-4x4-argh.html
www.partsguyed.com
https://www.ford-trucks.com/forums/1...crossfire.html
https://www.ford-trucks.com/forums/1...ment-only.html
https://www.ford-trucks.com/forums/1...ion-flush.html
https://www.ford-trucks.com/forums/1...ont-start.html
How to adjust idle speed (official Ford procedure) - FSB Forums
https://www.ford-trucks.com/forums/1...-autozone.html
Clips y retenedores:
Ford Clips And Fasteners
Problemas originales:
https://www.ford-trucks.com/forums/1...rom-frame.html
Cajas Automáticas y modificación a manuales:
zf 5 speed conversion - FSB Forums
Suspension:
https://www.ford-trucks.com/forums/9...l-springs.html
https://www.ford-trucks.com/forums/1...ift-kit-s.html
Proyecto Fiery Redhead:
1992 Ford F-150 - Electrical, Battery Upgrade - Four Wheeler Magazine
Investigar:
Performance Unlimited 4-Wheel & Off Road Center - Hartford, Wisconsin - USA Technical Documents
Informacion de utilidad:
Ford V8 Engine Identification - FORDification.com
Understanding Universal Joints and Size Charts
Internet Archive Wayback Machine
Encho's Avatar
Encho
The links are so sweet they double posted themselves... now i'm editing this post, by the way, you should take a close look at the Project Fiery Redhead link. They do most of the upgrades i want except they didn't touch the engine and used a bullbar i didn't like (and the perimeter lighting, i can have it either way).
Old Feb 11, 2012 | 06:43 PM
GruesomeJeans
Thats a lot of links haha very informative. My 78 has 194 bulbs in it, they are the twisty ones but i think the connections are flimsy on the printed circuit board...
Old Mar 19, 2012 | 01:50 AM
BASHAM's Avatar
BASHAM
http://fullsizebronco.com/forum/showthread.php?t=73678 a detailed link to half doors and quick change hinge pins
Old Mar 21, 2012 | 10:38 PM
Bubba Jones's Avatar
Bubba Jones
I just finished putting an explorer overhead console in my Bronco. I mainly used this tutorial Explorer Overhead Console Install - FSB Forums
It was super nice for me because I have bench seats and no storage space, so now I can put my sunglasses somewhere else the then glove box! Plus, I get to see how hot its getting due to all this global warming !
Old Mar 22, 2012 | 12:03 AM
greystreak92's Avatar
greystreak92
Watch buying LEDs from Superbright. The quality SUCKS! You are better off adding LED's in arrays that don't try to use the OEM optical plastic in the gauge assembly. The LED retrofits don't disburse light in the same way or with near the efficiency of the OEM incandescent 194's.
Check out these guys for some really good options.
Old Mar 22, 2012 | 12:49 AM
BASHAM's Avatar
BASHAM
Bubba jones that is a great upgrade thread i have a stock center console with a small locking cashbox installed in it.. but i would love the OHC for the temp and compass if not just to show off to others.
Old Mar 22, 2012 | 10:57 AM
  #28
Bubba Jones
Thanks BASHAM. I wish I could have a center console too (and cup holders!), but I have to wait until I can afford some bucket seats.. A small locking cashbox sounds really cool too.. I don't really have anywhere to put something like that though. I really like having the overhead console though, and I got all the parts at a salvage yard. It cost me $18 for the overhead console and $12 for the wiring harness with the sensor. So it was only $30 compared to 200-300 from what I was looking at on eBay!
Old Mar 22, 2012 | 02:40 PM
  #29
Big_Rob's Avatar
Big_Rob
I've seen write-ups on the SixLitre tuneup for the 5.0. Seems to be a common performance improving deal....
Old Mar 22, 2012 | 10:24 PM
  #30
ErrorS's Avatar
ErrorS
I totally disagree with you on this one. I just upgraded from normal bright LEDs to their super bright ones and there are still no hot spots, the color is beautiful, looks like stock but much brighter. Two orders from them, have had a single bulb go bad (maybe 20 bulbs total?), anyone who sees my cluster comments on the brightness and how good it looks. They have bulbs that give up to 360 degrees of even light output, or down to a 20 degree spot light, all the numbers are listed.
not affiliated with them at all, but when I find a product I like I stand by it
