Polishing factory clear coated aluminum wheels
I have a 20 year old F150 with factory forged aluminum wheels. The clear coat is still on the wheel -but the clear coat is cloudy. If I wet the wheels-the clear coat becomes clear again-until the wheels dry and then the cloudiness comes back.
This leads me to believe that the cloudiness is on the surface of the clear coat. What polish will remove the cloudiness but not harm the clear coat?
I've had several sets of similar wheels over the past 20 years and I've never found anything to permanently fix the cloudiness (some products will make it less obvious, but then the volatile chemicals end up going away and you're back to square one).
Here's a website that discusses how to remove the clear coat and polish the rims. BUT then you still need to either keep wax on them or re-apply some kind of protective finish (probably some other websites out there that discuss that, maybe after you polish them, a body shop can re-spray them with some high-performance clear urethane). Bare polished metal just doesn't hold up for very long on wheels, especially with brake pad dust getting on them.
Wheel Refinishing
Wheel Refinishing
If you are OK with a brushed aluminum look, try removing the clear (I have had mixed results with oven cleaner - get the nastiest, smelliest kind). Then using a synthetic sanding pad ("Scotchbrite") on the wheel. Our local paint store sells an off brand that I think works just as good as the 3M stuff at just over 1/2 the price. While this will leave the parent metal exposed to the elements, it is not very labor intensive to run the pad over the rims every few times you wash the truck. This is how I keep my old 5 slots looking respectable.
This is what I use....It actually removes the yellow/orange oxidation of rust also....(The kind that gets on chrome...Not the rough, scley stuff)...
Its AWESOME...
Aluminum Polish - 16 Oz Bottle | AW Direct
Its AWESOME...
Phoneman,
I had the exact issue with my Aluminum Wheels. Wet they looked good ,but dry they were cloudy. You are correct that the problem is in the clear. I used the same method to fix mine that I use to fix clear coated Brass Fixtures,lights, door hardware. I used steel wool & water to prepare the surface so I can clear coat them. Start with course steel wool to remove the top coat , then move to finer 000 , then finish with 0000 grade. I then rinse and dry them.They MUST be completely dry. Then I used clear Dupli-Color Engine Enamel DE1636 and got good results.
[IMG]https://www.ford-trucks.com/forums/picture.php?album
You could also try Dupli-color Wheel paint clear HWP 103. If you wish although I have not used it yet. I thought the clear Dupli-Color Engine Enamel would hold up better and so far for 4 years they still are clear. It is some work but less than shelling out $$$.$$ for new wheels. Hell, I still have to shell out $$$ for gas , But now that's another issue.
Just my 2cents,,,,,,, '92
I use this basic method to do Aluminum & Brass hardware,and to save or re-finish furniture that has clear polyurethane or lacquer damage.
It worked well on the Aluminum Wheels that the clear is cloudy with no shine,,, as "Phoneman said", (" the wheels-the clear coat becomes clear again-until the wheels dry ")
Mine had the same issue. It did my cloudy Aluminum wheels w/rivets great. Of course if the wheel has curb rash or pitted or other damage. Then this method will only get sub-par results in the clear . No pun intended. I'm just old and poor Best to Ya '92
What most people misunderstand, is that the "Shiny" areas of metal are simply reflections of light....A finer and finer grit sand paper, the "Shinier" the wheel gets...The coarser the grit, the "Duller" the wheel gets; To an extent.....
So personally, I vote for the strip/reclear idea....
Thats one common ground we will ALWAYS agree on...FoMoCo made stuff....Seems to make everything....Better...lol
tseekins
11-09-2008 03:31 PM
boxcar1974
1999 to 2016 Super Duty
02-27-2007 11:25 AM
