"Real" Oil Pressure Gauge
I decided I wanted to see how well the oil psi in my 302 E-line's was so I got rid of the idiot pressure switch and replaced with a pressure sender, application ~88 Ford Truck. I had to use a 1/4" female to 1/4" male 45° brass fitting to get the bigger sender to fit. Then I simply jumped the 20Ω resistor on the back of the cluster with a piece of wire. In the video you can see the pressure build with the RPM'S.
FF
YouTube - Econoline E 150 Ford REAL oil pressure gauge
God Bless
FF
God Bless
Ok so i had to revive this thread just to ask... Does anyone have a pic of the 20 ohm resistor on the back of the cluster???? How easy is it to locate? Just wondering b/c i am going to do this conversion soon! Didn't want to get lost if there were a bunch of resistors on the cluster to choose from...
I hope the back of my 88/89 clusters look the same so i can find that resistor!
x2... LOL! Best $20 I'll ever spend... well besides the $20 for the 130amp alt, or the $20 I'll pay for an efan... LOL... Maybe I just need to make a series of threads... "How to improve you truck $20 at a time!"
I need to make a correction to this thread for anyone reading about how to do this swap.
It turns out after research my cluster IS a real oil pressure guage cluster. However the OP switch is not the real OP switch. I have the 7psi idiot light OP switch.
here is my cluster out of "Thumper" ignore the red circle and arrow. This cluster is from a truck already wired for REAL oil pressure (ie: no jumper wire needed!)
Here is the Oil pressure switch that was OEM (ie: 7psi idiot light) Motorcraft SW2178A
Here is what I replaced the above switch with Motorcraft SW873B (from 87 F250 4.9L)
In addition to the above post...
I will admit I used a different pressure switch than the 873B pictured above. However I believe the above part will have an extended shaft allowing other 4.9L owners to skip the brass extention or 45* mentioned above. Using the above part with an extended shaft may also allow 302 and 351w owners to not need the brass fitting too. I'm not 100% on this yet but as you can see the origional switch has a long shaft on it so I would assume the older 873B will have a longer shaft too. I used a different sender from the 70's and will leave that borg warner part number in a later post for those that might want it.
The other thing I will admit to is the fact that I probably used to much TFE tape which blocked the switches ability to ground itself to the block. So the switch has not been functioning properly for me, yet... I would suggest others to use very little TFE tape or use a paste instead (if you are using a brass connection). If you are not using a brass connection to make the new OP sender fit, no TFE paste or tap is needed for install (the sender will come with sealant on it). I will be working on resolving my problems and adding more pictures of dash dismantling, location of Speedo cable disconnect, etc...
I have also heard that others like Turbogus above put a "T" fitting in. This allows you to send your oil pressure to the cluster and avoid CEL's and put in a second sender that runs to a "A-Pilar" OP guage. This might be even better for reading "real" OP because an AutoMeter OP guage will actully have numbers instead of Low-Normal-High like the OEM one. New "A-pilars" that hold Autometer guages can be found at Summit, LMC, etc... http://www.lmctruck.com/icatalog/fd/full.aspx?Page=96
I hope to make this the "GO TO" thread for making a swap back to a real OP guage/switch. So others with pictures please post them so all model years are covered!
on
Motorcraft Part# SW1547B fits the 1989 F250 351W in case anyone needs the info.
Is there a way to look under the dash to see if it already has the resistor? I think I can talk my son into going upside down in the truck but only if he will be able to see it (not going to be me this time!)
I don't really want to pull them out just to see if it's there.
