S. California Chapter Join Chapter, Leader:
December All Topic
Old Dec 13, 2011 | 07:52 AM
  #256
stRangerXLT's Avatar
stRangerXLT
grumble, slurp of coffee
Old Dec 13, 2011 | 09:55 AM
  #257
67 Olfthfl's Avatar
67 Olfthfl
Goodmorning all,
Have a terrific Tuesday!
The spirit of Christmas is sure making it's rounds this season. Thank you to everyone that's helping to make this happen.
Old Dec 13, 2011 | 02:47 PM
  #258
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Afternoon SoCal!
Old Dec 13, 2011 | 03:07 PM
  #259
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What should voltage be on our trucks? Is it the same for all motors? If not can you show me for the three big ones? (5.4, V10. 7.3)
Old Dec 13, 2011 | 03:08 PM
  #260
bigrigfixer
The Pacifier
should be all the same.
Old Dec 13, 2011 | 03:15 PM
  #261
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What voltage?
Old Dec 13, 2011 | 03:18 PM
  #262
bigrigfixer
The Pacifier
12 volts? Is that the answer you're looking for? 13.5 - 14.5 engine running?
Old Dec 13, 2011 | 03:33 PM
  #263
bpounds's Avatar
bpounds
Depends on when and where you measure it. A fully charged 12V battery should have a float voltage (after several hours at rest) of about 12.7 volts. And it doesn't matter what vehicle charged it. Charging voltage is constantly variable, but should be between 13.2 and 14.4.
Old Dec 13, 2011 | 03:56 PM
  #264
bigrigfixer
The Pacifier
What Bill said.
Old Dec 13, 2011 | 04:16 PM
  #265
bpounds's Avatar
bpounds
Originally Posted by A/Ox4
...three big ones? (5.4, V10. 7.3)
I disagree with your premise that those are the "big ones"!
Seriously though, I think all Ford/Int'l light diesels use 12 volt starters. I know many OTR tractors are 24 volt. But what about F550, F650, etc? I have no idea. It is a good question.
Old Dec 13, 2011 | 04:27 PM
  #266
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The three big ones for the Super duties
F550 will run the same as F250-450 but 650 an 750 might be different idk.
Old Dec 13, 2011 | 04:29 PM
  #267
bpounds's Avatar
bpounds
Yes, considering it might be a Cat or a Cummins in the larger F's.
Old Dec 13, 2011 | 04:34 PM
  #268
bigrigfixer
The Pacifier
Used to be fairly common, but not any more. Depending on the truck and how it was spec'd, they use either three or four 12 volt batteries in parallel.
Old Dec 13, 2011 | 04:53 PM
  #269
bpounds's Avatar
bpounds
Interesting. Is that true of off-road earth moving equipment as well?
Old Dec 13, 2011 | 05:22 PM
  #270
bigrigfixer
The Pacifier
I have no idea. I'll have to ask a couple buddies. One works for a Cat dealer, the other worked for a Komatsu dealer.
