S. California Chapter Join Chapter, Leader:
December All Topic
Old Dec 9, 2011 | 09:06 AM
  #166
stRangerXLT's Avatar
stRangerXLT
oddly it doesn't come up on a search from their website. worth a short drive to scope it out
Old Dec 9, 2011 | 09:25 AM
  #167
bpounds's Avatar
bpounds
Originally Posted by stRangerXLT
good morning FTE friday indeed!!!
PROPANE TANKS: where's the best spot to buy 2 20 pound tanks and get filled? i'd go to Homely Despot but those are only 15lb tanks!!
I just traded in an expired tank at Home Depot. Those are 20lb tanks. The rumor is that they only fill them with 15lb, but if that is true I can't tell the difference. But regardless, it will be cheaper than buying brand new tanks plus filling. I forget the non-trade price for a tank at HD, but I think it was less than $30. I could be way off on that.
Any place that sells BBQ's should have new empty tanks. Walmart, Camping World...
Old Dec 9, 2011 | 10:18 AM
  #168
67 Olfthfl's Avatar
67 Olfthfl
Goodmorning all,
TGIF!....May your workday go by quick & your weekend be relaxing!
I'm so ready for next year to start! As much as I love the holidays, I often find it depressing. I'm actually keeping busy this year & trying not to dwell on negatives - loss of loved ones, the economy for everyone, Jimmy's work hours being cut from 40 to 32, etc. Volunteering in my community is really rewarding & it helps me to see that in the end...as much as I want to bitch, whine, & complain - my problems aren't nearly as bad as someone elses.
Old Dec 9, 2011 | 11:50 AM
  #169
SpringerPop's Avatar
SpringerPop
Amen, Donna!
Volunteering is truly good for our souls.
Pop
Old Dec 9, 2011 | 12:34 PM
  #170
Jetcopterpilot's Avatar
Jetcopterpilot
Propane tanks are only allowed to be filled to 82% due to expansion of the fuel, so a 20 lb tank gets filled to Approx 16 lbs. That is actually a law, and why there is the little breather valve on the side of the main valve... If the tank was filled and then set out in the heat of the day it would rupture if there was no room for fuel expansion. My first job after college as a mechanical engineer was for Amerigas/Calgas designing gas systems for commercial properties...
Most RV shops sell tanks, and yes Suburban, or Amerigas, or Petrolane will have them in many sizes.
Old Dec 9, 2011 | 12:51 PM
  #171
bpounds's Avatar
bpounds
Yes, but a 20lb tank was designed to hold 20lbs at 80% full. In the old days the proper way to fill a tank was by weight. But too many places did not do it properly, and we had the overfilled tank problem. Now it is the law that all portable tanks have to have the Overfill Protection Device (OPD) and when it vents liquid it tells the seller to stop filling.
So I agree with what you are saying, except that a properly filled tank should still have 20lbs of product. Which is roughly 4.7 gallons.
Propane Cylinder and LPG Bottle Information
I'm not at all surprised that places like Blue Rhino fill to a lesser volume so that HD can be price competitive.
Personally, I have them filled at a bulk dealer. And then when my own tanks expire, I trade them in to Blue Rhino so that I don't have to deal with recert. If I luck into a good looking tank in the trade, then I have it refilled. I guess that is mostly a matter of convenience because I am usually getting my RV tanks filled at the same time as a few 20lb bottles. Because the price to trade at HD is actually less. It cost me $18 to trade in an expired bottle and get a filled one in return. For the BBQ, I don't really care if I only get 15 lbs.
Old Dec 9, 2011 | 01:04 PM
  #172
Jetcopterpilot
The tanks were originally designed to hold 20lbs at 87-90 percent,, in the early 90's that was lowered to 80-82 percent due to tank bursts, and the use of the dip tube valve replaced the use of weigh scaling. the dip tube valve was considered more accurate, but it actually isn't, if the fuel sloshes around it gives false readings and fills short... The manufacturers did not retool the sizes of the tanks after the changes.
Old Dec 9, 2011 | 01:31 PM
  #173
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Good day to all FTE'ers.
Old Dec 9, 2011 | 03:22 PM
  #174
stRangerXLT
it's their truck fill and dispatch yard, there
Old Dec 9, 2011 | 04:57 PM
  #175
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Oops
Old Dec 9, 2011 | 05:17 PM
  #176
stRangerXLT
no big deal, home depot was on the way back. afternoon project completed, now dammit where is the other one (not here yet)??
its a giant bug zapper in case you're wondering
Old Dec 9, 2011 | 05:26 PM
  #177
SteveBricks
FTE Emeritus
I'll say it's giant
Old Dec 9, 2011 | 05:55 PM
  #178
bpounds's Avatar
bpounds
Looks like it is for Pteradactyls. Are they a problem in your area? Haven't seen one around here in a long while.
Old Dec 9, 2011 | 06:05 PM
  #179
Jigger2020's Avatar
Jigger2020
Thats a beauty, we get some huge mosquitos up here, right on ST
Old Dec 9, 2011 | 06:22 PM
  #180
SpringerPop
Why do I think you're not completely forthright here?
Pop
