'79 tinker thread
Old Aug 19, 2012 | 07:06 PM
  #91
jgavac's Avatar
jgavac
I looked into the Curt hitches... Class 3 rear is $270 sans shipping. Shipping a 50lb package (Curt lists weight at 46lb) from Sioux Falls to Freeland though usps is $38...
CURT Manufacturing | Hitch Lookup for 1979 Ford F-Series All, Except F-250 Crew Cab
Has anyone used the LMC Floor pan patch panel? Is it any good?
Thanks
Jameson
Old Aug 21, 2012 | 11:54 PM
  #92
jgavac's Avatar
jgavac
Finishing up on the last of the interior prep. My Rustmort should be in tomorrow, so I'll get things taped off and hopefully start spraying on Thursday. Will need to rustmort the roof, passenger side floor, all along the top of the firewall where it joins to the part of the dash attached to the cab, and some various small spots on the firewall and floor. Overall, I've been surprised and happy at how clean the metal in the cab is. I was expecting some really nasty rust all over.
Here's a quick look. Gas and e brake pedals are now out.
Jameson
Old Aug 22, 2012 | 09:24 AM
  #93
74 F350 SCS's Avatar
74 F350 SCS
That's looking real good. Great progress! I am looking forward to seeing your progress.
Old Aug 25, 2012 | 09:16 PM
  #94
jgavac's Avatar
jgavac
Finally getting around to updating
Rustmort came in, and I converted the firewall and floor pan rust spots. I decided to use a rubberized undercoating rather then paint to help bring down the noise in the cab. Using Bondo heavy duty undercoating, because its all that I can get locally.
Converted, cleaned, and taped up
And here is what I have so far. Sprayed up to the upper part of the dash, the firewall, and the converted floor pan areas to seal them up. After I've taken care of all the rust, I'll coat the whole floor, roof, and any other areas that will be covered by something.
As for further insulation, I'll be using 1/8th inch rubber backed with foil that is usually used for mobile home roofs, but works wonderfully.
Jameson
Old Sep 3, 2012 | 12:41 AM
  #95
jgavac's Avatar
jgavac
Applied the rustmort to the roof and any other spots on the floor that needed it, as well as between the walls below the supercab window.
I took out some of the seam sealer along the rear wall where there was rust underneath. Coated the back wall and between the walls with the undercoating.
Taped off
Converted seam rust
Quality panel fitment
New seam sealer in grey
Final coating on the back
I've also decided to start planning out and building a roll bar/headache rack thing. I wish I could draw well enough to give a visual representation of what I see in my mind. I have a creeping suspicion that it won't turn out the way I want, but I can only try. What I have in mind is a roll bar that mounts to the bed rail on the sides, and then has middle supports going down to the bed that will hold a spare tire. Somewhere on the side rails will be mounts for a jerry can and high lift jack. If I can, I'll also make up a tool box to go in between the angled spare tire holder and the front side of the bed. On top will be 4 rear facing flood lights, and possibly dual cb whips. I think there are a couple more things I had in mind, but I can't really remember...
In the mean time, I've started making up a simple spare tire mount that moves it from under the bed to inside on the drivers side front.
I go back to school on Tuesday, so I won't have as much time to work as I would like
Jameson
Old Sep 3, 2012 | 02:48 AM
  #96
460 FORD MAN's Avatar
460 FORD MAN
Looking good man. Keep it up!
Old Sep 16, 2012 | 11:52 PM
  #97
jgavac's Avatar
jgavac
I've come to a halt on work for the most part. I am waiting to get my truck to a body shop to fix up the door jamb before I go any further with the inside.
Here are just a few parts I've been working on
Wiper motor mount and steering wheel mount before...
After
Emergency brake pedal (other side was worse)
Mostly done. Still have to get the last of the grease out from there
Started in on building a gantry crane to take the bed off. I'm doing it out of wood, and I'll be doing a write up once I'm done.
Jameson
Old Sep 17, 2012 | 09:02 AM
  #98
74 F350 SCS
That is totally looking awesome! I wish I still had that kind of energy
Old Sep 17, 2012 | 09:33 AM
  #99
Aaron-71's Avatar
Aaron-71
Looking great!
Glad to see there are other students on here with some dedication to their build.
Old Sep 17, 2012 | 09:45 AM
  #100
keiths78f150's Avatar
keiths78f150
Students UNITE! lol
Old Sep 17, 2012 | 11:28 PM
  #101
jgavac's Avatar
jgavac
Hahaha I do what I can when I have the money.
I've been considering a powder coating system for small parts that I can cure in our oven, but they all seem so expensive.... Might have to save before I can buy one
Jameson
Old Sep 21, 2012 | 11:09 PM
  #102
jgavac's Avatar
jgavac
Decided to freshen up the heater core housing, because there isn't much else to do, and the back had rust on it
Front of it had some funky scratches in it too
...So I painted it still have to do the backside and motor, then re-do the gaskets.
Jameson
Old Sep 29, 2012 | 12:59 AM
  #103
jgavac's Avatar
jgavac
Well the interior is back in.. Enough so that I can drive the truck. Our trailer is too small to hold my truck, and ones locally are around $120 per day, so I decided the cheapest way to get my truck to the body shop is by driving it up there.
I'll post a link to a vid of a recent run. I never get tired of the exhaust rumble
Jameson
Old Sep 29, 2012 | 06:29 AM
  #104
74 F350 SCS
Jameson
Very impressive Jameson! Great detail and progress. This is an awesome thread and you are doing a great job. I look forward to seeing the interior and body work. BTW, I know what you mean about never getting tired of the exhaust rumble!
Old Sep 29, 2012 | 07:17 AM
  #105
gumshoe's Avatar
gumshoe
I have two trucks that are driveing restos. I'm always tinkering with something. that's part of life with these vintage trucks. I'm like you nothing goes back on my trucks unless the part is restored. hood is always open doing something.
