'79 tinker thread
Old Feb 28, 2013 | 12:16 AM
  #151
jgavac's Avatar
jgavac
Thanks. For your needs it makes sense. I have another truck for hauling, so this one will be toy/show truck.
Wycked: are they really? Could've fooled me
Old Feb 28, 2013 | 08:09 AM
  #152
teds74ford's Avatar
teds74ford
For what it's worth, I have been using Rustoleum's Hammered paint for a while now on things and I really like it. Very tough compared to regular rustoleum, and I've read that the Hammerrite is even tougher. True or not, who knows, but I do know the hammered paint is tough. I think you'd be pleased with it.
Old Feb 28, 2013 | 11:48 AM
  #153
jgavac's Avatar
jgavac
I'll let you guys know how it goes with the Hammerite.
It's funny, this project has taken a mind of it's own, and dragged my wallet down with it
This has turned from a minor fix-this fix-that project to a mild restoration, and now I'm figuring it will end up as a frame off... Little bit more than I was expecting but I'm happy (I mean, how many other 16 year olds are doing this?). The only thing I worry about is if I can remember how to put everything back together... Fortunately I have this forum to help me out
Jameson
Old Feb 28, 2013 | 01:01 PM
  #154
JB78f150's Avatar
JB78f150
That's why I have two trucks sitting next to it
Old Feb 28, 2013 | 09:16 PM
  #155
jgavac's Avatar
jgavac
Hey wanna loan one to me? I promise to take good care of it
Old Mar 1, 2013 | 10:38 PM
  #156
jgavac's Avatar
jgavac
Only had a little bit of time today before I ran out of daylight Anyway I got the front bumper, grill insert, and lights out.
Then I moved onto the tank.
Top before
After (I did get the last side done)
Bottom before
Almost done. Forgot to empty the water trap so enough moisture built up to turn my sand into mud so I'm done for the night.
Jameson
Old Mar 3, 2013 | 11:42 PM
  #157
jgavac's Avatar
jgavac
Had a little bit of light after work today.
Then the usual stuff...
Jameson
Old Mar 4, 2013 | 12:39 AM
  #158
ford005's Avatar
ford005
Been watching this since the beginning...you're doing a great job. If you ever need a hand or some parts, I'm not too far from you.
Oh, so jealous...I have all kinds of equipment and tools, but I could really use a blasting cabinet.
Old Mar 4, 2013 | 12:51 AM
  #159
jgavac's Avatar
jgavac
Hey thanks man!
Having the blasting cabinet is soooo dang nice. Only problem is powering it. I've probably mentioned it before, but the size cabinet I have requires minimum 50 cfm @ 100 psi to run it effectively. Can't get a single phase electric motor that powerful without spending upwards of 2500, and can't get three phase at my house. Which is why I have a very fuel inefficient 302 monoblock compressor. It works wonders for the cabinet though, because my flow is 125 cfm at 90 psi. Makes short work of parts (those headlight buckets took maybe 5 minutes a piece), but wears out material really fast. That's the main reason I've been avoiding using the quality expensive stuff like Aluminum Oxide and favoring sand. For most projects now, I use simply Lane Mountain Co. silica sand, which is about $7 for a hundred pound bag, instead of $50 for a 20 lb bag of alum oxide.
Old Mar 5, 2013 | 12:37 PM
  #160
jgavac's Avatar
jgavac
What can you guys recommend for a quality, durable aerosol primer and paint? I'm going to need some strong stuff for the tank, and I figure I'll do all the other parts that I blast in the same stuff. I'm thinking along the lines of a gloss or semi gloss black, and a red primer is preferred.
Thanks
Jameson
Old Mar 5, 2013 | 08:46 PM
  #161
teds74ford's Avatar
teds74ford
How about a good zinc primer
MOELLER Zinc Chromate at West Marine
Followed by rustoleum gloss black. I recommend the gloss because it seems to be kind of satiny once dry.
Old Mar 5, 2013 | 09:06 PM
  #162
jgavac's Avatar
jgavac
I picked up a can of Krylon rust tough enamel primer, and I have a can of Krylon Hi-build fleet semi gloss black on order that I'll get tomorrow
Old Mar 6, 2013 | 09:26 AM
  #163
teds74ford's Avatar
teds74ford
Sounds good.
I am sure it is just preference, but I have never cared for hardly any spray paints but Rustoleum. Maybe it is just that I am used to how they lay down, but I haven't had good luck with too many others. Ace Rust Stop is pretty good as well. I think it and rustoleum are more oil based and maybe that's why I like them? They don't seem to dry as fast.
The point is, find what you like and you will get good with it.
Old Mar 6, 2013 | 10:15 AM
  #164
jgavac's Avatar
jgavac
I've used a lot of the ace brand paints because it's what I can get locally the day I needed it. The NAPA store I work at carries a small variety of spray paints in stock when compared to ace, but can get almost any type you need next day, with no extra charge. Because of the employee discount I get now at the napa store, I've decided to shop around a bit for the different brands and see what I like.
Thanks for the input
Jameson
Old Mar 9, 2013 | 09:38 PM
  #165
jgavac's Avatar
jgavac
Here ya guys go. A clean blasted gas tank. Only took me about 45 minutes to do. Just have to get all the sand and dust off, then get it painted.
