HPFP failures
Old Oct 13, 2011 | 06:50 PM
  #121
Tom's Avatar
Tom
Originally Posted by huntindog
Tom. Saying that the Duramax pump is not reliable is just not true. The Duramaxes are not having HPFP problems. In fact the only reported case of a suspected failure turned out to be a sensor. GM first replaced the pump under warranty and it did not fix the problem.
I knew people would question what I posted...heck I rarely trust data that's not sourced! So I get what you're saying, and unfortunately I can't get any more specific on a public forum.
All I can say is that this came from a source whom is both trustworthy and in a better position to know these facts than any of us. And yes, GM has had HPFP failures on their new Duramax trucks.
Sorry I can't provide a source!
Old Oct 13, 2011 | 07:46 PM
  #122
p12483's Avatar
p12483
Does anyone know if the Edge CTS monitors anything that could indicate an impending failure of this pump?
Old Oct 13, 2011 | 07:59 PM
  #123
Ian123's Avatar
Ian123
Unfortunately there is no way to tell if the pump is on its way out
Old Oct 13, 2011 | 08:15 PM
  #124
p12483's Avatar
p12483
So it looks like every one of us is playing a game of Russian Roulette with these pumps!
Old Oct 13, 2011 | 08:29 PM
  #125
jayman2's Avatar
jayman2
I said it once and i'll say it again for argument sake . The 6.7 motor was designed and tested in Ford's Germany diesel facility. The truck itself was tested in Europe and in the Middle East before it was introduced to the U.S.
Both countries have premium Diesel fuel the U.S. does not. Bosch is German company which provides fuel systems for many diesel cars and trucks worldwide. Their HPFP pumps are tested using European grade premium diesel ,so any of the test numbers posted here you can basicaly cut in half the service life using U.S. grade diesel without additives. Any one can search any car , truck ,or suv , forum that is ran by a diesel motor , post 2007 ( which was when USLD was introduced to the U.S) and can start to see all the fuel system related problems in every different make.You can start to connect the dots.
Ford is a global corporation , so is Bosch , We are in a global economy now. They are not going to change a part which goes into millions of trucks and cars just because one country has bad fuel quality , its all about the bottom line . All the car manufactures have to do in the U.S. is tell you to use an additive in their manual and it covers their butt .
Its only going to be a matter of time before you start seeing posts about peoples exhaust systems getting clogged and tech's blaming poor fuel quality .
Me personally , I wonder if Ford actually built in the cost of a fuel system - $9500.00 , and a exhaust system when it gets clogged -$3500 into the price of the truck , If so i wonder if Ford would let me cancel my full warranty in return write me a check back for $13000.00 and i'll never visit Ford dealer again and fix my truck myself when it breaks? I know that would never happen ,just wishful thinking.
Here is another link http://www.chevron.com/products/prod...ech_Review.pdf
This should answer alot of peoples questions and its a wealth of knowledge about diesel fuel.
Here's another one ,again this is in Europe not in the U.S. Speed | Know your fuels
On the home page click on the left side menu , High Speed Diesel.
Old Oct 13, 2011 | 08:47 PM
  #126
Glockin' Bob's Avatar
Glockin' Bob
I don't think so, not if you find and regularly use an additive which will give sufficient lubricity to the fuel you use. Do that and you'll likely find the pump will give many years of service.
The question is, what additive is safest and provides good lubricity?
Another question is why do we in the U.S. have inferior quality fuel relative to Canada and Europe?
My final question is, why did an engine with the CP4.2 get released into the U.S. market when Bosch clearly specs HFRR < 460? Perhaps I'm jaded and cynical, but my chips are on Marketing.
Old Oct 13, 2011 | 08:54 PM
  #127
Indigofarm's Avatar
Indigofarm
Wow. This thread has certainly sparked a lot of conversation/ideas, and not all in the direction I thought when I started it.
This is likely because the reported GM HPFP failures turned out to be non existent. And the Ford failures have been too few to point to a signifignant problem.
Reading some of what has been posted on this thread, and others, it appears that Ford is kinda paranoid about this issue. They actually have buyers sign a document about monthly draining of the seperator.
Think about that for a minute. Of all the maintenence that needs to be done,,,,,only one item rates a special sign off sheet?????
What document are you referring to. I don't recall this but may have overlooked it?
Old Oct 13, 2011 | 08:58 PM
  #128
dschuffert's Avatar
dschuffert
Great information, the diesel review document is great, thanks! Rep given!!
Old Oct 13, 2011 | 09:13 PM
  #129
jayman2's Avatar
jayman2
Hey ,Thanks . What really scares me about the review document link is the topic in chapter 2 on the bottom of page 6 , if those findings are correct on the filter and micron sizes ,then the filtering system on our trucks is not sufficient enough to protect the HPFP.
Old Oct 13, 2011 | 09:27 PM
  #130
Glockin' Bob
I believe the secondary filter is 4 micron so should be fine on that count.
Old Oct 13, 2011 | 09:59 PM
  #131
Tom's Avatar
Tom
Now I don't know about the rest of the post, but this is completely incorrect. This engine was designed in Detroit, not Germany. Adam Gryglak was the chief engineer, and he came on here and answered some questions a year and a half ago near the launch date for the truck.
Check it out:
Originally Posted by BusinessWeek
Adam Gryglak had what seemed like an impossible task: deliver an all-new Ford (F) diesel engine in 36 months. Ford was way behind schedule, so the time frame was a year faster than usual. Gryglak, the chief diesel engineer, knew he'd never meet his deadline without short-circuiting the usual development process. So he put together a team, moved off campus, and kept his second-guessing bosses at bay. Gryglak called the project Scorpion (after the heavy metal band the Scorpions) and came up with a logo featuring a menacing mechanical insect.
From HERE.
They did use things learned from other nations though:
Originally Posted by www.pickuptrucks.com
“This was a global effort within Ford to create this engine,” Gryglak said. “We applied many of the lessons learned from Ford’s European operations.”
From HERE.
To my knowledge the Super Duty isn't available anywhere other than North America with the exception for some export models sold without warranty. This is not a global platform.
On edit:
Correct, the engine-mounted filter is 4-micron.
Old Oct 13, 2011 | 10:27 PM
  #132
jayman2's Avatar
jayman2
Check it out:
From HERE.
From HERE.
On edit:
Yes the 6.7 is designed and built by Ford with the help of a Austrian company called AVL . Ford 6.7L Powerstroke Diesel Engine - EGR Valve - Diesel Power Magazine
and it states it here to, AVL (engineering company) - Wikipedia, the free encyclopedia
Old Oct 13, 2011 | 10:33 PM
  #133
Tom's Avatar
Tom
That's exactly right.
But there's a HUGE difference between
Originally Posted by Diesel Power Magazine
Ford partnered with the Austrian engineering firm AVL to conceptualize the 6.7L Power Stroke's design back in 2006
Read more: Ford 6.7L Powerstroke Diesel Engine - EGR Valve - Diesel Power Magazine
and
It's one thing to have an Austrian(NOT German) company help with the initial design, and a completely other to have them design, test, and build the whole truck and then sell it over here.
Ford did take experience from everywhere when they designed this engine, and I believe that's why it's been as successful as it has.
Old Oct 14, 2011 | 05:20 AM
  #134
huntindog's Avatar
huntindog
Here it is. Post #519
https://www.ford-trucks.com/forums/1...l#post10855407
After looking at it again, there are a few other items on it as well.
Old Oct 14, 2011 | 05:53 AM
  #135
KC8QVO's Avatar
KC8QVO
Although it is stated that fuel quality is critical, it mentions that you "can" add the additive. They don't state it is absolutely necessary. Not that you shouldn't use it... No one ever mentions specifically from Ford that you HAVE to like DEF.
