HPFP failures
Old Oct 14, 2011 | 08:19 PM
  #151
farmerdave's Avatar
farmerdave
That's the filter that would solve all of our water problems!?!
Old Oct 14, 2011 | 08:44 PM
  #152
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by NinerBikes
Surely, there are some mechanical engineers in here and not all a bunch of well monied retired group of Old Farts?
Tread lightly, my friend...
Old Oct 14, 2011 | 08:50 PM
  #153
cford716's Avatar
cford716
A 2.0L TDI redlines at 5000 rpm... power falls off at 4300 rpm, and folks recommend you shift at 2500 rpm cold, 3000 rpm when warmed up. Also, it is common on TDI club, becuase the cars are only 22 to $27 k, that you break the motor in by seating the rings by "driving it like you stole it" to seat the rings properly. This has persisted since 2000, long before HPFP's were on TDI's or HPFP's being more critical for break in than cylinder bores and rings. It's an outdated procedure, but the crowd at TDI club is young, the car is affordable.
E =MV squared.... you double the RPM's, you quadruple the load laterally on that piston and roller in the HPFP bore.... it aggravates the wear... everything happens with more RPM's in a TDI.... it is a high rpm diesel motor design, it really needs 52 cetane to get good mpg on the highway while cruising.
A 6.7 redlines at what 3300 rpm, maybe 3500? There's your sign.
6.7 redlines at 4000 rpm
Old Oct 14, 2011 | 09:26 PM
  #154
NinerBikes's Avatar
NinerBikes
Originally Posted by kper05
The world isn’t perfect so random failures at different times is reality.
All things eventually fail but with the extreme pressure the hardware components are under, it feels like to me these expensive, well built components will still fail early.
I too have a difficult time realizing the pressures involved.
That’s why I was wondering if the manufacture of the major fuel system components (with different life spans I’m sure) actually report a MTBF.
The variables are so different region to region (fuel quality, climate, use, etc.) they may not even feel reporting a number is helpful.
VW quoted a 150,000 km life cycle for their TDI motors....... that's 94k miles that they consider a "life time" for all the components before off to the junkyard.
TDIClub Forums - View Single Post - The Delphi DFP 6 High Pressure Fuel Pump Thread.
If you take a look at this post on TDI club, you can see the differences in the piston design, and the square bore for the shoe follower on the Dellphi DFP 6 versus the round bored "top hat" roller follower on the Bosch CP 4.1. You then have to ask "What is preventing that roller from going out of alignment with the cam?" Nothing, nothing at all, and that is exactly what Delphi addressed in their pump design... things that make you go Hmmm?
Old Oct 14, 2011 | 09:29 PM
  #155
Tom's Avatar
Tom
Our trucks don't use the CP4.1. And from everything I've read failures of the CP 4.2 are downright rare in comparison.
Do some searching and tell me how many Ford 6.7L and GM Duramax CP4.2 failures you find. There aren't very many.
Old Oct 14, 2011 | 09:48 PM
  #156
p12483's Avatar
p12483
Does the new Cummins use a similair HPFP?
Old Oct 14, 2011 | 10:40 PM
  #157
Tom's Avatar
Tom
Looks like the 6.7L uses the same Bosch CP3 pump that the Duramax used up until recently.
Old Oct 14, 2011 | 10:45 PM
  #158
rickatic's Avatar
rickatic
Originally Posted by 720Deere
You ask questions that I too have asked myself. I think in the end you find out that it is not you and I that are missing something, but rather some of the threads that are missing something.........details. Cheezit posted in another thread that he has replaced one pump and that truck had a fuel tank half full of water. He also mentioned that the WIF code had been stored in the KAM.
Now I am going to offer up what will be a very unpopular opinion, but it has been a mantra of mine for many years. There are 3 sides to every story. The vehicle owner's side, Ford's side and ultimately the truth which probably lies somewhere in between the first two. Many details we will never know, yet a lot of people have drawn some pretty harsh conclusions based on what little that we know.
The first dealer reported rust in the fuel system. Did the second dealer and/or the FSE find no evidence of rust? I would think if it was proven that there was no rust anywhere in the fuel system that would be enough to bring into question the validity of the first dealer's warranty flag. Sorry guys but I'm not ready to jump ship over one documented failure. If I had bought a parachute instead of a truck my concern level may be a little higher over one failure.
I have tried my best to make sure that the three sided story scenario would not be invoked. I will make another attempt. The first dealer replaced two different parts in two separate repairs in two failed attempts to repair the truck. There was no mention of water in fuel throughout the five days it took to attempt these repairs. The very part that this dealer used to void the warranty coverage on this repair was the same part they replaced with a new one in the second attempt. The discoloration of the ferrous metal base of this part is barely noticeable. So much so, that until the dealer knew he was now in the soup for two repairs that Ford would not reimburse him, the water in fuel card had still not been played. Their WIF diagnosis was a desperation move on their part to cover their previous ineptitude. My instincts tell me that based on their talent for covering their tracks in paperwork, they have been down this road before. I have been allowed to read the Customer Service Report. It is Pulitzer Prize material.
Shepherd Lincoln took one look at the truck, the fuel samples and the parts in question and immediately said that there first reaction was not water damage. They did withhold final opinion until their diesel tech with 33 years experience had a chance to do his job. After two days of pinpoint diagnosis, their position was HPFP pump failure not related to fuel quality or water. They had serviced the truck since new. They had drained the fuel separator multiple times. Each service record shows no water found in the fuel separator.
Then the political positioning began. Ford refused to send a FSE out for over a week. Not until my BIL, a Ford engineer and Plant Manager, got involved and made some contacts within the FSE department did a FSE appear. After his visit, he told the service manger he was not the enemy and he would have to see where he could go with this issue. In the end, internal politics and dealership CYA won out.
I am not the type to walk away from my responsibilities in situations like this. If I thought for an instant that there was a modicum of responsibility assignable to me in this fiasco, I would buck up and bear the burden. However, this is not the case. Those that know me realize the truth in that statement. Those that distrust my statements, I can only say that you do not know me. Even the high level Ford person who escalated the case agreed that I was in no way responsible for the breakdown. I have an email stating that fact. The other members who helped here have seen this email.
I hope this clarification helps others here understand the reality of the situation.
Regards
Old Oct 14, 2011 | 11:30 PM
  #159
Glockin' Bob's Avatar
Glockin' Bob
Even water in the fuel system should not cause failure of the HPFP. It should cause the truck to shutdown. Water which is not emulsified is not supposed to penetrate the Racor filter.
You may not be ready to jump ship, but you might put your life preserver on. The facts about the CP4.2 pump, that VW has had numerous failures, that Bosch recommends fuel with much higher lubricity than is commonly available in the U.S., those facts cast a significant shadow of doubt about the future reliability and cost of ownership, to say nothing for the behavior of FoMoCo.
Old Oct 14, 2011 | 11:33 PM
  #160
jwp98's Avatar
jwp98
If I understand correctly, this rare failure is costing rickatic $600 (could have been $10k.)
Many of us can sneeze or fart $600 to keep a good truck rolling.
What we can't tolerate is a slap in the face from a corrupt and incompetent company. I've heard enough to decide.
If anyone employed by Ford is reading this, visualize a smiley with his middle finger extended.
Old Oct 15, 2011 | 12:33 AM
  #161
NinerBikes's Avatar
NinerBikes
When I read stuff like this, from England, on top quality European D2 for fuel, and the pump still fails... then it's not the fuel... it's the pump design.
http://forums.tdiclub.com/showpost.p...&postcount=835
Same thing for pumps in Canada, failures on 460 micron canadian spec fuel.
Old Oct 15, 2011 | 07:08 AM
  #162
dbc001's Avatar
dbc001
Rick .... I would be very surprised if anyone on FTE that knows you seriously doubts your information, candor, or honesty. I am going to suggest that the doubting Thomas' are just in disbelief that something like this could actually happen and are looking for something normal to hold onto. Something that doesn't raise the fear factor that they maybe sitting on a time bomb.
As this issue makes headlines, based on your post yesterday, there will be many, many, more users chiming in that have no pre knowledge of you, your truck, or the history. Simply armchair quarterbacks that have an opinion but little to no value to add. Or GM/Dodge sales people that are salivating.
In case your wondering NinerBikes I was not referring to you.
Old Oct 15, 2011 | 07:11 AM
  #163
720Deere's Avatar
720Deere
Here is where the problem starts. I have posted my concerns about emulsified water many times in the past. We are not guaranteed that unscrupulous fuel vendors are not using emulsifiers in their tanks for their own benefit. If they have emulsified any water in their tanks, when you come back on them for bad fuel and the tank is tested, voila no water shows! Even using an additive with demulsifiers will not guarantee full water separation.
How many people have you heard stating that they don't find any water when they drain their water separator.........95%-98%? I wonder how it is possible that as many times as the fuel is transferred from one tank to another sometimes during rain events that no water is making into the water separator? I know for a fact that storage tanks at terminals have water drained off of them daily due to condensation buildup in the large tanks. I won't continue to beat a dead horse about emulsified water.
Rick, thanks for the response. My mind develops questions and I ask them to satisfy it, not necessarily to discredit you. No matter the circumstances, it appears that you are the victim. Now that you have a completely new fuel system, what are the possibilities of future warranty on those components? If there is no possible warranty on the fuel system, I would think seriously about aftermarket water separation and lubricity additive. Of course those will be necessary items on a Duramax that uses the same pump as well.
Old Oct 15, 2011 | 09:21 AM
  #164
Percys Armory's Avatar
Percys Armory
You really should be extending that finger to the dealer that flagged it as non warranty
Old Oct 15, 2011 | 09:35 AM
  #165
jwp98's Avatar
jwp98
You're right I should, but I'm feeling bitter and sassy as I just had a similar experience with a foreign manufacturer. I also find it hard to believe that some mid-level suit at Ford couldn't easily reverse the first dealer's decision.
Peace and a great weekend to all.
