HPFP failures
Old Oct 15, 2011 | 04:45 PM
  #181
Tom's Avatar
Tom
You missed my point. The 2011+ Duramax trucks have been out for over a year. These do not use the CP3 anymore, they use the same CP4.2 that you've been attacking since you've come here.
Where are the mass failures? Same here, we have some 6.7L trucks here with over 80,000 miles already. Yet still very few failures.
Old Oct 15, 2011 | 04:56 PM
  #182
jayman2's Avatar
jayman2
NinerBikes , I'am going to have to respectfully disagree with your theory of a bad design . I'll play the numbers game here for a second . Bosch has sold over 3 million of these cp4.2 hp pumps since 2010 , even at a 10% failure rate that would mean 300,000 cars and trucks would be in shops with this problem . Even at a 1% failure rate thats 30,000 units that would be effected.
From what i could research , 3 superduty's, a handful of audi's ,some jeep's with the 3.0 diesel, and the vw tdi's. Total i give you maybe 10,000 cars and trucks with this pump have failed and thats on the excessive side. That's less than 1 percent. Which from a manufacture's point a 99% product success rate does not constitute a design flaw.
Jay
Old Oct 15, 2011 | 05:58 PM
  #183
NinerBikes's Avatar
NinerBikes
Jay
Great, then with the profit Bosch has made on selling 3 million of them, then a few warranty coverage pumps should be no big thing to cover. Why is Bosch being so stingy?
I'd also like to see your source of 3 million of these pumps being sold by Bosch. That would be proprietary sales information, the sales figures for Bosch. The pump alone goes for 1000 Euro.
Maybe you can share with us why so many Bosch CP4.1 pumps on tiny little 2.0 liter 4 banger motors are failing?
1% is unacceptable, when someone can get killed when the motor dies permanently. Ask a jury... and if you think it's acceptable, let's try that statistic in the airlines industry, or the aerospace industry. I'm not adjusting my expectations downwards, ever, for such mediocre performance. It's unacceptable, when the damage cracks 9 to 10 grand a pop.
Respectfully submitted... NinerBikes
Old Oct 15, 2011 | 06:29 PM
  #184
Tom's Avatar
Tom
I've mentioned this to you before, and I'm growing tired of it. For the last time, this is not relevant. These trucks do not use the CP4.1 pump. This is neither a VW TDI forum nor a Bosch forum, it's a Ford Trucks forum. And these engines do not use the apparently trouble-prone CP4.1 pump.
ON edit:
And I agree with you that it's not acceptable for a defect to cost the customer that much money. It is ridiculous, and there's no getting around that. But we just haven't seen enough of these to say that it's a defective pump, and we have yet to find a correlation between failure modes of the 4.2s found on the GM, Ford, and VW vehicles.
Old Oct 15, 2011 | 06:40 PM
  #185
Hdslider's Avatar
Hdslider
Crazy001 ck pm.thanks Paul
Old Oct 15, 2011 | 10:28 PM
  #186
B HOOFED's Avatar
B HOOFED
Originally Posted by Front Runner
That is my point exactly. If Ford says that WIF caused the damage, well are they going to prove it! No WIF light, no record of it in the PCM, was the fuel tested for water? How can such claims be made with no standing? For all we know Rick could have gotten a ticking time bomb of a HPFP. Ford has to come a little better than this IMO before voiding a warranty claim.
Am I off base here?
Only two scenarios in which a warranty claim for a failed HPFP could legitimately be rejected:
Misfueling (gasoline, urea, improper additive containing emulsifiers)
Owner neglect/improper maintenance such as failing to replace fuel filters at recommended interval, or using filters that don't meet Ford specifications.
If you do everything Ford says you need to do, according to the maintenance schedule in the manual, I don't see how they can not cover failure of a warranted part.
Old Oct 15, 2011 | 11:39 PM
  #187
MisterCMK's Avatar
MisterCMK
ON edit:
Tom, isn't the CP4.1 a single piston and the CP4.2 a 2 piston? If so I would say that there certainly is relevance between the failures of that family of pumps.
Old Oct 16, 2011 | 09:38 AM
  #188
Glockin' Bob's Avatar
Glockin' Bob
I can see both sides. Ford shouldn't have to warranty the situation where emulsified water pits the pump and injectors. But in the absence of absolute proof that bad fuel was in the tank, I think the consumer gets the benefit of the doubt.
I'm guessing that if the cost to us is $10,000 to fix the engine when a pump grenades, the actual cost to Ford is more like $5,000. If the number of such failures is as low as only perhaps 6 failures at this point, I'd think it would make good business sense to go ahead with warranty repair.
Old Oct 16, 2011 | 09:45 AM
  #189
Tom's Avatar
Tom
The problem is that the failure modes between these different pumps just hasn't been consistent. For some reason the CP4.1 pump has been having numerous failures at low miles in the Volkswagen application. These pump failures are commonplace, but limited to the Volkswagen/Audi pumps. The CP4.2s used in the larger TDI VW and Audi engines also have not demonstrated similar failures to those used in the D-Max and Powerstroke engines.
They are all in the same family, but are not the same pumps. I believe the CP4.x series has been around for a couple years now, and it's likely that Bosch implemented some revisions that make the ones used in the D-Max and Powerstroke to make them more reliable. The pumps between the D-Max and Powerstroke have mechanical differences, and I'm sure that also means that our pumps are different from the VWs.
This thread is going every which way, and we need to keep this focused on the pumps on the Ford Powerstroke 6.7L engine.
Old Oct 16, 2011 | 10:01 AM
  #190
Hdslider's Avatar
Hdslider
Amen on pumps on a 6.7
Old Oct 16, 2011 | 10:48 AM
  #191
sscarboro's Avatar
sscarboro
If emulsified water is a problem for this pump then why would they certify the 6.7 or any engine using these pumps as B20 engines? Doesn't Bio Diesel contain emulsified water?
Steve
Old Oct 16, 2011 | 11:05 AM
  #192
Glockin' Bob
Steve
Which is part of the reason I think that if Rick would have pushed a bit harder by going outside of Ford with his complaint, that eventually it would have been covered by warranty. Perhaps it still can be and the insurance company reimbursed?
Given the facts as I know them, I still think that Rick's pump failure should have been covered by warranty. If some very reasonable amount of emulsified water is in the fuel, as is implied by biodiesel, the pump should be resistant to damage. (That's not to imply that Rick had any emulsified water or biodiesel in his fuel)
It might be illuminating if a third-party engineer examined Rick's failed pump and injectors.
Old Oct 16, 2011 | 11:06 AM
  #193
rickatic's Avatar
rickatic
Steve
Great question...I was accused of running biodiesel by the first dealer...never bought a drop of the stuff for this truck
Old Oct 16, 2011 | 11:18 AM
  #194
NinerBikes's Avatar
NinerBikes
Enlighten me as to the mechanical differences internally, on the working parts, the cams, the rollers, the followers, the plungers and the bores of plungers on the DMax motor and the 6.7 PS, perhaps with some pictures of the internal guts, because the CP4X pumps I've seen all have the same amount of teeth on them that the crankshaft does, they turn at the same speed as the crank, which is double the RPM's that the old VPS 37 and 44 systems did.
These Bosch CR pumps on the Ford are so simple in design, it's stupid, compared to older models that were mechanical Injector pumps. Now fueling is controlled electronically by a brain, crank sensors, cam sensors, needle lift sensors, piezos pressure sensors on the glow plugs, not mechanically.
Really, it is a pump, a high pressure one that makes up to 28,000 psi in the rail at full throttle applications, but most of the time, it runs around 10 to 14,000 psi. If it doesn't make enough pressure, either the pressure sensor on the pump, or the pressure sensor on the common rail near the bleed off valve shuts the Electronic control unit down, and the software says your fuel pressure is out of spec, kill the motor from running. As the pump starts grenading... with metal on metal contact and no lube film barrier, or rotation of the piston and cam follower in the bore, possibly getting 90 degrees out of alignment, metal bits go everywhere, including the pressure sensor on the HPFP, which has a very small trap screen built in to it. The trap screen gets overloaded with metal swarf and debris, clogs up, pressure drops, sensor then shuts the motor off for too low a fuel pressure. You can run an OBD II scan and see something like P0082, fuel pressure too low stored in the memory. As a matter of consideration, if your goes and stops running, everyone should have an OBD II reader to pull the code, and then look it up on the internet, what the code means. I am not sure, but with 2 rails on your motors, the code could be off by a number or, two, one code will direct you to the left bank, another code, one one digit higher or lower, with direct you to the other bank of the motor. If both rails have low pressure, well, look at the HPFP then.
Really, guys, it pays for you to educate yourselves on how these systems run... they are complex, and you need to know more than the dealership servicing your trucks, so you can tell when you are getting a snow job. I really feel bad for Ric on this, I've seen the same thing happen to owners of other CR Bosch CP4x systems, and it's like deja vu all over again.
So, lets see some pictures, less talk, more pictures. Anyone frequent truck boards where the guys actually tear in to these pumps and take pictures after warranty is denied?
Old Oct 16, 2011 | 11:38 AM
  #195
Tom's Avatar
Tom
If I could enlighten you I certainly would. But I don't know the exact specifics.
I do know that they are not identical. Furthermore I know that there are over 400,000 of these trucks on the road and some have been for almost a year and a half. And yet failure seems downright rare. By your own opinion these pumps should be failing every day, and yet they are not. If you do some google searching you will find Rick's story on no fewer than three message boards and little else. These pumps have NOT proven to be unreliable in these trucks yet. I'm not saying that they won't, but they certainly haven't been failing at 10-15,000 miles like you are implying.
And also,
Why don't you ask around before posting stuff like this? There may be more differences than you think, the FRP when running down the road is almost always higher than 10-14,000 PSI.
