new steering column for 55 f100
was wondering wut u guys/girls have used with a new steering column also to have it clear your headers right now i have a 390 and before i had it the guy bent the header to fit the old steering so please need help! where to look and what u are using thanks and also help with some good headers?
well i was looking online i read about ppl taking out there steering box and adding in a ball bearing or something could that be connected to original steering column i cant find any more info on the bearing column ?? i need to have clearance with my headers the guy bent in with a hammer and heat and all made a crack no has bad exhuast leak lol sounds like a poping popcorn so please help on that bearing steering box ??
I had to modify my last tube to fit the toyota box in my '54 with a 390. sanderson ff390's
Header clearance - THE H.A.M.B.
i would think the stock box would fit better then the toyota one.
I seen some Here 0308Cl Straightaxil11 Z Photo 11
But if I found some stock 390 headers will it clear my original steering box in the 55 ?
yes the toyota kit will fit your original column with mods. you'll need to cut the stock column and weld, spline your old shaft or double d the old shaft to fit the new u joint.
https://www.ford-trucks.com/forums/9...mn-repair.html
chad77
11-11-2015 07:59 PM
The67Beast
02-08-2006 11:04 PM
RWDCelicadude
06-03-2004 01:07 AM
