Steering column clicking
Old Nov 27, 2010 | 12:03 PM
Scratcher's Avatar
Scratcher
I replaced my steering shaft a few months back to eliminate drifting from a worn rag joint. Steering is great but I'm feeling a little click when turning the wheel. I took the steering wheel off and turned the column with a pair of mole grips and the clicks still there. It feels as if its somewhere on the column and not on the new shaft. Any ideas anyone?
Old Nov 27, 2010 | 12:52 PM
greywynd's Avatar
greywynd
I'm thinking there's a bearing/bushing in the bottom of the column, but never got into one before. What about popping it apart at the box, and trying it again? See if it helps isolate it for sure?
Old Nov 27, 2010 | 10:52 PM
Scratcher's Avatar
Scratcher
It feels like its nearer the top but I could be wrong
Old Nov 28, 2010 | 05:13 PM
rmalottwtes30's Avatar
rmalottwtes30
My bet is your top steering column bearing is gone, does your steering wheel wiggle?
Old Nov 28, 2010 | 07:51 PM
Scratcher's Avatar
Scratcher
There is a small amount of free play in it. Can the bearing be replaced or is it easier to put another column in?
Old Nov 28, 2010 | 08:23 PM
rmalottwtes30
They actually make a kit from ford, most likely you will need to order it from your local dealer, cant get it through a local parts stores bummer.
Here is the part number
F6AZ-3605-AA
This may help you out also.
96-23-1***STEERING - "CLICKING" NOISE HEARD WHEN TURNING STEERING WHEEL***NOISE - "CLICKING" SOUND HEARD WHEN TURNING STEERING WHEEL
Old Nov 28, 2010 | 08:58 PM
Scratcher's Avatar
Scratcher
F6AZ-3605-AA
Thanks bud
mattt181
Feb 28, 2016 04:14 PM
tl1965
WTB - Parts & other
Feb 2, 2016 09:08 PM
biker55
1997 - 2003 F150
Jan 24, 2015 12:56 PM
FSJ-EARL
Nov 25, 2013 07:40 PM
guessrow
2004 - 2008 F150
Sep 20, 2013 08:44 PM
