Rotella T6 from Amazon
Old Apr 29, 2024 | 10:14 AM
johndeerefarmer's Avatar
johndeerefarmer
In the past I have bought 1 gal and 5 gallon jugs of Rotella T6 from Amazon. This time I bought two 2.5 gallon jugs. They came in cardboard boxes with no markings of any kind. The jugs were in plastic bags. On both jugs the seal was partially open- crinkled up seal. Since one was spilled Amazon is sending a replacement. I want to see if the seal looks like it was messed with as well.
Wondering if this is real Rotella? It came from Amazon not a third party
Old Apr 29, 2024 | 10:22 AM
OBS460's Avatar
OBS460
I always just looked on Homedepot.com or Walmart to find T6 in 2.5 gallon jugs. Amazon has A LOT of reviews from people buying oil that they show up leaking.
Old Apr 29, 2024 | 10:48 AM
acdii's Avatar
acdii
This This
is the only T6 I will buy from Amazon.
Old Apr 29, 2024 | 11:09 AM
4wd6.7L's Avatar
4wd6.7L
My only experience with the 2.5 gallon size was from Tractor supply, in store. I had to pick through a few because some were leaking. At the time the 2.5g size used a seal, the seal was loose or lifted a little on the ones leaking in store. Never experienced that with the gallon size from anywhere I've purchased, whether online or in store, but they also have a different cap and seal arrangement.
Old Apr 29, 2024 | 11:13 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Biggest I've ever purchased was the '5 quart' jugs, which would be a gallon and a quarter. Some places carry the gallons, others the gallon and a quarter. Much bigger than that, though, and they get to be tough to manhandle and the chance for spillage goes up.
Old Apr 29, 2024 | 11:57 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Man, you'll have to show us that one.
I've never seen shell rotella in a 5qt jug.
To the OP, I know amazon sells a lot of stuff that they buy in bulk from china/india and package themselves for resale in unmarked packaging, but have never seen real rotella oil come in anything but actual shell labeled jugs and boxes, I sure would be wary of that oil they sent you.
Old Apr 29, 2024 | 12:00 PM
4wd6.7L's Avatar
4wd6.7L
They would come in unmarked boxes if they aren't normally packaged and sold in that quantity from Shell. Like if I were to order two, 1 gallon jugs I wouldn't expect it to come in a Rotella marked box.
Old Apr 29, 2024 | 12:06 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
But, shell does sell 2.5 gallon jugs, so something is off.
Old Apr 29, 2024 | 12:10 PM
chadstickpoindexter's Avatar
chadstickpoindexter
This is why I try to order things from anywhere but Amazon… and if I want something of value and I want to know it’s authentic, I won’t order it from Amazon. There are exceptions, like if the item I am ordering is listed to ship from the actual company.
But if it isn’t in an actual Rotella T6 jug, I wouldn’t use it. Send it back.
Old Apr 29, 2024 | 12:15 PM
stryder's Avatar
stryder
Originally Posted by acdii
This is the only T6 I will buy from Amazon.
That's all I order anymore as well. Comes in original Rotella box. Never had an issue with leaks. The 2.5 gallon jugs I've bought locally definitely are not sealed the best.
Old Apr 29, 2024 | 12:18 PM
johndeerefarmer
Thanks, I guess they have issues with their seals on the 2.5 jugs. All of my 1 gallon jugs have the lid like a water bottle where you twist it to break the ring at the bottom
Old Apr 29, 2024 | 12:29 PM
SARDiverDan's Avatar
SARDiverDan
I tried Amazon for T6 once. The order never showed up. I go to Walmart or a local Auto Zone when they have a deal. The Tractor Supply stores out here never seem to have any.
Old Apr 29, 2024 | 12:33 PM
4wd6.7L's Avatar
4wd6.7L
Yes, but maybe not in a two jug quantity. Maybe I'm not understanding what the issue is.
Old Apr 29, 2024 | 12:40 PM
Phillbo's Avatar
Phillbo
I would not put it in my truck. Someone may have sucked out all the T6 and pumped in a lower grade oil just to make .16cents more profit........
Old Apr 29, 2024 | 02:47 PM
stryder's Avatar
stryder
If you buy the 3 one gallon case that Acdii linked above, it comes in a sealed box from Rotella. It may ship from an Amazon warehouse, but it's factory sealed. The gallon jugs also have the tinfoil type seal under the sealed cap. So would be pretty difficult to pull off a switch without noticing.
