The camper thread! Pulling, using, equipment, maintenance!
Old Mar 15, 2016 | 12:09 PM
  #1381
Country_Mouse's Avatar
Country_Mouse
Originally Posted by karrun
You left off cheap. If I can do something myself for less money I'm all about that.
I'm all about saving $, I was an extreme couponer after all.
In this case husband time : $ saved after buying supplies not a big enough gap.
Old Mar 15, 2016 | 12:56 PM
  #1382
karrun's Avatar
karrun
Well in my case, ~$10 in materials and about a half an hour or so plus paint beats $70. Then again, my time probably isn't worth as much as his.
Old Mar 15, 2016 | 01:00 PM
  #1383
Country_Mouse
I don't see my husband whipping that up in 30 min, lol! Maybe I don't give him enough credit.
Old Mar 18, 2016 | 10:21 PM
  #1384
copsey's Avatar
copsey
The Hensley showed up today. Looked better than the pictures except for a missing bearing cap on the bottom. Looks like it was knocked off in shipping as the grease was still there, clean and no rust. Install looks pretty straight forward if not long winded in the manual. Any tips on install, Tom? Going through it tomorrow after work to repack all bearings and repaint the stinger. I believe the seller was incorrect and I have the 1400# bars. Anyway to verify? They are huge.
Old Mar 19, 2016 | 08:35 AM
  #1385
Snowseeker's Avatar
Snowseeker
The floor on the drivers side of the TT is soft... I just did the passenger side last year or the year before. Its not a fun job.
Old Mar 19, 2016 | 09:47 AM
  #1386
WE3ZS's Avatar
WE3ZS
Both sets of bars I have have the rate stamped into them somewhere, it's small but give them a close look.
Pull the bar bushing out of the lower hitch head and verify that the two sides are still connected to the little bridge piece, and then check the interiors for wear and replace if needed. Of course if you need to change spring bars for the correct rating then that bushing will also need changing too.
Do yourself a favor and buy at least two new zerk assemblies for the bar retainers, install new ones and keep the old ones in a bag along with an extra new one or two for on the road spares. In my spares box I also keep extra strut bar end pins, shear bolts, over center latch pins and a few extra safety clips/pins, I hate it when they disappear!
Pack as much grease into the bar bushings as possible them after the bars are in pump more in through the zerk fittings and then repump those zerks before every trip.
Also make sure that your safety chains, break away cable and 7 pin cord are going to be long enough with the extra length of the HA. I had to move the junction box a little on the Jayco to ensure the cord wouldn't be stretch too far on turns.
Feel free to hit me up with any other questions during the install, I'll be checking in here a few more times today but tomorrow will be a pack up and travel day with a 10 hour tow back into a Wintery mix and snow forecast.
Old Mar 19, 2016 | 02:08 PM
  #1387
copsey's Avatar
copsey
Will check the bars again...do you remember where on the bars they were stamped?
Old Mar 20, 2016 | 07:40 PM
  #1388
WE3ZS's Avatar
WE3ZS
I can check in the AM, we just got back home and it's SNOWING!
Old Mar 20, 2016 | 07:51 PM
  #1389
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
We got our snow yesterday. I was wondering if you were going to get stuck in that stuff. Hope you made it before the salt was laid down?
Old Mar 20, 2016 | 08:23 PM
  #1390
WE3ZS's Avatar
WE3ZS
The last 100 miles they had roads brined but they were still dry, so that was OK, but then about 10 miles from home it started a steady Wintery mix that got everything wet and covered in salty spray.
I will be giving the underside a good wash down this week for sure.
Old Mar 20, 2016 | 09:32 PM
  #1391
copsey's Avatar
copsey
We had snow Friday night into Saturday. No accumulation but enough they wanted to put several tons of salt down on the roads. Thanks,can't wait for the answer. Checked my bars again and can't find anything but I'd had a few dad pops as I was cleaning the garage.
Old Mar 20, 2016 | 10:21 PM
  #1392
hav24wheel's Avatar
hav24wheel
Speaking of salt... We got snow Friday into Sat morn. Of course I had a 200 mile trip to take. When I got there I found the nearest car wash. The Lincoln looked horrible!! Got the best wash with underbody rinse too.
It rolled to 50,000 miles today on the way home even. Lol
Old Mar 20, 2016 | 11:26 PM
  #1393
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
We had snow, but no salt hehe
BTW I love that Lincoln!
Old Mar 21, 2016 | 06:15 AM
  #1394
hav24wheel's Avatar
hav24wheel
I wish we didn't hav salt. They started using it about 2 yrs ago. N they over do it. A lot of the plow trucks didn't even have a plow on them this year!! Thanks. I need to take it in like you and get the body on it redone.
Old Mar 21, 2016 | 12:40 PM
  #1395
WE3ZS's Avatar
WE3ZS
OK, I just looked both of my bar sets over...........and I can't find the markings on the 1400lb bars! . The 1000lb set has "1000" stamped into the bars on the flat tapered section along with a manufacturers stick (Draw-Tite by the way), I though that the bigger set also had the rating marked but looks like I was wrong. I did measure them though, the 1000lb set is 1 3/8" thick on the round section just below the bend and the 1400lb set is 1 1/2" thick. Hopefully this helps some.
