The camper thread! Pulling, using, equipment, maintenance!
Old May 15, 2016 | 03:51 PM
  #1651
Pwrgeek's Avatar
Pwrgeek
Originally Posted by Excurvelle
Met a guy at the campground with a 6.0 l, we traded stories. He was supposed to leave fri but when turning into ft wilderness his right rear wheel on his fifth wheel broke off, he is staying waiting for parts. Oh well, stuck at Disney World with a broken camper, could be worse.
When were parked I run two Honda eu2000is in parallel.
Old May 15, 2016 | 10:02 PM
  #1652
WE3ZS's Avatar
WE3ZS
We have the set of Honda eu200is also, mated together they did a great job serving up power to the 30 amp RV plug on our old toyhauler at the racetrack. We don't boondock with the new TT so they now stay tucked away and only get used during power outages keeping friends and neighbors fridges cold.
Originally Posted by sky Cowboy
I have a yamaha generator i take camping.
Normally it barely works at all....but even just the little air conditioner in my camper makes it beg for mercy for the first few seconds when i turn it on.
Surprisingly the microwave makes it work hard to....on my last camping trip i popped a bag of microwave popcorn and the yami ran hard for that 2.5 mins. I should probably get bigger generator, but 98% of the time it does fine.
Yamaha Motor Canada :: Products :: Power Equipment :: Inverter Series :: EF2400iSHC
Be careful with the AC and that genny, having the AC compressor laboring at startup like that can age it prematurely.
Old May 15, 2016 | 11:23 PM
  #1653
Pwrgeek's Avatar
Pwrgeek
Originally Posted by WE3ZS
We have the set of Honda eu200is also, mated together they did a great job serving up power to the 30 amp RV plug on our old toyhauler at the racetrack. We don't boondock with the new TT so they now stay tucked away and only get used during power outages keeping friends and neighbors fridges cold.Be careful with the AC and that genny, having the AC compressor laboring at startup like that can age it prematurely.
Yeah mine only get used a couple times a year when we're in the national forest either for the Sunrise 3D shootout or elk hunting. Other than that my trailer is pretty much a park queen because I use it for work. I did a propane conversation on both Hondas a couple of years ago so I wouldn't have to worry about gummed up carbs from leaving gas in them for too long. Has worked out great.
Old May 15, 2016 | 11:37 PM
  #1654
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I just pulled my trailer out and put it next to the garage to plug it in. I'm running out of time fast so I think I'm going to stick with one new deep cycle battery combined with the new little generator that should keep me going just fine.
I would really like to figure out why I can't get the fridge to run on propane, does great plugged in but it won't light up on gas. I need to actually spend some time messing with that. Oh and I need to flush all the antifreeze out...ughhh
Old May 16, 2016 | 06:43 AM
  #1655
ExxWhy's Avatar
ExxWhy
You can change the start capacitor on the AC unit which is supposed to help a lot on startups using a generator.
Careful with that fridge Russ. A lot of RV fridges have been recalled over the years for propane leaks. Sadly a lot of RV's have burned because of it too. You might want to check your fridge model number for recalls.
Course it could be something as simple as a wasp nest in the tubing.
Old May 16, 2016 | 08:03 AM
  #1656
Snowseeker's Avatar
Snowseeker
I know it takes some time to purge the gas line to the fridge in my TT every year.
I have heard many times it is cheaper to replace the whole fridge unit if it is having problems than to buy parts and try to fix it. Unless it is some obvious cheap part that needs changing. But if the unit is older and you have to buy more than just one part to "chase a problem" thats when it is cheaper to get a whole unit I hear.
I do know mine was slow on cooling down last year when I switched to gas. From what I read some sort of "stuff" builds up on the insides of the freon tubes and blocks them from flowing. I feel this is whats happening with mine and one of these years will be the last for it. I wish there was a way to clean it out.
Old May 16, 2016 | 09:54 AM
  #1657
mecdac's Avatar
mecdac
Wink
Before I traded up I thought I was going to have to replace my reefer and it was going to be $1100. It turns out I just didn't have the unit level.
Three weeks later I eliminated the problem and traded up to 2015 model.
Old May 16, 2016 | 11:22 AM
  #1658
sky Cowboy's Avatar
sky Cowboy
Thanks guys for the tips.
I may upgrade to a larger generator oneday.
The rv place said while borderline it should be okay.
I turn everything else off if going to use the AC when i turn it on.
Then just use low draw items like lights while it runs.
Apparently it doesn't need as much power as a larger unit like a big trailer would have.
I also don't use it a lot. Usually just open the windows and latch the door open and let the breeze blow through the camper.
That is one benefit to having a small camper i guess.
And i can tow the boat now to since I got this little guy.
When i had my bigger tt I had to leave the boat home.
Old May 16, 2016 | 11:39 AM
  #1659
sky Cowboy's Avatar
sky Cowboy
What i should do is find out the actual specifications actually. Not take what the salesman said as factual.
I may call Coleman and ask them since they make it.
Says its a low profile series 9...whatever that means ☺
I just know i can hear the little yamaha work when i turn it on.
But flip on lights or stuff anx I cannot even hear the engine tone change.
Old May 16, 2016 | 02:03 PM
  #1660
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I'm thinking this and the fact I have a very hard time getting it level are two main factors to my problem.
This trailer is basically a throw away so I don't want to dump a bunch of money in it, but I know when I do go to sell it I'll still be making a profit in a couple years when I upgrade to a 25-28ft.
Old May 18, 2016 | 08:20 AM
  #1661
pgguru's Avatar
pgguru
I am moving my Daughter to Halifax In Mid June and was planing on taking the TT and coming back through the US back to Buffalo.
Any one know what we can do? Where to Camp? Must See?
Thanks
Old May 18, 2016 | 09:12 AM
  #1662
az_r2d1's Avatar
az_r2d1
Having the RV level is VITAL for the fridge to run well.
Old May 18, 2016 | 10:38 AM
  #1663
sky Cowboy's Avatar
sky Cowboy
Best how to instructional video on the Internet for dumping the rv holding tanks.
Old May 18, 2016 | 10:45 AM
  #1664
az_r2d1's Avatar
az_r2d1
Everyone's favorite part of rv-ing....lol
Old May 18, 2016 | 11:49 AM
  #1665
IMASAP's Avatar
IMASAP
Yeah, the sap's free advice for the day: Don't wear flip flops when you head to the dump station.
