- 4R70W + transgo kit problems
- What fluid for tranny
- dual mass flywheel failure rate
- Married C6 Rear shaft issues
- transfer case fluid change?
- 92 F250 shifting hard
- mystery buzzing sound
- Where do you put the temp sender for aftermarket tranny temp gauge?
- E4OD Zip file?
- Vehicle Speed Sensor? C6 -> E40D speedo gear?
- 5.8 Flywheel, Tooth count and balance
- Metallic rattling in 5 speed
- '92 F350 EO4D OD start
- 203 doubler
- E4OD Shift kits... Suggestions/ideas?
- Towing/ Mileage converter for C6
- 5 speed stick in place of an AOD??
- C6, diesel, poor engagement when cold
- T18 vs 435
- d50 or d60
- reverse rotation gears???????????
- Front axle lube change
- 400/460 C6 Torque Converter
- Powertrax limited slip?
- 94 F150 E40D Strange Shifting
- tork converter/transmission
- 9" 3rd member and axle tubes
- whining noise
- C6 rolls in park
- strength of standard 3 speed
