- 1999 Expedition air sus. pump
- 5.4L 4V Heads Spark Plug Blow Out
- 2002 expedition 4.6L xlt output shaft seal replacement
- Can't ID leaking a/c hose
- HELP!! P0302 and P0171
- Failing COP or bad plugs???
- ball joints DIY?
- HD towing package ?
- 2003 expedition 5.4l 4x4high & low lights falsh every few seconds three times while driving?
- How do you replace the A/C condensor on a 1999 Ford Expedition 5.4L
- Expedition Problems
- Ac help please 2001 navigator
- Expedition hatch door doesn't open
- 2001 Expy Upper Intake Man. Replacement
- Steering wheel controls (radio volume, temp, fan speed, cruise, etc.)
- 1997 Expedition Exhaust Leak, erratic idle, bypass O2 sensors?
- What is this part called???
- 01 expi changeover... project blackout
- 1999 Exped.drivers side sits 2" higher
- replacing starter need help
- In reverse and Drop sound and then wouldn't backup with out gas
- Fluid for power steering 2001 ford expedition
- Rear driver's side brake fluid leak
- Gear wont stick in park, column broke?
- 04' Navigator won't start
- Window Motor replacement....my experience 2000 Expy
- Does anyone make an aftermarket Y-Pipe for the 5.4?
- Battery Light Issue
- HVAC Controls acting up
- Tir rod replace 98 Expedition
