- 2004 Expedition Brake Upgrade:
- CV Joint replacement???
- 2004 Expy Brake Rotor/Pad upgrade:
- crossover tube
- P0171 code and long term fuel trim 1 reads high
- Leaking front axel, anyone know about fixing?
- 2004 Expy left side dropped
- Frustrated! 40 series Flowmaster decreased mpg
- Howdy All
- Anyone here use Dynabeads?
- 2001 Expedition heater problems.
- abs
- brown wire mod on A4WD
- newbie to a ford.
- Parking Brake engaging on its own
- Should I add an additional cooler?
- Waitress, I need 2 more boat drinks-99 Expy Blend Doors Acuators & Plugged Heat Cores
- 2006 EB 5.4 stumbles no codes
- oil sensor location
- 2004 expedition rear heat problems
- 98 Expy vacuum hoses next to the battery
- Help! Anyone know an AFFORDABLE/DEPENDABLE mechanic in the OKC metro?
- Trans Fluid ?
- spark plug and coil on plug questions 03
- Word to the wise about fluid levels in front/rear diff and transfer case...
- Window Motor Slowness.. How slow is yours?
- Front wheel slippage in tight turns
- 2002 EB 2wd 5.4 - what problems to expect
- WTB: 2004 Expedition factory running board set
- need help no oil pressure to one head
