- mileage?!?
- 2001 expedition lock problem
- 2002 Ford Expedition Motor replacement
- 2001 Expedition 5.4L has high LTFTR and P0171 codes
- Looking to buy high mile 1998-2000 Expedition. What to look for?
- Dumb Lube question
- Anti-Seize on Plugs
- Is a timing chain the only culprit?!
- Rear end ABS light maintenence issue
- Secret to a long lasting tranny
- 2000 expy trany issues
- Reinstall 5.4L hints
- Random flash of airbag light.
- Starter Problem "Smoke"
- Compression Test
- Thinking about an engine swap.......
- Engine 9G938BA
- Replaced front wheel bearing, now a different problem
- 2000 Expedition 4.6 Misfire after getting wet
- Broken spark plug removal video - Ford 3 Valve 4.6 5.4 & 6.8
- transmission fluid on 04 expedition
- p0355 after coil pak replacement
- Replace fuel pump without dropping gas tank
- Would you buy 1997 EXP 4x4 1 owner 224k?
- 2001 Expedition fog light replacement
- Gotta misfire on #2. Did lots of tests, can't find cause of misfire, now...
- temp goes up and truck sputters & service engine light
- Winter Issues
- 2001 Lincoln navigator v
- Anyone ever paint the grill emblem?
