- Bad Alternator??
- Seasoned tech meets air bag suspension
- Switched power under center console
- 2003 Expy 6-way driver seat
- Extra Battery in a 2003 Expy
- 2004 Navi Gear Shifter broke
- Turn Signal - Volts but no amps?
- Didn't Lock on Park
- Spark Plug Change 2004 XLT 4.6L
- 2004 Exp. Front brake drag? not siezed caliper, HELP!
- 2000 Expedition downshift clunk
- another stumbling 5.4
- 2003 Expy replacing inside door handle
- 99 A/C working pressure?
- Holiday weekend help? p0305 cyclinder 5 misfire, p0506 idle air below specs
- Vehicle Roadworthiness - What to Check???
- Priming the Oil Pump of a 5.4 Liter
- Coolant Flush for Expedition...
- grinding or scraping noise when i hit a bump
- Dependability of 2005 EB Expedition?
- 03 Bad fuel pump?
- 4x4 lights blinking
- 1999 Expedition 5.4L No Start - No Voltage to Cam Sensor???
- Rear brakes and side mirror question.
- NO BRAKE lights. unless I push down hard
- 03 Exp. EB mirrors will only go down
- High Mount Stoplight Sockets are Burnt
- 06 Expy - tow package's '12v recharge' pin has no voltage
- 2006 Expy. AC stopped working, strange pressure reading.
- 2005 Expedition LTD broken axle
