HD towing package ?
Old Jun 21, 2011 | 12:50 AM
werpknarly's Avatar
werpknarly
HD towing package ?
can i tell from vin# if a used 2005 has the HD towing package ?
Old Jun 21, 2011 | 01:06 AM
werpknarly's Avatar
werpknarly
while im at it.. how do i reorder my garage ?... would rather my 95 transport be more at the bottom than show up on all my post (but dont tell it that, she got over 240K miles)
Old Jun 21, 2011 | 06:55 AM
I fish's Avatar
I fish
you can try this, not sure how far it goes back though, if not you can request a build sheet direct from ford
use this link, except take out the 1FMFK16558LA76512 at the end, and put in the VIN you want info on
http://services.forddirect.fordvehic...FK16558LA76512
Old Jun 21, 2011 | 07:30 AM
alwaysfords41's Avatar
alwaysfords41
I think you can also tell by the number of tubes in the tranny cooler. There was a thread here that had that information in it. 8 tubes vs 12 maybe? I dunno, it was a while ago. If you use the search function it may show up.
Old Jun 21, 2011 | 10:24 AM
r2millers's Avatar
r2millers
The towing pkg comes with a heavy duty tranny cooler, class 4 hitch that bolts to the frame, 7 pin trailer wiring harness on the hitch, limited slip differential, self leveling airbags, heavy duty blinker relay, and a under dash harness for electric brake activators.
Old Jun 21, 2011 | 12:32 PM
alwaysfords41
It does not include LSD or LLS (airbags). Those were both a la carte options. It also has a HD radiator.
Old Jun 21, 2011 | 09:30 PM
werpknarly's Avatar
werpknarly
COOOL TOOL !!! but i couldnt get a 2005 to show up
Old Jun 22, 2011 | 06:19 AM
ScottyDsntKnow's Avatar
ScottyDsntKnow
Dead giveaway is usually the 7 pin trailer plug in the back. Also if you have 3.73 gears you have the tow package. That gear option is H6 on the door sticker IIRC but I could be totally wrong as far as that code goes. I know mine has it and mine has the coils springs. Airbags were just an added feature you could get if you wanted.
Old Jun 22, 2011 | 06:24 AM
alwaysfords41
3.73s do not mean you have towing, it was optional.
Old Jun 22, 2011 | 08:06 AM
werpknarly's Avatar
werpknarly
7 plug
large "7-plug" mean HD towing ?
Old Jun 22, 2011 | 10:22 AM
06SD350's Avatar
06SD350
This is true.I came across that thread a few days ago reading
up on our new to us 04 Expy. if you count your cooler rows as
alwaysfords mentioned,you will know for sure.The trans cooler
is on the passenger side,and the PS cooler is on the drivers.
I Cant recall the title of that thread,but it was very informative.
Old Jun 22, 2011 | 01:51 PM
r2millers's Avatar
r2millers
You might look in the original packet that holds the owners manual and see if the detailed window sticker was ever put in there as many do. It will clearly state on the original sticker, the towing pkg option.
Old Jun 22, 2011 | 04:13 PM
alloro's Avatar
alloro
In the absents of that sticker, this site allows two free queries per day. Just enter your VIN and it will return many details, including axle weights, tire sizes, tow packages, just to name a few.
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder
Old Jun 22, 2011 | 08:57 PM
06SD350's Avatar
06SD350
All anyone needs to do is kneel down a bit and look through
the lower grille for visual confirmation of what we each have.
No need for stickers, manuals...just trust your eyes on this.
It's not hard to spot the cooler, quite simple actually...IMO
Edit:
https://www.ford-trucks.com/forums/1...imensions.html
Old Jun 22, 2011 | 09:05 PM
alloro's Avatar
alloro
Originally Posted by 06SD350
All anyone needs to do is kneel down a bit and look through the lower grille for visual confirmation
That's not always possible. Navigators have a shield that blocks the view you're describing. Then of course there are people that might not be able to kneel down as you suggest, due to some physical issues or age.
