HELP!! P0302 and P0171
Old Jun 21, 2011 | 08:05 PM
MLance12107's Avatar
MLance12107
Hi everyone! I have a 2000 Expedition XLT with 96,000 miles on it. My check engine light just came on, took it to AutoZone and got codes P0302 and P0171. I've read a little bit on here, and will definitely be checking the hose that everyone seems to have found a hole or crack in, I'm curious as to if I should replace all of my O2 sensors as well. My truck idles rough, the RPM's jump when stopped, and it does not like to go over 55mph without my easing off the gas and then staying steady on it. It gets really jumpy between 50 and 55mph. Any advice you all could offer would be greatly appreciated, I don't have $500 to spend on diagnostics or bull**** repairs that most mechanics seem to mention simply because I have a vagina and they expect me to just say "Ok!" Daddy didn't raise no fool....
Old Jun 21, 2011 | 08:48 PM
lv2race's Avatar
lv2race
Don't spend all your money on 02 sensors yet. My Expo started running bad right at 97,000 mi. A new set of spark plugs and an IAC cleaning made it run like new. Do you know when or if the spark plugs were ever changed? Has the IAC been cleaned? How old is the fuel filter? A bad COP will do what you describe at 50-55 mph, a stuttering annoying miss. Inspect your COP boots and wire if you change your plugs, use dielectric grease in the boots and anti-seize on the plug thread. Check these links for possible solutions... OBD-II Trouble Code: P0171 System Too Lean (Bank 1) , OBD-II Trouble Code: P0302 Cylinder 2 Two Misfire Detected
Old Jun 21, 2011 | 09:52 PM
pdqford's Avatar
pdqford
No! Well, at least I wouldn't. Many drivers don't realize that the PCM periodically tests the O2 sensors, first forcing them lean and then rich. The PCM measures the O2 sensors voltage when driven rich and when driven lean to see if they are still in spec. The PCM also measures the time in milliseconds that it takes the O2 sensor to swing from rich to lean and from lean to rich. If the O2 sensor fails the PCM will set a code and turn the SES light on to let you know.
So if the PCM is happy with the O2 sensors performance, so is my wallet.
Old Jun 22, 2011 | 08:57 AM
MLance12107
The truck is new to me, I bought it in November last year and since I've had it, it's only ever had a regular oil change and been in the shop last month to replace a cracked ring when my air ride suspension went out. I pulled the carfax on it and it's only had 1 owner before me, she drove it less than 9,000 miles a year after buying it brand new, it's never had any major work done as far as Carfax is concerned, so I'm assuming all parts are factory original. I drove it this morning, and it drove perfectly! I live in Houston, Tx, so it's been in the high 90's lately..today with the rain it's at 69 degrees, I'm wondering if that has anything to do with it. All of my gauges are reading normally, it's not running hot at all. My hubby would rather put it in the shop, let them pinpoint exactly what's wrong, but I prefer to fix it myself if I can.
Old Jun 22, 2011 | 01:07 PM
lv2race's Avatar
lv2race
Sounds like you got a good Expo, just a little maintenance to bring it back to new. A few things to note, the shop (Ford) will probably charge you $300 - $500 to change just the plugs, which is why you should take the time and do DIY. If you or your hubby are mechanically inclined, it will take you a few hours. Here is what I suggest. Replace these first with Motorcraft parts; Plugs about $3.50 each (verify plug gap), Fuel filter $13 and a few hours of your time. You'll need these to remove the fuel filter available at any auto parts store for a few bucks. K-D Tools 3530 6 Pc. Low Profile Fuel Line Disconnect Set - Toolfetch.com Clear your codes and drive for a while. As I said earlier, check the boots for cracks/splits and replace as necessary. Apply dielectric grease to the boot and anti-seize to the plug thread. Start with the cheap fixes first and if it doesn't fix you, let us know and we'll go from there. If you decide to do the plugs, we can walk you through that too.
Old Jun 22, 2011 | 02:15 PM
r2millers's Avatar
r2millers
JL is right. Start simple and check the egr rubber tee if that's what you were referring to in your original post. When that cracks and starts to leak, you will get "lean" firing codes.
Besides the great suggestions above, especially using anti sieze and dielectric grease on those coil packs, you might think about changing out the tranny fluid and filter. Ford recommends between 35-50k but 100k definitely makes it time. If towing and having a limited slip rear end, also change out the rear end oil with synthetic.
Some inexpensive maintenance here will go a long way to prevent the big ones.
Old Jun 22, 2011 | 02:55 PM
lv2race's Avatar
lv2race
Originally Posted by r2millers
JL is right.
Is your avatar pic at Glen Helen?
Old Jun 22, 2011 | 03:45 PM
r2millers's Avatar
r2millers
JL,
No it's up at Piru Motocross track west of Santa Clarita on the big table back up in the canyon. A GREAT TRACK BECAUSE OF IT'S CHANGES IN ELEVATION. Headed up there on Sat.
daveplot
Jun 20, 2022 11:13 AM
DANA60
Modular V8 (4.6L, 5.4L)
Jan 27, 2017 11:27 AM
superkaz
Modular V10 (6.8l)
Sep 27, 2016 06:06 PM
gibinez
1997 - 2003 F150
Nov 8, 2015 07:38 PM
soto8704
2004 - 2008 F150
Sep 28, 2010 10:21 PM
