Expedition Problems
Old Jun 20, 2011 | 09:25 PM
Big Edd's Avatar
Big Edd
Expedition Problems
My 99 Expedition is flashing PO 171 174 and 430. I have checked PCV elbow and intake gaskets and there are no noticeable vacuum leaks. what gives. I dont want to change out 02 sensors for no reason and the thing runs really well. I have cleaned the mass air sensor and keep on getting these codes. My smog check is coming up and i know that it wont pass with the light on. Thanks in advance for any and all advise.
Old Jun 20, 2011 | 10:30 PM
pdqford's Avatar
pdqford
A vacuum leak a-n-y-w-h-e-r-e in the intake can cause the dreaded P0171/174. It doesn't have to be the famous PCV elbow.
It could be a pin hole leak in the intake path between the MAF and the throttle body.
Is your dipstick fully seated?
I found my P0174 problem was the return line for the PCV replacement air was not fully seated in the valve cover.
Also, check the famous "battery acid eats the vacuum hose" behind/under the battery tray.
The P0430 might just be a by-product of the P0171/174.
Old Jun 21, 2011 | 12:47 AM
alloro's Avatar
alloro
You can get all of these codes when your fuel pressure is low, such as when the fuel filter is plugged, or the fuel pump is starting to go bad.
Old Jun 21, 2011 | 01:05 AM
Big Edd's Avatar
Big Edd
I know i just replaced the fuel filter, and it seems the fuel pressure is good. Its a 15 pass limo and it scoots when you get on it. The cat threshold code is weird though
chadly36
Jun 16, 2012 11:58 AM
JoeG112
Nov 13, 2011 09:27 AM
tarsha29
Feb 15, 2011 06:45 AM
Lobo
Dec 15, 2007 07:13 PM
acastignetti
Mar 8, 2004 06:11 AM
