- looking at 98 XLT, carfax and vin decode are way off
- Interior lights and running board lights won't turn off.
- Whats the highest RPM you have had your EXPY
- Lower ball joint replacement - '97 expedition 2wd
- Brighest Headlight Bulbs
- air bags
- Expedition navigation system question
- 2007 Navigator aftermarket exhaust?
- 2001 Expedition 4.6L Transmission Issue??
- KYB Shocks / Struts
- 2000 EXPY rear discs
- 305/50-20's with stock suspension?
- sensors bad w/o setting code?
- 05 5.4 cold weather engine whine...
- oil change questions...
- Cylinder misfire - 97, 4.6
- Strange problem with stuck horn
- Changed Out Misfiring Spark Plug Now Truck Won't Start
- 99 Expy 5.4: #6 misfire question
- Spark plugs blown out of engine block?
- aftermarket engine heaters
- Motorcraft vs Bosch spark plugs
- Won't idle at startup
- Recommend Battery for 2001 EB
- Need to replace front wheel bearings
- Air suspension conversion
- battery/alternator light
- 98 Expedition injectors
- how to remove expedition rear axle?
- LED License Plate Lights
