September chat thread. 2.0
Old Sep 23, 2009 | 08:41 PM
  #346
ctubutis's Avatar
ctubutis
Originally Posted by Jmeyer1990
Is there any way to get the Pinion oil seal? Or does it come in a set with bearings, washers, and all that other stuff.
I need to do this same thing and have talked with some people about it... Both
people tell me that yes, the pinion shaft seal is replaceable merely by removing
the yoke. The guy in the Parts Dept. at my local Ford dealer doesn't
recommend that I do it, he talks about crush-bearings and tolerances and such
+ the nut that holds the yoke on is officially a single-use item and should be
replaced with a brand-new one (still available from Ford, I seem to recall about
$15 but it's been over a year since I talked to the guy).
Another ex-Ford mechanic I spoke with says the nuts can be re-used and that
the entire process isn't too awful complicated BUT you have to pay special
attention to clearances & tolerances & torque and such. If/when I do this, I'm
gonna make sure that guy is pretty dang close at hand....
Old Sep 23, 2009 | 08:47 PM
  #347
Jmeyer1990's Avatar
Jmeyer1990
I've been reading up on this also. I am pretty sure i can do it, along with a friend of mine, in a matter of a day. The only problem is that I am comfortable doing brakes, minor engine, and minor transmission stuff (replacing transmission lines and that kind of stuff) and also a bit of coolant . BUT I do not have the confidence, nor am I comfortable messing with things that affect the core components of the vehicle.
Old Sep 23, 2009 | 08:50 PM
  #348
greyghost85's Avatar
greyghost85
are you just putting a new seal in?
Old Sep 23, 2009 | 08:52 PM
  #349
Jmeyer1990's Avatar
Jmeyer1990
I need to get a new seal is a better way of saying it.
I left quite a puddle after I got done towing some people earlier today.
Old Sep 23, 2009 | 09:05 PM
  #350
greyghost85
years ago, i got the seal and put it in place, and tightened the nut down, and realized very quickly that the seal wasn't in far enuff. i figured shops had special tools and equip and training to do this procedure. i took her to a nearby shop, and the guy let me watch. all he did was find something cylindrical that fit the approx size of the seal, and hammered it in kinda like a freeze plug.
Old Sep 23, 2009 | 09:16 PM
  #351
ctubutis's Avatar
ctubutis
Smart man!
Rep points for you
Old Sep 23, 2009 | 09:17 PM
  #352
Jmeyer1990's Avatar
Jmeyer1990
Smart man!
Rep points for you
Thanks!
Old Sep 23, 2009 | 09:42 PM
  #353
jeramy's Avatar
jeramy
i used to work at oreilly's loved the job hated my manager. he messed me over one to many times
wouldn't mind haveing another job working for them if the pay would be any where near what i make now.and the employee parts discount was freakin awesome
Old Sep 23, 2009 | 09:44 PM
  #354
jeramy's Avatar
jeramy
pinion seals are a piece of cake. dump trucks hammer them out all the time so i get to change 2 or 3 a month.just make sure you drive it in straight and don't distort it.now axle hub seals are a whole other matter
Old Sep 23, 2009 | 09:58 PM
  #355
Brooksd1991's Avatar
Brooksd1991
Real men have timing chains
Old Sep 23, 2009 | 10:07 PM
  #356
Jmeyer1990's Avatar
Jmeyer1990
Old Sep 23, 2009 | 10:11 PM
  #357
jeramy's Avatar
jeramy
and women are gear driven!!!
Old Sep 23, 2009 | 10:16 PM
  #358
Jmeyer1990's Avatar
Jmeyer1990
Here's some good advice from Autozone:
DIFFERENTIAL OVERHAUL
A differential overhaul is a complex, highly technical, and time-consuming operation, which requires a great many tools, extensive knowledge of the unit and the way it works, and a high degree of mechanical experience and ability. It is highly advisable that the amateur mechanic not attempt any work on the differential unit.
I'll take that advice, and paint my rims instead haha!
Old Sep 23, 2009 | 10:26 PM
  #359
jeramy's Avatar
jeramy
an overhaul yes putting in an external pinion seal no.
Old Sep 23, 2009 | 10:29 PM
  #360
Jmeyer1990's Avatar
Jmeyer1990
Uhh....
  1. Raise and safely support the vehicle with jackstands under the frame rails. Allow the axle to drop to rebound position for working clearance.
  2. Remove the rear wheels and brake drums. No drag must be present on the axle.
  3. Mark the companion flanges and U-joints for correct reinstallation position.
  4. Remove the driveshaft.
  5. Using an inch pound torque wrench and socket on the pinion yoke nut measure the amount of torque needed to maintain differential rotation through several clockwise revolutions. Record the measurement.
  6. Use a suitable tool to hold the companion flange. Remove the pinion nut.
  7. Place a drain pan under the differential, clean the area around the seal, and mark the yoke-to-pinion relation.
  8. Use a 2-jawed puller to remove the pinion.
  9. Remove the seal with a small prybar.
    hello Meineke, goodbye 100 dorra
