460 vs 5.4
Welfare-"I think the best possible social program is a job." Ronald Reagan
<!--[if !supportEmptyParas]--><!--[endif]-->
we know the 5.4 has 365 tq at 3500 rpm and we know the 460 has 245 hp at 4k rpm. so we can use a little math here and figure out their power numbers. at 3500 rpm the 5.4 is going to be making 243 hp and 365 tq. at 4k rpm the 460 is going to be making 245 hp and 350 tq. the 5.4 makes peak tq at 3500, so its going to drop off some by 4k rpm, which means at 4k rpm they are both going to be making the exact same hp and tq.
we know the 460 makes 400 tq at 2200 rpm. we know the 5.4 makes 80% of tq at 1k rpm and 100% of tq at 3500 rpm, so we can say with 100% certainty that at 2200 rpm the 5.4 makes between 80 to 100% of its peak tq. i will be very very very generous and say the 5.4 makes 99% of its tq at 2200 rpm so i dont upset the 5.4 guys(even though its closer to 90%). that means that at 2200 rpm the 460 is making 168 hp and 400 tq. the 5.4 will be making 151 hp and 362 tq even with the grossly inflated numbers. (if i used 90% it would put the 5.4 at 125 hp and 328 tq)
so while the 5.4 has higher peak hp numbers, from idle to 4k rpm it has less hp and tq than the 460. from 4-6k the 5.4 wins hands down. in a drag race the 5.4 will beat the 460 because the 5.4 will stay in its peak power band where it does make more power than the 460. but if i remember correctly, driving a truck isnt a drag race(thats the argument 5.4 guys use against the tundra). its about which truck makes more power in a useable power range. if you bring up the tundra, 5.4 guys say its not a drag race. but if you bring up a 460, they start talking peak hp and higher rpms.
However I disagree with you on the V-10 vs 460, in stock form the V-10 is better, but when you add a good set of heads and a cam it's 460 all the way not even close to even anymore.
i dont have the numbers on hand for all the engines, but i just did this comparison a couple of weeks ago for a 3v 4.6 truck vs a 5.0 truck and the numbers are fresh in my mind. the 4.6 has 292 hp and 320 tq and the 5.0 had 185 hp and 270 tq. even though they are in the same class you would have to be crazy to think the stock 5.0 would outrun or outpull the 4.6 if they were in the same truck. but does that make the 4.6 a better engine? in stock form the 4.6's heads flow a LOT BETTER than a set of gt-40 heads for the 5.0 and the 4.6 has a .070 higher lift cam than the 5.0. and thats not even getting into fuel supply, intakes and electronics, etc. so when comparing a stock 4.6 vs a stock 5.0 the 4.6 already comes with performance upgrades from the factory. its fair because its stock vs stock and lots of people leave their engines stock, but in a way its not fair because one of them is already factory "built". i just think if you want a fair comparison of an engines capability then make it a level playing field and have all things be equal.
take a 92 5.0 out of the mustang and compare it to a 92 5.0 out of the truck. same year, same engine, same technology, etc, but the mustang had 225 hp and 300 tq while the truck had 185 hp and 270 tq. nothing more than an intake change and better exhaust bumped it up 40 hp and 30 tq. give it a set of gt-40 heads and the same lift cam as the 4.6 and its going to be putting out the same or more power than the 4.6.
so while these engine vs engine comparisons are fun, they dont really tell the whole story. whether it be 5.4 vs 5.8, 460 vs v10, etc, stock vs stock doesnt always tell an engines true capabilities unless you actually leave the engine stock.
Comparing my previous 97 F350 460 to my 07 F350 V-10
There really is no comparison the V-10 Is much better in every way.
Towing Power wise : The 5.4 Is much closer to the 460 but the 5.4 gets better mileage. sorry but it's true.
I Think the new 5.4 3v with the 6speed trans will out tow all previous gas offering's including the 460/454 or whatever.
The New 3v V-10 flat out Rocks and is in a league of it's own.
i cant speak for everyone, just myself, but when im towing i like to take my time. i shift at around 2k-2500 rpm when i pull out and keep it below 2500 rpm when im driving. yeah, the 5.4 makes more power than the 460 from 4k rpm to redline, but thats of no use to me until i start drag racing the truck and trailer instead of the car thats inside of the trailer. like i said earlier, i can drive 675 miles from my house to florida and for about 674 of those miles i am going to be between 2k-2500 rpm. at those rpms the 460 is worlds apart from the 5.4 and virtually dead even with the 3v v10.
the 5.4 will do great on light to intermediate weight trailers. on flat land or small hills it will do just as good as a 460 or a diesel. but when you start hooking big time weight to it, and im talking 15-20k lb trailers, thats where you see what kind of power your engine really has. ive had those kinds of weights on a 7.3 and 7.5 many times and dont even think twice about it. i did 15k lbs one time with my 5.4 and i wont ever do it again. thats irrelevant in an f150 forum, but very relevant in a 5.4 vs 460 debate.
To add to the discussions........
I agree the V10 is one hot engine, It is a great alternative to a diesel for those of us that hate diesels.
The 5.4 is a great engine for the F150 considering its size, towing and, load limitations.
The 4.6 is an ok engine for the F150 if you never plan on max tow or max cargo
The V10 is only in the F250s +
The diesels are great if you tow or haul long distances 75% of the time. The worst thing to do to a diesel is shut it down.
The 460, atleast the one I have is AWESOME!!!! Its power starts at idle and yes does peak lower than the 5.4, but, if you can tie it to it, it will move it. When I tow'd my 10k camper, i would set the cruise and it ran 60mph @ 1800rpm all day, well atleast between gas stops.
As for the comment "the 5.4 will outrun the 460"..... Well... I need to be tactful...... no way!!!! I may have to stop and get gas but I'll pass you at the next one. My 460 is definatly quicker than my 5.4
I know this will stir up the nest
I can almost put money on it that the 09 f150 with the 5.4 is quieter at 4000rpm than the 460 is at 2000rpm.
I know i would rather be in my f150 all day long with the 5.4 over the 460 so to say it's the better tow engine is wrong. Yes the 460 may have more TQ at lower RPM's but i couldn't careless when i can change down a gear and rev a little higher and still be smoother, quieter, More comfortable and more economical as i do it.
all people ever talk about with trucks is hp this and hp that, but hp doesnt mean crap in anything other than racing. hp belongs in the mustang forum. your 5.4 on E85 has more hp than our international big rig wrecker, but would you be willing to have a pull off with them? my 5.4 has 100 more hp at 4k rpm than my 7.3 has at 2k rpm, but which tows better, my 5.4 at 4k rpm or my 7.3 at 2k rpm? i could put a rev limiter at 2k on my 7.3 and outpull my 5.4 all day long.
quiter doesnt make it a better engine and quietness is based on what kind of exhaust you run. how many 5.4 guys have a nice set of flowmasters or other aftermarket exhaust on their trucks? i dare say they arent too quiet. many of us prefer louder trucks, which is why aftermarket exhaust companys are in business in the first place.
like i said earlier as well, whether you like high or low rpms is a personal preference when youre towing the kind of weights you would with an f150. but we arent comparing f150 vs f350 here. this is engine vs engine alone. the benefits of the 460 arent as obvious until you get up in bigger weights or on big hills. i would tow 20k lbs with a stock 7.3 or 7.5(or v10) any day of the week anywhere you wanted me to pull it. i doubt anyone would say the same about a 5.4.
im not arguing with you over which would be a better engine in an f150. theres a reason why the 460 and 7.3 didnt come in an f150. its over kill for what youre going to be towing with it. but theres also a reason why the 5.4 doesnt come in an f450/550 and the 460 and 7.3 did.
I think this will as the only figures i can find for a 460 doing 0-60 are in f150's and they range from 9.2-9.9 secs and i found a highly modded forced induction 460 f150 and that done 0-60 in 6 secs. The 09 lariat 4x4 5.4 is rated any anything from 8.0-8.6 0-60 and i take it yours is an f250 which i guess would be even slower than the f150 with the 460?
