Sponsored by: Real Truck
Lets see them CB's
Old Jun 16, 2009 | 10:35 AM
  #136
jstnromero's Avatar
jstnromero
Originally Posted by Sarge261
Did you guys put anything under the magnet to keep the rust ring in check.
I have heard a womans nylon works really well at keeping the scratches down and it is not too thick to impact the magnets strength. Just my .02
Old Jun 16, 2009 | 09:41 PM
  #137
mstiles19's Avatar
mstiles19
haha i wish i had thought about doing something like this before i mounted my dual whips on my tool box i had a mag mount and it scratched the heck out of my roof. also the sides of my drivers side cab when it would get knocked off.
Old Jun 17, 2009 | 09:59 AM
  #138
Sarge261's Avatar
Sarge261
Thanks guys.
I will look into it once the antenna gets here.
Sarge
Old Jun 17, 2009 | 11:42 AM
  #139
Snorcr31's Avatar
Snorcr31
I decided to build a box that would fill the gap in between the dash and center console.
Old Jun 17, 2009 | 12:32 PM
  #140
Boo_Daddy's Avatar
Boo_Daddy
Looks good! If my truck wasnt a stick, I would do something similar.
Old Jun 17, 2009 | 01:52 PM
  #141
myblkex's Avatar
myblkex
I dig the diamond plate
Looks pretty sweet !
Old Jun 17, 2009 | 04:34 PM
  #142
tbaker00's Avatar
tbaker00
Sorry to steal the thread but it will be for just a second. So I found a CB today digging through some stuff of mine and decided what the hay, and installed it. It had everything i needed except I couldnt find the actual antenna. Has the wiring and a magnet mount but no antenna. If i just buy a firestik from clays will that screw right in to the magnet mount?
Old Jun 18, 2009 | 01:14 PM
  #143
conifers4's Avatar
conifers4
Doubtful, there usually not compatiable.
Old Jun 18, 2009 | 01:38 PM
  #144
BillyBob69's Avatar
BillyBob69
Check with your local radio shack....you should be able to get a replacement mast for about $10. Just make sure it is for CB's. Different lengths are for different frequencies.
Old Feb 23, 2010 | 08:46 PM
  #145
jstglockem's Avatar
jstglockem
CB Raido Install 2004 EX
This is the first time I have tried to post pics..So if I screw it up please move it. I took out my cup holders along with the metal frame that the cup holders mount in. I installed a Galaxy 919 which is a decent size radio in a small whole. It has an output of 30 watts with out and amp. I also took out that weird thing that has a hook, I imagine its for holding a bag. Bag of what, I am not sure I then put a 8 watt CB speaker. I put a Wilson 1000 antenna on my roof. I did not want to drill a hole so I drilled a hole in one of the racks that is on top of the roof and ran the antenna wire down under the rails through the back window and then fished it to the on the passengers side A pillar I think its called. I ran the power directly to the batter and the speaker to the fuse box. With the squelch control I hear absolutely no engine noise through the speaker.
Old Feb 24, 2010 | 02:18 AM
  #146
Surge08's Avatar
Surge08
Originally Posted by f-250 ford
Here is my small antenna will get a pic of the radio later
Do you get Nascar and NFL with that thing?
Old Feb 25, 2010 | 08:13 AM
  #147
Sarge261's Avatar
Sarge261
I have a question you all can help me out with...I hope.
I have a wilson 500 antenna, its a mag mount, I ran the wire through the 3rd brake light. I also have my Sirius antenna running the same way, my question is:
I get a lot of feed back through the stereo when I key the mike, wether the stereo is on or off it doesnt matter. Is it because the antennas are so close?
Is there anything I can do to prevent this?
I also think I bought a bum CB because every once and an while it will just turn on by itself and make this loud screeching noise...the on off **** is off and it does this.
When I get some extra scratch I am gonna buy one from Clays, whats a good CB that has a WX frequency?
The stereo in the truck is a Kenwood DNX 5120
Thanks for all the help,
Sarge
Old Feb 25, 2010 | 09:29 AM
  #148
flamebuster's Avatar
flamebuster
Cobra 29 ST is a excellent radio and has the weather channels along with priority channels and ant. calibration.
Runing antenna cables parallel to other can cause cross feeding, try seperating the wires and see if this elimanates your problems. Also I would check the grounding side of your ant. cable connections. It is the braided or metal jacket just under the rubber coating, It should be in contact with the metal connector. Also the copper wire should not touch the connector.
Old Feb 25, 2010 | 11:27 AM
  #149
Sarge261's Avatar
Sarge261
I will try that. the antenna is brand new just bought it not too long ago from clays.
Sarge
rpenterics
Jan 1, 2009 05:03 PM
86sujaguar
Apr 10, 2008 10:00 PM
rgthoma
Aug 24, 2006 01:00 PM
Bruker
General Automotive Discussion
Oct 13, 2005 06:18 PM
taxabel
66
Oct 10, 2004 12:59 AM
