replace radio antenna
Old Apr 10, 2008 | 02:49 PM
86sujaguar's Avatar
86sujaguar
I have a front fender mounted antenna and want to replace the antenna because it is broken, not sure how, anyone have any information on the how to replace the antenna?
Thanks
Old Apr 10, 2008 | 10:00 PM
operator414's Avatar
operator414
You can remove the plastic cover with a screwdriver, flat screwdriver, just pry a little and it will pop off, then there is 3 phillips head screws hiding under it, I had mine apart the other day because the whole thing was loose, if the mast is just broke you can unscrew it and replace it from your local parts store....
ojh
Mar 1, 2017 04:36 PM
'78F250351m
2009 - 2014 F150
Jun 26, 2012 03:38 PM
rpenterics
Jan 1, 2009 05:03 PM
kilog55
Apr 18, 2007 01:38 PM
Kep4
Aug 27, 2006 09:34 AM
