Sponsored by: Real Truck
Lets see them CB's
Old Feb 18, 2009 | 09:29 AM
pbr man's Avatar
pbr man
Here is mine along with my brake controller.
https://www.ford-trucks.com/user_gal...112209.520.390
Old Feb 18, 2009 | 09:34 AM
threeonebravo's Avatar
threeonebravo
there's no drilling on the dash, it's just 3M adhesive, which has worked surprisingly well so far for 2 years now.
Last edited by threeonebravo; Feb 18, 2009 at 09:36 AM. Reason: comment on adhesive
Old Feb 18, 2009 | 09:37 AM
threeonebravo
nice Glock.
Old Feb 18, 2009 | 09:56 AM
Jock's Avatar
Jock
Pictures of my 2005 & 2008. These are VHF not CB. I have done a few in-dash CB installs on the 2005 to 2007's. The install in the 2008 is not convenient, done that way to keep my wife happy.
Old Feb 18, 2009 | 10:03 AM
Jock's Avatar
Jock
Roof mounts are easy to do, usually you can get away with the factory bracket. Insurance companies tend to frown on them due to head injuries in accidents.
Old Feb 18, 2009 | 10:33 AM
08XL2fitty's Avatar
08XL2fitty
I like that on the 2008. That would be a great spot on my truck.
All tho like you said it would be tricky to change channels..
Old Feb 18, 2009 | 10:41 AM
Citypol86's Avatar
Citypol86
Roof mounts are easy to do, usually you can get away with the factory bracket...
I have an '05 sans overhead console. If I pull the roof liner, are the mounting brackets there anyway?
Thanks,
Later...
Brewster...
Old Feb 18, 2009 | 11:10 AM
Jock's Avatar
Jock
You don't have to pull the headliner. If you pull the front of it down just a bit you will feel a ridge about 11/2" wide. you can screw thru the headliner in to that ridge to mount your bracket. Depending on the radio configuration it may be difficult to tip it down enough to see the display well. Wires can be tucked underneath the headliner and run down the pillar.
Hope this helps
Old Feb 18, 2009 | 06:11 PM
Citypol86's Avatar
Citypol86
Hope this helps
I was hoping to build a console that runs front to back, about 12-18" long. Are there provisions behind the liner for something like that? As the next alternative, are there any provisions to build a console left to right? They used to make them [decades ago] that fit above the sun visors.
TIA
Later...
Brewster...
Old Feb 18, 2009 | 06:19 PM
TheBigBee's Avatar
TheBigBee
I stumbled across a company that still makes those visor consoles I will see if i can back track and find it.
Old Feb 18, 2009 | 06:52 PM
TheBigBee's Avatar
TheBigBee
Here it is. It should fit your 2005. They look pretty good. I had this brand in my last truck.
Vertically Driven Shelf-It Overhead Storage Shelf For 2000–'05 Ford F-250/350 Super Duty, Model# SH2205 | Storage | Northern Tool + Equipment
Old Feb 18, 2009 | 07:13 PM
420CREW's Avatar
420CREW
Old Feb 18, 2009 | 07:36 PM
  #28
Citypol86's Avatar
Citypol86
So do I but did you see the price tag? WOW! Also, there's no room for the MDT/Laptop. I have it mounted high and swiveling now but I can't get to where the radio is in the picture.
Thanks for the ideas though, I can always incorporate something into the F650 dash panel.
Later...
Brewster...
Old Feb 18, 2009 | 08:54 PM
  #29
Furian's Avatar
Furian
You Keep What You Kill
Later...
Brewster...
Yes, I like the F350 dash panel much better!
Old Feb 18, 2009 | 10:06 PM
  #30
Citypol86's Avatar
Citypol86
Originally Posted by TheBigBee
I think I'm gonna go with this one. I don't think the radio will fit in it but I can drill into it to mount it. I can ALWAYS use the extra storage space also.
THANKS!!!
Later...
Brewster...
