It may not be called that, but there is some provision for it to see what the line pressures etc are and make the appropriate shift strategy. I have read about it in my manual for when you disconnect the batteries. Jody mentioned it during my live tuning. Seems to make sense to me too. It looks at every shift, line pressures etc. The PCM looks at slipping, solenoids, etc. There has to be an IF-THEN algorythmn there. Does that make any sense?
I keep reading how the PCM won't "learn" shift strategies, but I also keep hearing about how the chip adjusts the line pressure for the shifts. So I do see your point. There has to be some kind of communication going on there to affect line pressure. The IF-THEN part makes sense, because I noticed it holding a gear longer under moderate acceleration instead of down shifting and trying to take off. (Life is easier in the country where you can stop and start in the middle of a road with a posted 55 mph speed limit and no other cars even visible)
Originally Posted by fxstbchopper
Mike is right Chris I did not think it had done anything for my truck but the more I drove it and made it draw out the shifts the better it got.
I did notice a difference in just the short trip, so I'm very pleased. I know things will change once the chip is installed, but as I mentioned, we've ridden in Joe's truck with the TransGo & Tony's tunes, so I don't think we're in for any big surprises.
Originally Posted by Izzy351
Yeah, the 3-4 shift is sucky. Wish it was as crisp as the first two!
Don't know how the wife's truck will turn out, but I can make MY 3-4 shift as soft or as firm as I want it. You should have gotten an extra pedal and you wouldn't have to deal with all these issues.
Let me make sure I have this straight, we are talking about the shift into OD right? Just think about that for a moment. Myself, if I haven't smoked the other vehicle by then, OD ain't helping because wind resistance is really building by then. Just my experience, what are you guys seeing?
Well I don't necessarily look at it as a race thing either(my truck with out my chip is lucky to out run the paper boy on his bicycle)I like for the trans to have a firm shift through all the gears the regular cab I had before this truck had a shift kit in it I don't know what brand as I did not install it but it would shift fast and firm in all the gears. I have found though that if I get on the truck it does shift like I want it to into 4th. I just don't go around getting on the throttle all the time (of course that will change when I get my chip back too).
Well, I was wrong kind of, from the manual:
NOTE: All gasoline vehicles will have new adaptive shift strategies. Whenever the vehicle's battery has been disconnected for any type of service or repair, the strategy parameters stored in the keep alive memory (KAM) will be lost. The strategy will start to relearn once the battery is reconnected and the vehicle is driven. This is a temporary condition and will return to normal operating condition once the powertrain control module (PCM) relearns all the parameters from the driving conditions. There is no set time frame for this process. If a concern is present during downshifts or converter clutch apply, it is not the fault of the shift strategy and will require diagnosis as outlined in the workshop manual.
Now it says all gasoline engines. We have a KAM in our trucks. Just what is being kept alive in that memory then? Why do we even need a KAM if the PCM is stupid? Jody told me it needs to learn. He knows more about this than me. I believe him until someone can tell me what our KAM is storing.
I am willing to bet it is mostly, if not all 4R100 data as these are digitally controlled trannies.
Yeah, it's not nearly as big of an issue as 1-2 & 2-3, but I just wish it was more firm.
I drilled my calibration plate to the '6 cyl/low stall diesel' specs because the slightly 'tighter' aftermarket billet triple disc TC. The hole for the 2-3 shift was smaller that the others. I wish I had 'opened it up' to the same size. 3rd is not quite as firm as I'd like it to be. 3-OD has a quick, firm shift like 1-2. I do however have all the pump mods in there along with upgraded clutch packs from my rebuild. The TC lock up kit, I installed in the pump, makes its engagement feel like another firm shift.
Damn Roland, seems none of us can get it right. Actually, I have no complaints about how mine shifts. It shifts better than it has since I got the truck. Done. Well, until diode pukes.
the softer 3-4 shift is probably due to the pcm's strategy with torque converter application during that shift. the e4od's use an on-off strategy during 3-4 while the 4r100 uses a pulsed strategy. both ways suck causing a softer shift.
how does the overall shifts compare to mine? i have never ridden in a transgo kit truck. YouTube - 0-100+ mph
After doing a little reading down in the OBS forum, racer x did some testing on The Cure all the E4OD guys like. If I would have noticed this before, I would have spent my money there.
Dangit, I posted an update to this earlier and it is nowhere to be found. Let me dig it up.
Here we go. Take from this what you will. There seems to be some adaptive strategy going on here:
<title>Diesel Powertrain Control Software</title><link href="V1C%7Eus%7Een%7Efile=V1Cstyle.htm%7Egen%7Ere f.htm" type="text/css" rel="stylesheet">Powertrain Control Module
The center of the Electronic EC system is a microprocessor called the Powertrain Control Module (PCM). The PCM has a 104-pin electrical connector. The PCM receives input from sensors and other electronic components (switches, relays, etc.) and places this information in RAM or Keep Alive RAM. Based on information programmed into its memory (ROM), the PCM generates output signals to control various relays, solenoids and actuators.
Keep Alive Random Access Memory (RAM) The PCM stores information in Keep Alive RAM (a memory integrated circuit chip) about vehicle operating conditions, and then uses this information to compensate for component variability. Keep Alive RAM remains powered when the vehicle key is off so that this information is not lost.
