Calibration Code to to EEC Program Code
Old Jun 22, 2022 | 03:19 PM
  #31
rla2005's Avatar
rla2005
The problem is the F150 5L trucks usually came with a 4R70W transmission by 1996, but that is not 100% certain. Check the Trans Code listed on the sticker located on the driver side b-pillar. Trans Code U is a 4R70W. Trans Code E is an E4OD. The computers are not interchangeable because of the transmission differences. If you do have the 4R70W then your donor compatibility goes way down.
Old Jun 22, 2022 | 04:49 PM
  #32
torq'ta 5 8's Avatar
torq'ta 5 8
Cardone says this one-->Cardone Engine Control Module - Remanufactured 78-6411 | O'Reilly Auto
Old Jun 22, 2022 | 06:36 PM
  #33
subford's Avatar
subford
For calibration code of: 6-54E-R10
Ford part number: F6TZ 12A650-MC
The number on the unit: F6TF 12A650-MC
Old Jun 22, 2022 | 07:28 PM
  #34
Bryce'74's Avatar
Bryce'74
5th Gear
Thank you so very much! Do you happen to know what the color chart says re: Axle = 19? This is such a help. Thank you again.
Old Jun 22, 2022 | 07:34 PM
  #35
torq'ta 5 8
Peg leg, 3.55's
Old Jun 22, 2022 | 07:40 PM
  #36
Bryce'74's Avatar
Bryce'74
5th Gear
Thank you so much. Y'all are amazing! I love my truck so much and have over $30K invested in her over the past twelve years. She is stock and very clean. I refuse to get a new truck, against everyone else's advice. They just don't understand. It would be such shame to lose her over a $300 part. I'm going to try to post a picture of the lady y'all are trying to help me save. Thank you, again.
At Home
I40 Arizona-3rd trip cross country
Old Jun 22, 2022 | 09:36 PM
  #37
Bryce'74's Avatar
Bryce'74
5th Gear
Yes, it is Trans Code U. I believe the last computer came programmed E40D. It had a revolving misfire on four cylinders and the trans was acting like it thought it was a manual. Would long pause between gears, would rev up & slam into the next one. Thank you so much for the info.
Old Oct 13, 2022 | 08:04 PM
  #38
Pdstark's Avatar
Pdstark
4wd Low
Forgive me for hijacking this post but the could you decipher calibration code 2-51E-R00 please?
Old Oct 13, 2022 | 08:42 PM
  #39
subford's Avatar
subford
Pdstark:
Can you tell me what engine you have and what year truck?
Old Oct 13, 2022 | 08:47 PM
  #40
Pdstark's Avatar
Pdstark
4wd Low
It’s a 1992 with the 4.9L
Old Oct 13, 2022 | 09:02 PM
  #41
subford's Avatar
subford
Pdstark:
For calibration code 2-51E-R00 = Parts list 175.
Parts list 175 says when the truck was new it had F2TZ-12A650-ATB for the PCM
It also says r/b for it is F3TZ-12A650-TA.
So take your pick.
Old Oct 13, 2022 | 09:22 PM
  #42
Pdstark's Avatar
Pdstark
4wd Low
Many thanks subford!
Old Oct 14, 2022 | 07:42 AM
  #43
AuroraGirl's Avatar
AuroraGirl
i would take that 1993, i recall reading a TSB which was fixed by the release of a PCM from around that time, but couldnt say with 100% certainty if it was that. but it sounds familar.
Old Oct 15, 2022 | 10:26 AM
  #44
geo455's Avatar
geo455
I use a 93 Bronco PCM in my 94 F150 with CA emissions. Both 5.8L with E4OD. I originally used it to test but stuck with it when I determined that the original PCM was bad.
Old Oct 16, 2022 | 11:07 AM
  #45
DPDISXR4Ti's Avatar
DPDISXR4Ti
As long as the donor has the same engine and transmission, most any '87 - '95 PCM will work. I'm pretty sure it doesn't even matter if it's a later black ICM (TFI). I say that having run a PCM from a '95 in my '91 4.9 F-150.
