Offroad & 4x4
Cheetos Crew Build
Old Feb 8, 2011 | 06:46 PM
  #661
crazyredneckanyhow's Avatar
crazyredneckanyhow
Ive got a craftsman 1/2 drive. It just wont grip the bits anymore. Im gonna try what steve told me about grinding 3 flat spots into the bit and seeing it thatll work. if not ima go buy a normal drill.
Old Feb 13, 2011 | 08:45 PM
  #662
crazyredneckanyhow
progress bishes Not much but the spring hangers are on for good and i got everything for the rear painted and ready to go in. Just need to put the gears back in and put my 1410 yoke on.
Old Feb 13, 2011 | 08:48 PM
  #663
joe f350's Avatar
joe f350
i give that 3 weeks at most
Old Feb 13, 2011 | 09:21 PM
  #664
fatdan460's Avatar
fatdan460
^^^^^Bwahahahahaha, truff
what did you paint the axle housing with? i'm going to try to make the crap i buy look at least semi decent on the new truck. no sense in leaving the axles all cruddy looking.
Old Feb 13, 2011 | 10:06 PM
  #665
crazyredneckanyhow
Frame is brush painted with black rustoleum. Everything else is spray bombed with rustoleum other than the pinion gaurd and diff cover. They are painted with OD green krylon.
Old Feb 13, 2011 | 10:09 PM
  #666
fatdan460's Avatar
fatdan460
what kind of prep? just wire wheel the **** out of it and wipe it down? or did you have primer anything? me and spray paint have disagreements on stuff, mainly sticking to frames.
Old Feb 13, 2011 | 10:16 PM
  #667
crazyredneckanyhow
On both i just wired wheeled the hell out of it and cleaned it all with brake cleaner. I also had the garage about 80 so it all dried pretty quick.
Old Feb 14, 2011 | 08:07 AM
  #668
captain p4's Avatar
captain p4
DAN, POR15 everything since you live in salt land. You'll thank me later.
Until you have to remove it for some reason, then you'll hate me
Old Feb 14, 2011 | 09:12 AM
  #669
kjett's Avatar
kjett
Paul, I hate you for even mentioning that evil stuff!!! But I have to admit it will stick to anything.
Old Feb 14, 2011 | 11:33 AM
  #670
fatdan460's Avatar
fatdan460
the 250 was done up decent at one point in time. the frame was painted, but its starting to peel off. when i ditch the bed i'll try to clean it up as best as possible and coat it in something. do they carry that por 15 crap at the chain parts stores or do you have to order it?
Old Feb 14, 2011 | 11:48 AM
  #671
alpha/omega's Avatar
alpha/omega
GRRRRRRR!
SUPATRUF!
Ive never seen it in a parts store around here. I think Summit carries it.
Old Feb 14, 2011 | 04:53 PM
  #672
captain p4's Avatar
captain p4
order it beootchhhhh!
Old Feb 14, 2011 | 05:10 PM
  #673
crazyredneckanyhow
Anyone ever use any of those lube locker diff cover gaskets? Seems they might be good but at like $40 each shipped seems kinda pricey. Especially when i need two of them for the 14b.
Old Feb 14, 2011 | 05:22 PM
  #674
alpha/omega
black RTV. $5 a tube
Old Feb 14, 2011 | 05:25 PM
  #675
crazyredneckanyhow
Kinda figured Paul would be the one to comment on cheap black tube. :flipoff:
