Cool Tips and tricks
Old Jan 30, 2016 | 02:46 AM
  #376
petemcl's Avatar
petemcl
Originally Posted by flat48f2
If you are not able to get two fingers on the nut and washer use contact cement to stick the nut to your finger and the washer to the nut.
Contact cement like you use on weatherstrips, right? Not super glue ! I have visions of some poor guy with his hand stuck to a nut up inside the door and his wife has to call 911 to get him loose.
Old Mar 13, 2016 | 05:43 PM
  #377
1951 f1 two's Avatar
1951 f1 two
Great thread, took a while to read thru. My tip is back to post on bending sheet metal. There's a tool that sheet metal workers use to make 1/4, 1/2 and 3/4 bends in metal. Tool has measurements built in. Two sizes are 4" and 8" wide and work like pliers. Will try find picture.
Old Mar 13, 2016 | 05:53 PM
  #378
1951 f1 two
Name:  sheetmetal bender.jpg
Size:  1.3 KB Here's the tool.
Old Mar 13, 2016 | 06:01 PM
  #379
petemcl's Avatar
petemcl
I just bought one of these inexpensive sheet metal benders at HF. It looks like it would work on 18 gauge or less. Not sure about 16 gauge?
Old Mar 13, 2016 | 07:19 PM
  #380
76-5.0's Avatar
76-5.0
We called that tool a "folding bar" in the a/c business. They tend to spread and bend if used on the thicker stuff.
Old Mar 16, 2016 | 11:48 AM
  #381
Telestar's Avatar
Telestar
Cool trick!
Old Apr 26, 2016 | 07:41 PM
  #382
huffman1953's Avatar
huffman1953
Has anyone used a hood prop on a 48/52 ford f1. I want to elimate hood springs
Old Apr 28, 2016 | 09:23 AM
  #383
raytasch's Avatar
raytasch
Believe Nothing
This works for me. A 27" X 1" inch piece of PVC painted black. I like to keep things simple. I am sure a couple struts could be used as well.
Old May 30, 2016 | 01:15 PM
  #384
petemcl's Avatar
petemcl
Somewhere on this forum I think that I posted a lesson that I learned the hard way (is there any other way with these old trucks?) about installing inner wheel seals on a CPP disc brake conversion kit. But I can't find it now.
When I went to replace the pinion seal on an 8.8" Ford rear axle that I just reconditioned I realized that the pinion seal looked very similar to the previously experienced inner wheel grease seals and that the pinion opening was not chamfered which make installing the seal without damage difficult.
So I chamfered the lip of the opening slightly and the seal went in without damage. Here are some pictures as I know everyone likes pictures.
Square inner lip makes seal installation difficult
I used a Dremel tool to just slightly chamfer the edge.
Seal before installation.
I didn't have nice Kent Moore pinion seal installer so I bought a cheap 2 7/16" drive for $15 which fit perfectly.
Pinion seal fully seated.
Old May 30, 2016 | 02:01 PM
  #385
JimG1098's Avatar
JimG1098
Nicely done
Old May 30, 2016 | 03:22 PM
  #386
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
What did you do about tightening the pinion nut? Count the turns when you took it off, tourque it,???
Old May 30, 2016 | 07:10 PM
  #387
petemcl's Avatar
petemcl
This axle has a solid shim for preload vs a collapsible collar. I'm going to check it with the old school method of white lead to make sure that the pattern is correct. I have a Ford bulletin on this if anyone is interested.
Old Jun 3, 2016 | 01:02 PM
  #388
ALBUQ F-1's Avatar
ALBUQ F-1
Here's a simple tool for locking the flywheel for torque'ing the flywheel bolts or pressure plate bolts. This is for a flat V8 but a similar trick would work on almost any engine.
I took a piece of 1-1/4 x 1-1/4 x 1/8" angle iron and drilled a hole about 2" from the end. Because I was using a piece of scrap angle iron, I actually had to drill two holes, each 2" from the end (I judged that to be easier than sawing the piece to 4"). A short 7/16" bolt clamps it to one of the well-supported block-to-bellhousing holes at the top of the block. The piece tips down so that it engages the starter ring gear teeth at no more than a 45-deg angle. Rotate to tighten FW bolts.
Old Jun 11, 2016 | 10:18 PM
  #389
mike.rogers's Avatar
mike.rogers
Well I was fighting getting my stick shift back in my NP435 transmission. I tried pushing down with my hands, screwdrivers and twisting but with no luck. This went on for an hour. I couldn't hold it down and twist the ball in place. Well finally I set my channellocks over the cap. I push down on both ends of the channellocks, twisted and wallah it was in. The rubber on the handles grip the cap just enough to hold it and twist it. The dang thing was in place in less than two seconds. I mean I faught this thing for a whole hour then boom it was in. here is a pic of how I placed the pliers. Don't know if anyone else ever done this, but man it works and it works good.
Old Jun 12, 2016 | 04:19 PM
  #390
56panelford's Avatar
56panelford
