6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Trucks been flagged
Old Sep 4, 2007 | 11:00 PM
  #136
biz4two's Avatar
biz4two
Arrow
Originally Posted by Pocket
The PCM doesn't think. It doesn't magically decide that a regen is needed. Sensors in the DPF tell the PCM when a regen is necessary.
Exactly my point. So...what happens when the sensors are missing because the DPF has been removed and the PCM has not been flashed? The 6.4L PSD is going to have issues...
biz
Old Sep 4, 2007 | 11:05 PM
  #137
powerstroked162's Avatar
powerstroked162
The sensors are in place still, as far as the computer knows, the DPF is clean as a whistle and needs no regen to clean it out.
Cowboy Steve
Old Sep 4, 2007 | 11:13 PM
  #138
origcharger's Avatar
origcharger
Cowboy Steve
I've read others have thought the same and it hasn't turned out for them to be quite as simple as that.
Old Sep 4, 2007 | 11:17 PM
  #139
powerstroked162
Well we'll see wont we. No problems yet other then the loss of my powertrain warranty, haha
Cowboy Steve
Old Sep 4, 2007 | 11:18 PM
  #140
herman391's Avatar
herman391
And the blown head gaskets, but those aren't necessarily (or at all) caused by the DPF delete.
Old Sep 4, 2007 | 11:23 PM
  #141
powerstroked162
No problems yet with tripped codes due to the removal of the emissions equipment. Everybodies a critic, lol
Cowboy Steve
Old Sep 4, 2007 | 11:27 PM
  #142
Pocket's Avatar
Pocket
biz
I never said anything about removing sensors.
  #143
biz4two's Avatar
biz4two
Arrow
Cowboy Steve
Very interesting! Good to know...
But aren't there sensors down at the DPF area? If that has been removed, then where are the sensors installed?
See...this is where pictures would really come in handy. To see the DPF removed...and the new aftermarket installed. Having the sensors still in place...etc...etc...etc.
biz
Old Sep 4, 2007 | 11:33 PM
  #144
powerstroked162
When I orginally posted about my Dpf removal many asked were the BP sensors where at or if I deleted them. Like I said then, I had the exhaust shop remove the sensors from the dpf and install them into the new DPF delete pipe in the factory location as to help maintain geometry, wether it mattered or not I didnt want to chance it. With the sensors in the new delete pipe and the dpf gone I have had no issues whatsoever that would result directly from the removal of the DPF.
Cowboy Steve
Old Sep 5, 2007 | 12:14 AM
  #145
biz4two's Avatar
biz4two
Arrow
powerstroked162 -- Oh...Ok. Never did read your original post on the DPF removal. Certainly makes sense...and explains why you have not had any check engine issues.
biz
Old Sep 5, 2007 | 12:17 AM
  #146
biz4two's Avatar
biz4two
Arrow
Right. However some folks when removing the DPF would remove the sensors to...and not realize that the PCM needs those sensors to "believe" the DPF is still installed. Got to "trick" the PCM...if you will.
That was my intent with my previous post.
biz
Old Sep 5, 2007 | 07:13 AM
  #147
GMtoFord's Avatar
GMtoFord
Did you ever get your pics posted of your setup? If you need help im sure the Moderator will help you out... WE wanna see your truck!!!!
Old Sep 5, 2007 | 08:46 AM
  #148
origcharger
It would seem Powerstroked 162 has been far luckier with this than most.
As its designed there should be no way simply leaving the sensors in place in the system after removing the DPF is going to trick the PCM.
AFAIK only one of the sensors measures back pressure, the others measure temperature. Others have reported what happens is that after 500-800 miles the computer initiates a drive cycle regeneration and since the DPF is gone the exhaust system does not get hot enough to shut it off.
This is why some here have been somewhat sceptical of what Powerstroked162 has been reporting.
Old Sep 5, 2007 | 09:22 AM
  #149
GMtoFord's Avatar
GMtoFord
"This is why some here have been somewhat sceptical of what Powerstroked162 has been reporting"
I wanna see pics of his truck with some of the equipment installed on it he has in his sig. Guess he cant get his pics up...
Old Sep 5, 2007 | 09:35 AM
  #150
dkf's Avatar
dkf
If simply removing the DPF and transfering the sensors over to the new straight pipe works fine, it makes me wonder why companies such as SCT are going to so much trouble to come up with a program for DPF removal?
Starting a Gallery and posting pics is very simple. I added galleries for the first time ever a few weeks ago and it was very quick and easy.
