OH , I gotta do it!!!
Old Aug 8, 2006 | 12:18 PM
  #166
broke77f100's Avatar
broke77f100
c'mon yall get this topic goin again i thought it fell off the forums till i went through like 7 pages before i found it
Old Aug 8, 2006 | 02:08 PM
  #167
Silver Streak's Avatar
Silver Streak
Why? It's run its course.
Old Aug 8, 2006 | 02:41 PM
  #168
RotGrubestier44's Avatar
RotGrubestier44
yeah, it pretty much has, until between Dec.-Feb. Besides that, I already have all the info I need, and thats what I started this for in the first place.
Old Aug 8, 2006 | 04:31 PM
  #169
the peppermint's Avatar
the peppermint
Since we are talking in here again, how is the truck coming along rot?
Old Aug 8, 2006 | 07:04 PM
  #170
broke77f100
yah really how is that thing goin man? im plannin on pullin the engine and putting it on a stand and strippin it painting it and replacing all the seals etc etc and gettin some detailing pieces like chrome valve cover and airfilter stripping the engine bay and painting it gloss black like i did already over all the other dirt that was in there but it looks alright...ill get pics next spring after its as good as it can get...until i drive it for 1 year and get it all performance built
Old Aug 9, 2006 | 03:58 PM
  #171
RotGrubestier44
well, so far I have the lift, wheels and tires installed, as well as a new exhaust setup. Next will be Yukon 4.09 front and 4.11 rear gears, a Power Lock LSD in the front, and a Lock Rite in the rear, along with all new Yukon axle shafts, bearings, seals, and Spicer U-Joints. After that $1350 gets blown, I will be buying a running "junk" engine from a buddy of mine for $125. He swapped in a 460, and doesn't want it. I am going to start on the engine build this winter. I will be using a propane kit from www.gotpropane.com, and hopefully the FSPP aluminum big block six head when they come out with at the end of the year. I am wanting to use 4.050" flat top pistons from a 390 to raise my compression ratio up around 13:1. Propane is 100-110 octane, so that will be no biggie. Just have to wait and see what the head will handle. The main reason I am waiting until the end of the year is because I am going back to school at LTI now, and don't have the cashflow I had before, lol. I will be done in Feb. and should start out around $50k a year. At any rate, I will keep ya'll informed on the buildup. Also, there is a slight possibility of a turbo being added at some point, although most likely not initially, in this build.
Old Aug 9, 2006 | 11:12 PM
  #172
4.9inline6's Avatar
4.9inline6
if you do decide to turbo it, do a dyno before and after...even if just for fun!
chris
Old Aug 10, 2006 | 02:52 PM
  #173
RotGrubestier44
If I do go turbo, I'll have to put in diffrent pistons to actually lower the comp. ratio a lil, bit, otherwise my head will go bye bye, and all the $$$ I put into it will as well.
Old Sep 16, 2006 | 01:20 PM
  #174
broke77f100
well im hopefully gonna start a job soon...sadly its mcdonalds but hey i need the money and it'll help me get my truck goin for next year when i turn 16
Old Sep 16, 2006 | 01:21 PM
  #175
broke77f100
hopefully i can get an engine stand soon so i can pull my 300 and clean it paint it and replace all gaskets over winter
Old Jan 28, 2007 | 07:56 AM
  #176
broke77f100
ok so i wasn't hired at mcdonalds cuz im 15 but they would have if i applied during the summer and not fall...and was not able to pull and replace gaskets and paint during this winter...i did get some new pics up on cardomain http://www.cardomain.com/ride/2271446 i would have put them on here as well but im having trouble uploading them
Old May 15, 2007 | 09:50 PM
  #177
Mtthwvn73's Avatar
Mtthwvn73
Talking
I just had to revive this thread.
You never said anything else about how the motor's comming along. I'm sure (especially silverstreak ) would love to know how much progess you've accomplished so far.
Matt
Old May 15, 2007 | 09:52 PM
  #178
broke77f100
yeh man i havent heard anything on here in a longggggggggggg time
David Koppin
Feb 2, 2017 08:20 PM
cjwalsh87
Jan 3, 2017 10:26 AM
oldschool-f150
Sep 3, 2015 11:55 AM
MEPR
Mar 26, 2003 05:59 PM
wildjon300ci
Aug 24, 2001 03:29 PM
