OH , I gotta do it!!!
Old Jun 2, 2006 | 05:16 PM
  #61
RotGrubestier44's Avatar
RotGrubestier44
ok, thanks, I'll check it out over there.
Old Jun 2, 2006 | 09:48 PM
  #62
broke77f100's Avatar
broke77f100
Originally Posted by shmoozo
Just a bit of advice I once got from an old engine builder --
When building a performance engine it's usually a bad idea to bore a modern engine's cylinders out any more than required to clean them up and then get them to the next standard piston size. The amount of displacement you can gain by going further is minimal (perhaps 1 or 2%) so it doesn't really add much to either the torque or the HP and you'll risk weakening the cylinder walls in the process. If you're going to be boosting the compression, adding boost, or squirting in big shots of nitrous oxide and pushing the engine hard, that can lead to some pretty spectacular (and therefore costly) engine failures. Furthermore there is no practical, cost efficient way to "unbore" a cylinder block.
Here's the actual displacements you'll see in a Ford 300 six from various overbores in increments of 0.010 inch. I've rounded the displacements to the nearest 0.1 inch.
0.010 -- 301.5 cubic inches
0.020 -- 303.1 cubic inches
0.030 -- 304.6 cubic inches
0.040 -- 306.1 cubic inches
0.050 -- 307.6 cubic inches
0.060 -- 309.2 cubic inches
So what you gain by going to 0.060 over as opposed to, say, 0.030 over is only about 1.5% of the engine's total displacement. That's not even close to being worth the risk.
Trust me. Go conservative on this.
isnt boring .080 giving 314? and .060 310 cubes and not 309.2??????????
Old Jun 2, 2006 | 09:49 PM
  #63
broke77f100
well actually 310.7
Old Jun 2, 2006 | 09:50 PM
  #64
broke77f100
and .080 would be 313.7777
Old Jun 3, 2006 | 01:03 AM
  #65
Jefftopgun's Avatar
Jefftopgun
and a dead motor loool.... I say bore it 80 and then get some nice sleeves
Old Jun 3, 2006 | 06:21 AM
  #66
STGFordCrazy04's Avatar
STGFordCrazy04
if it were me I would bore it all the way out and just have 1 oval shapped piston custom made. Rough guessing says that it would be approx 26" long and 4" wide. Im thinking it will be the worlds first 400ci 1cyl truck engine. That seems to be the best idea Ive heard so far. This is probably more realistically achievable than a 600hp 500tq natually aspirated street motor funded by a high school job.
This is getting out of hand
Old Jun 3, 2006 | 07:11 AM
  #67
broke77f100
high school job? when i work with my dad(installing flooring)i make 2-3 times more than a high school job...working with him you dont get paid by the hour but a percentage of the job
Old Jun 3, 2006 | 09:25 AM
  #68
havi's Avatar
havi
I'll have the Roast Duck
You DO realize how much fuel costs these days? I can only imagine the mpg something like that would involve. BTW, If torque is the name of the game, install a Caterpillar engine from a forklift or something.
Old Jun 3, 2006 | 09:34 AM
  #69
83Van's Avatar
83Van
About the water pump: no there's no "high flow" pump for the 300... BUT... if you get a new [not rebuilt] pump made by either Cardone or ASC [or is it ACS?] they'll have a modernized impeller disign with a backer plate that will make them flow ~20% better than the old factory pump. New pumps for the 300 are very inexpensive, just paid about $35 for mine.
As far as coolant additives, "Water Wetter", "40 below" and similar chemicals do indeed work. My old Mercedes runs HOT by nature, and dumping in the correct ammount of -40 dropped the idling temp by a good 20 degrees. Have some friends in the rice racer world who do insane turbo jobs on their tiny engines, and they'll often use it because where the heck are you going to put a larger radiator in a civic??
Old Jun 3, 2006 | 11:44 AM
  #70
STGFordCrazy04
Havi,
hopefully you realize that I am joking.
CAT DT466 in a 150? hmmmmm I can see it now and it scares me.
Old Jun 3, 2006 | 02:21 PM
  #71
broke77f100
u could always just strap it to the front end or hood lol
Old Jun 3, 2006 | 03:35 PM
  #72
81-F-150-Explorer's Avatar
81-F-150-Explorer
I'd guestimate 3 gallons to the Mile.
Old Jun 3, 2006 | 04:40 PM
  #73
shmoozo's Avatar
shmoozo
Nope. I just checked my math again using an Excel Spreadsheet. Here's the results, this time rounded to the nearest 0.001 cubic inches.
Stock Bore & Stroke: 4.00" x 3.98"
Overbore, ........ Displacement,
inches ............. cubic inches
0.000 ---------- 300.085 <-- Stock
0.010 ---------- 301.587
0.020 ---------- 303.093
0.030 ---------- 304.603
0.040 ---------- 306.117
0.050 ---------- 307.634
0.060 ---------- 309.155
0.070 ---------- 310.680
0.080 ---------- 312.208
Old Jun 3, 2006 | 04:46 PM
  #74
havi's Avatar
havi
lol, Sarcasm doesn't show well in typed form. But on a side note, I have an article on a 64 ford pickup w/ caterpillar motor....Four-Wheeler I think it was, back in the mid-90's. 3 gallons to the mile...still better than what Bigfoot gets.
PS: not trying to steal this thread.
Old Jun 3, 2006 | 06:22 PM
  #75
broke77f100
wait no cuz i just checked it myself on a calculator using 6X0.7854X4.080sq.X4 and am still getting 313.7779814
