OH , I gotta do it!!!
Old Jun 3, 2006 | 11:16 PM
  #76
flat4vw's Avatar
flat4vw
Originally Posted by optikal illushun
i REALLY dont think DD2K is that accurate.
FINALLY! DD2K is a toy. Real engine analyzing software is significantly more than $30 and almost impossible for a non-professional to use.
Old Jun 4, 2006 | 08:35 AM
  #77
broke77f100's Avatar
broke77f100
wait the stroke isnt 4" is it? thats where i was screwing up the formula i believe...it must be the 3.98" sorry about the argument
Old Jun 4, 2006 | 02:32 PM
  #78
Twinscrew's Avatar
Twinscrew
This higher math is killing me. I can't seem to get past my take-aways.....
Old Jun 4, 2006 | 02:37 PM
  #79
broke77f100
it cant possibly be that difficult to do this math...im 15 and did it
Old Jun 4, 2006 | 08:25 PM
  #80
Jefftopgun's Avatar
Jefftopgun
Forgive my ignorance
Old Jun 4, 2006 | 09:59 PM
  #81
RotGrubestier44's Avatar
RotGrubestier44
Originally Posted by 83Van
About the water pump: no there's no "high flow" pump for the 300... BUT... if you get a new [not rebuilt] pump made by either Cardone or ASC [or is it ACS?] they'll have a modernized impeller disign with a backer plate that will make them flow ~20% better than the old factory pump. New pumps for the 300 are very inexpensive, just paid about $35 for mine.
As far as coolant additives, "Water Wetter", "40 below" and similar chemicals do indeed work. My old Mercedes runs HOT by nature, and dumping in the correct ammount of -40 dropped the idling temp by a good 20 degrees. Have some friends in the rice racer world who do insane turbo jobs on their tiny engines, and they'll often use it because where the heck are you going to put a larger radiator in a civic??
Thanks for that info, on both counts. I will definantly check it out. All of you nay sayers, I am serious, go post in Ford VS the competition or something. All you are doing here is taking up more valuable space with your BS remarks.
oh, p.s. The DT466 is an International engine, not a CAT engine.
Old Jun 4, 2006 | 10:48 PM
  #82
STGFordCrazy04's Avatar
STGFordCrazy04
Rot,
You are correct. my mistake.
I will leave you alone on this one. I personally dont care if you go as cheap as do a Marvel Mystery Oil fix or do a full out competition build. Im not spending the money and noone else here is either. All I can say is spend YOUR money wisely and the best of luck to you. I sincerely hope you can make the power you want out of the motor you have. I just dont want you to fall into the same trap as I have in the past and many others do daily of believing the advertised hp and tq gains of aftermarket parts. The real numbers, the ones that matter, come from a rear wheel dyno not from the crank. You lose 20%, at least, through the drive line. So that being said, you 500tq will be more like 400tq at the rear wheels if not less. "IF" you do build this engine and it makes the power you claim please have it blueprinted and Im sure you will make some money back selling the plans on this site. Good luck and Im sorry again for the negativeness.
Old Jun 5, 2006 | 02:16 PM
  #83
broke77f100
this brings me to another point...I qualified for a car sponsorship from carsponsorships.com but...i have no credit card therefore i can not register to recieve parts...what do i do?i would have even been able to get my sponsorship "agent" to try to have Clifford sponsor me...
Old Jun 5, 2006 | 02:49 PM
  #84
optikal illushun's Avatar
optikal illushun
Scam! Scam! Scam! Scam! Scam!
Old Jun 5, 2006 | 02:57 PM
  #85
broke77f100
really? many people use thatmsite though...anyhow i cant get a card till im 18 or wutever so i guess im stuck with paying myself lol..unless yall want to donate some parts for me?a new 4 or 5 leaf rear spring with perch and um some engine pieces maybe a valve cover and intake...also motor mounts for my 300
Old Jun 5, 2006 | 07:23 PM
  #86
RotGrubestier44
Broke, you could always get one of those rechargable MasterCard deals from CVS, You can't over draw, and its only a few bucks to put money on it.
I want ya'll to understand I'm not trying to be a jerk when I tell you to fark off, I am look'n for info on parts, so I can make a parts list, and start accumulating parts so I can assemble said parts in and on an engine block. I do appriciate concerns, but alot of this stuff you are saying is either very negative, or reads that way.
Does anybody know of an oil pan with a windage tray for the 300? I thought I read somewhere that Milodon makes one. I know they make the HV oil pump.
Old Jun 5, 2006 | 07:46 PM
  #87
havi's Avatar
havi
I'll have the Roast Duck
FWIW, a thin gauge piece of steel formed to shape and lightly tackwelded into the pan several times could do the trick if you can't find one aftermarket.
Old Jun 5, 2006 | 09:56 PM
  #88
Jefftopgun's Avatar
Jefftopgun
agreed........
Old Jun 5, 2006 | 11:17 PM
  #89
the peppermint's Avatar
the peppermint
I did the standard upgrades, offy intake, holley 4160 (390cfm), hedman header, and duraspark II ignition. My exhaust is 2.5 inch pipe two into one just past the tranny crossmember, single 40 series flowmaster and it ends just after it comes down over the axle. It has 18s and 20s with a 3.08 gear and the np435, rear tire height is 30.5 inches. It makes between 135hp (street tune) and 180hp ( lots of carb tuning and it was just a good day) measured with a g-tech performance meter. It pulls harder and harder the more rpms it climbs. The highest rpm I have taken it to is 5000 (yes I have a tach, I'm not guessing) and it never "ran out of breath". I once passed one of my buddies who said he was doing 125, in his audi a4 1.8t, I went by him like he was sitting still. The acceleration is 7.0 to sixty and the quarter in 17.4 seconds. My point is this rot how much power do you really need? I know my acceleration is sucky because my effective gear ratio is something like 2.85 but its a truck.
On the other hand the power that you are wanting is possible naturally aspirated. There used to be a guy running around ozark AR who could pull the front wheels about 6 inches off the ground with his 300. I have since talked to people who knew him, all they could tell me was it had "chevy rods, a 750 cfm holley, and crane rockers". It was naturally aspirated though and one guy who went to school with him told me it dynoed about 550hp
Old Jun 6, 2006 | 08:56 PM
  #90
Jefftopgun's Avatar
Jefftopgun
wow that 0-60 is very impressive, and I am jeleous, given that I do it in about 11.5. I might be converting to carb . I am about to have to tear something down though, got a weird ticking noise somewhere in the drivetrain (but non motor) that I cant figure out, so I am going to get one of the other mechanics at work to give it a shot.
