locking hubs?
Old Dec 13, 2011 | 02:17 PM
  #196
R1racer's Avatar
R1racer
Ok here's my thoughts i will take apart the OEM auto Locking hub clean them with commercial part cleaner. Re-pack them and give it try as x-mas time around the corner
*on the other hand am really curious .when the truck up in the air & set the hubs to lock all turns good but when i droop it to the grond i get No 4x4 action ? Is it because the one locking hub in question might be failing ?
* But if it is failing how could it be functioning 100% like it suppose to when i use the auto selector inside the cab?
* Last one when the truck set to auto lock is the front axel suppose to be in a stationary or in rotation motion with the weel spining ?
Old Dec 13, 2011 | 03:02 PM
  #197
Treker58's Avatar
Treker58
Originally Posted by EXv10
Warn has been around since day one.
Exactly why I went with the Warns, I'm sure that the Mile Markers are fine. I've just had Warns before and been very happy and see no need to change
Old Dec 13, 2011 | 03:10 PM
  #198
Treker58's Avatar
Treker58
I'm not sure I completely understand the first part of your question, when you have the hubs in the lock setting the selector inside the truck needs to be in either 4 H of 4 L for it to be in 4X4. and when your hubs are set to auto and you are in 2 wheel nothing up front is turning except the tires, no axles
Old Dec 13, 2011 | 03:35 PM
  #199
tjblair's Avatar
tjblair
Originally Posted by Stewart_H
I have read about Mile Markers failing over time, but have yet to hear about Warn's failing.
Not saying Warn's are bullet proof, but I'll pay a little extra for peace-of-mind.
Stewart
I pay a little more for Warn for a quality American made part. And peace of mind.
MM sells nothing but Chinese made junk.IMO
Old Dec 13, 2011 | 04:05 PM
  #200
Treker58's Avatar
Treker58
They are made in China? Thought they were USA the way people talked, thanks for the info. Wife will be happy she's on the buy american thing(I agree) so points there on me getting the Warns. Durning the summer I was doing a BBQ and part of the meal is a sauteed brussel sprouts with a cream shallot sauce, the brussel sprouts that I was going to buy were from Chile, had to stop at a different market on the way home for the USA sprouts
Old Dec 13, 2011 | 04:15 PM
  #201
tjblair's Avatar
tjblair
About Mile Marker Inc.
Mile Marker operates from its headquarters in Pompano Beach, Florida, its primary distribution center in Kalama, Washington and from its plant in China.
Old Dec 13, 2011 | 05:15 PM
  #202
Stewart_H's Avatar
Stewart_H
Originally Posted by Treker58
...part of the meal is a sauteed brussel sprouts
AUGHGHGHGHGHGHGHGHGHGHGHGHGHGHGH! Name:  cwm8.gif
Size:  4.8 KB Name:  cwm8.gif
Stewart
Old Dec 13, 2011 | 06:00 PM
  #203
Treker58's Avatar
Treker58
Stewart
No they are realy good I won't eat them if they weren't made this way, want the recipe
  #204
Treker58's Avatar
Treker58
Stewart
No they are really good I won't eat them if they weren't made this way, want the recipe
Old Dec 14, 2011 | 08:03 AM
  #205
R1racer's Avatar
R1racer
SO even when you go outside and set the hubs to lock you still got to set the selector switch from the inside ?
The way i understand it ....The reason you got the lock on them hubs is to go out side and lock them in the event the auto fail which from inside the truck . What you say in is i still got to use the switch even when bypassing the auto function . Correct me if am wrong ... As this truck is new to me and am learning as i go
Old Dec 14, 2011 | 08:18 AM
  #206
RACERX7775's Avatar
RACERX7775
Whew, all this and it was user error? I hope not. Read the owners manual. You still have to turn the switch. That is what engauges the transfer case. The reason the hubs are able to manually lock is if the HUBS dont lock by means of the vaccum system.
Old Dec 14, 2011 | 08:52 AM
  #207
tjblair's Avatar
tjblair
You sir are correct
Old Dec 14, 2011 | 09:42 AM
  #208
R1racer's Avatar
R1racer
I sure did read the manual but it was not clear on that part that I still got to flip the switch from the inside or at least to me... I was under the impression that by setting the Hubs to lock from outside i don't have to turn the switch.
Regardless i found that the right locking hub internal plastic retained inside the cup itself is cracked that's why it wasn't releasing , I took the left locking hub apart serviced it , greased it and waiting for replacement to the R side <O</O
Old Dec 14, 2011 | 09:45 AM
  #209
RACERX7775's Avatar
RACERX7775
What are you going to replace it with? If you are paying more than $90, you should just buy a set of mile markers from summit.
Old Dec 14, 2011 | 10:06 AM
  #210
EXv10's Avatar
EXv10
Regardless i found that the right locking hub internal plastic retained inside the cup itself is cracked that's why it wasn't releasing , I took the left locking hub apart serviced it , greased it and waiting for replacement to the R side <o</o
You still have to flip the switch to engage the T -case. Many people just leave them locked in the winter to make them easier to lock up by the switch and it doesn;t hurt anything. There should be lots of stock units around, cheap.
