locking hubs?
Old Aug 21, 2010 | 07:03 AM
  #91
Cardiac69's Avatar
Cardiac69
Who makes an electronically actuated hub?
Old Aug 21, 2010 | 09:56 PM
  #92
Hybris's Avatar
Hybris
No one that I know of but I was actually fishing around for responses on the concept of such a mod.
Old Aug 23, 2010 | 08:26 PM
  #93
RobertH's Avatar
RobertH
I for one love the autohubs and when I buy something that is designed, I expect it to work. So far, no fails on the vacuum I have been hearing about.
My GM has never been an issue, so wonder why Ford does not change?
Or have they? What are the new truck doing? Are they still designed the same way?
Old Sep 5, 2010 | 06:50 AM
  #94
jdboy's Avatar
jdboy
I purchased a used hub from my local wrecking yard to replace the one on my truck with the broken dial. I used the info on Guzzle's site to guide me through cleaning and lubing the new hub as well as the one on my truck at the moment. Worked great on the one that I had purchased but it seems like the dial on the other one is still really hard to turn! Sounds like the o-ring is still dry so who knows? I may just go back and buy another one and keep my old original as an extra.
Old Sep 5, 2010 | 05:46 PM
  #95
wallz's Avatar
wallz
Try soaking the stuck hub in atf fluid for a few hours. I had one that was pretty stiff to turn, and after a few hours soak it works as good as new, and now several months later still good. Set it upside down enough to cover the dial area in tranny fluid and see if it works for ya.
Old Sep 5, 2010 | 08:37 PM
  #96
jdboy's Avatar
jdboy
Cool, thanks for the info!! I'll give it a try for sure.
Old Sep 5, 2010 | 09:51 PM
  #97
EXv10's Avatar
EXv10
I posted on this 2 or 3 times. Drill a hole in the dial, fill a small bowl with oil to about an inch with atf or penetrating oil, let in sit in there overnight, work it with pliers, and put a sheet metal screw back into the hole. It has such a good seal that it is actually too good and you need a hole to get to the back side also.
Old Sep 13, 2010 | 08:44 PM
  #98
socal4x's Avatar
socal4x
Originally Posted by RTM
If this is your third and you have not had an auto hub issue then your lucky. I and others have swapped out the auto hubs for manual locking hubs. My auto hubs were frozen in the locked position for almost a year.
I must say that I would like the auto hub for the wife but for me it doesn't matter. After all it takes all but 20 seconds to lock in both hubs the old fashion way.
cuz ford new the auto would fail! Backup plan I guess.
Old Nov 22, 2010 | 06:56 PM
  #99
hoofkicker's Avatar
hoofkicker
manual locking hubs
I want to change my 2004 f-250 over to manual hubs. Does any-one know if the Mile Marker 449ss hubs well fit and do i need anything else for the conversion? Thanks for any information, i e-mailed Mile Maker, but didn;t get a reply.
Old Nov 22, 2010 | 07:16 PM
  #100
RACERX7775's Avatar
RACERX7775
I have had my 449ss hubs on for a couple years now and they move like new still. The hubs do feel like they are loose but they arent.
Old Nov 22, 2010 | 09:38 PM
  #101
RPEX's Avatar
RPEX
This might be a dumb question but I'm gonna ask anyway. When you switch to manual hubs do you still use the button to switch from 4h to 4low?
Old Nov 22, 2010 | 09:44 PM
  #102
EXv10's Avatar
EXv10
There are no dumb questions! It's not dumb if you can benefit from an answer and nobody is expected to know everything.
Yes you still have to hit the switch inside.
Old Nov 22, 2010 | 09:46 PM
  #103
EXv10's Avatar
EXv10
I've had my stock ones for 10 years and they are still as smooth as new.
Old Nov 23, 2010 | 08:27 AM
  #104
59CRL's Avatar
59CRL
As a newbie the information here is great. I went out and checked my hubs, both frozen, so I soaked them in WD-40.... waited then worked them loose with pliers, one hub was in the front lock position and the other in the back auto. Now you can turn them easily with your fingers. Im keeping mine in auto mode for now, until we get snow. Great thread!
Old Nov 23, 2010 | 09:22 PM
  #105
EXv10's Avatar
EXv10
You could have taken the hubs off, drilled a hole in the dial, and set it in penetrating oil overnight or take the hub off, turn it to 1/4" past unlock, pull the dial out, and put new generic 0-rings in it.
