locking hubs?
Old Jan 2, 2011 | 01:41 AM
  #121
EXv10's Avatar
EXv10
Originally Posted by rlh68050
Then how does the t-case get engaged?
You got me there rlh..ha ha
Old Jan 2, 2011 | 08:24 AM
  #122
chazman's Avatar
chazman
Look at post #18 for an explanation of how the whole system works..
Old Jan 27, 2011 | 03:46 PM
  #123
Bigpapa346's Avatar
Bigpapa346
ESOF troubles...
So I'm sitting at an intersection about to turn right, i engage the esof switch to be sure i have traction going into traffic, I hear the initial click and the 4wd engages as I am making the turn then 4wd goes away and I hear what I thought was a big vacuum leak. No leak as the whistle goes away when I come to a stop...
My question? What the heck did I do? I've gotten home ok and as I turn down my street the noise goes away. I try to lock in the hubs manually and they are frozen, I remove the hubs to clean them a bit and see if I can break them loose, success with 1 but not the other. The driver side is where the noise was coming from. Anyone else heard of this or had a similar issue? This thread is long and I think I've read all but may have missed something...
Thanks gang. BTW, I've been a member here for awhile but had to create a new login...
2003 Limited X 4wd. 110 k.. V10.
Old Jan 28, 2011 | 02:14 AM
  #124
EXv10's Avatar
EXv10
I know how it works.
Old Jan 28, 2011 | 09:55 AM
  #125
Fosters's Avatar
Fosters
Looks like my passenger side one is frozen into auto; I wouldn't be surprised thus if the axles and diff aren't locked in - I usually do get bind when I switch into 4x4 on pavement, so I'm guessing they are either frozen into locked or the bind is just coming from the driver side wheel which might still function normally.
What do you guys use to cap the vacuum lines?
Also, what are some of the places that have the best prices on the Mile Markers and the Warns? Best I found for the warn premier was 193 on amazon.
Last but not least, are the Warn premier worth the price over the standards? Only difference I saw between them was the premiers had a lifetime warranty...
Old Jan 28, 2011 | 12:37 PM
  #126
TYZ78F150's Avatar
TYZ78F150
Mile Marker 449SS - Mile Marker Supreme Locking Hubs - Overview - SummitRacing.com
Only $89.50. This is where I bought mine, they went on easy and look/work great.I just used them yesterday for the first time and they worked flawlessly. it's 3/16' vacuum caps.
Old Feb 3, 2011 | 08:19 AM
  #127
jdross440's Avatar
jdross440
I have the warn manual hubs on mine (converted from auto locking). I had the front axles, hubs rebuilt in late summer. The inner bearings in the hubs had gone and wiped out the stub axles. New axles and hubs were installed. Now that we have 6 inches snow and close to zero, when I turn the hubs to lock, they don't engage. The transfer case is engaging as the driveshaft turns. Could too much heavy grease on the warn hubs cause this or could something have been put in wrong? I am 200 miles from the shop that did the work with lots of ice and snow between us, so can't get back there until next week.
Old Feb 3, 2011 | 10:32 AM
  #128
TYZ78F150's Avatar
TYZ78F150
I know on my hubs, they said not to use additional grease, as it will affect the performance of the hub.
Old Feb 3, 2011 | 11:07 AM
  #129
EXv10's Avatar
EXv10
Not much needed on locking hubs
Old Mar 6, 2011 | 07:29 PM
  #130
tpozz's Avatar
tpozz
I just bought a used 2003 Excursion 4x4. Despite the 4x4 light on the dash illuminating when I switch on the fly, the hubs would not engage as both sides were seized. I removed the hubs, soaked them with liquid wrench to loosen them up and though it worked somewhat, decided to just get Mile Marker manual hubs new on ebay ($75). Disappointed that I no longer have switch on the fly capability but at least I know they work. Opted not to cap the vacuum line since others that have posted have had no issues. Ford OEM hubs are a rip off.
Old Mar 6, 2011 | 07:51 PM
  #131
jdross440's Avatar
jdross440
Replaced my Warn hubs with the stainless steel MileMarker ones. They work great and are of superior quality. No plastic. When I pulled the Warn hubs, the drivers side the inboard snap ring out allowing the inner workings to push out and not engage. The snap ring didn't fit the groove well at all. The Mile Marker hubs use superior snap rings. The only grease I put in was to lightly coat the splines, per a Mile Marker tech rep.
Old Apr 6, 2011 | 03:34 PM
  #132
thekauz's Avatar
thekauz
Manual or auto locking hubs
I had to get my '03 Super duty front hubs serviced. turns out they were all screwed up. i had an extended warranty so they were replaced. problem is they replaced them with SuperWinch manual hubs. Besides the fact that the wheel rim covers now looks out of place they no long shift on the fly. I personally dont care but I'm sure my wife would rather not get out of the car to lock the hubs.
Any suggestions? Should I keep the manuals and find another plactic wheel cover or should I make them get the autolocking hubs???
Old Apr 6, 2011 | 03:57 PM
  #133
jdross440's Avatar
jdross440
Smile
My wife likes the manual over the automatic. She says: "At least I know they work when I need them, not like the auto locks that don't work half the time. If I think I may need 4WD, I'll lock them before leaving."
We have a 92 Dodge W250 Cummins with factory manual hubs, we bought the truck new, and they have always worked and she liked them from day one.
IMHO I'd stay with the manual hubs.
Old Apr 6, 2011 | 06:53 PM
  #134
thekauz's Avatar
thekauz
Her Truck
It is her truck and she likes the idea of not getting out of the truck to lock the hubs when its nasty out or she's sitting in snow....???? Seems like most agree that manuals are the way to go. I just wish the plastic bolt covers matched up to the new hubs. Like I said its her truck so its gotta be pretty....can a truck be pretty?
Old Apr 7, 2011 | 11:51 AM
  #135
EXv10's Avatar
EXv10
Trucks are handsome and the new VW's with the flower holder on the dash is pretty.
