locking hubs?
Old Dec 13, 2010 | 11:39 AM
  #106
jeronlines's Avatar
jeronlines
Originally Posted by EXv10
There are no dumb questions! It's not dumb if you can benefit from an answer and nobody is expected to know everything.
Yes you still have to hit the switch inside.
So, if you put manual locking hubs on and keep them in locked you can still control the 4x4 inside? I.e., with the manual hubs locked the truck will still be in 2x4 until you push the locking button inside?
Old Dec 13, 2010 | 12:00 PM
  #107
Cardiac69's Avatar
Cardiac69
That is correct. That is the way I have mine right now. Of course with our blizzard here in NW Indiana, it is getting a work out...
Old Dec 13, 2010 | 12:34 PM
  #108
jeronlines's Avatar
jeronlines
So doesn't that make them auto-locking hubs? Seriously, how is that system different than what comes stock? My stock hubs are "frozen" and I can't get them unstuck so I am looking at replacing them with the OEM auto hubs or going with a set of manual Warns.
Old Dec 13, 2010 | 02:37 PM
  #109
RobertH's Avatar
RobertH
When the hub is locked, the gears are engaged to the axle and it always turns. When not engaged, it is free wheeling. Less wear and tear and better fuel mileage as a result when not engaged.
From inside the cab, when you engage 4X4, that will engage the transfer case to the axle and turn all.
If that makes sense.
Old Dec 14, 2010 | 01:21 PM
  #110
jeronlines's Avatar
jeronlines
It does and seems to fit, engineering wise, why have an "auto locking" hub vice a hub always locked in manual and then 4x4 from the cab.
Old Dec 14, 2010 | 03:37 PM
  #111
SkySkiJason's Avatar
SkySkiJason
Please send me any non-working OEM hubs. I'll pay for shipping! (How long ya gonna let'em sit there and collect dust? )
Old Dec 28, 2010 | 09:21 PM
  #112
HuntingTag94's Avatar
HuntingTag94
Hey, this is probably another stupid question, and the answer could be found by searching the forums, but my internet connection is so slow I would be senile before I got to the right thread.
Does an auto lock hub basically work like a retractable ink pen? I mean, do you send a vacuum pulse to lock the hub, and then another to release it? The PVH is only energized for 35-40 seconds,right? And that solenoid can't do anything but put vacuum on again when you switch to 2wd, can it?
Old Dec 28, 2010 | 11:20 PM
  #113
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
That is exactly what happens and there's no stupid questions here.
We all learn every day.
Old Dec 30, 2010 | 12:32 AM
  #114
EXv10's Avatar
EXv10
Originally Posted by GR$$N$
im a bit of a noob on the 4x4 issue. but i have the manual ones on each wheel and also the in door switch to switch them. whats the point to have both of them?
The inside switch is just a convience. Women (no offense) like it and so do lazy people. I actually like even though I am neither. You could eliminate the indoor switch but then your wheels would always be in the lock position which is not devastating but it will cost you a little in gas mileage.
Old Jan 1, 2011 | 11:50 AM
  #115
King_Ian's Avatar
King_Ian
I've read through this whole thread and haven't found anything on what I'm experiencing. Just thought I'd toss it past you guys and see your thoughts since you seem to be pretty knowledgeable.
When my hubs are set to auto and it's warm out, I can switch it into 4x4 and hear it engage when on pavement, and it works just fine. This winter, still set to auto, I switch it 4x4 and there's no chance it's working. I flip the hubs into lock, and the 4x4 works perfectly, as does 2x4 when selected. Does this have to do with the weather?
Old Jan 1, 2011 | 12:25 PM
  #116
Cardiac69's Avatar
Cardiac69
You probably just need to service the hubs. Do a search on here for Guzzle's hub info....
Bob
PS: Here is the link: Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Jan 1, 2011 | 01:03 PM
  #117
rlh68050's Avatar
rlh68050
Then how does the t-case get engaged?
Old Jan 1, 2011 | 08:38 PM
  #118
hochus's Avatar
hochus
are they auto or manual hubs?
Alright a little confused. I got a 2001 excursion 4x4.
do i have auto or manual hubs?
On the dash I have a **** 2 high, 4 low, 4 high.
My hubs I can rotate from free to lock. Hubs are factory.
Do I need to go out and lock the hubs or would it do it from the switch.
I alway go out manually lock them then turn **** to 4 low or 4 high depending on what im doing.
Old Jan 1, 2011 | 09:36 PM
  #119
Cardiac69's Avatar
Cardiac69
If you have the black Ford ESOF hubs, they should be labeled "Auto" and "Lock". If left in auto, and they are working properly, they should lock on their own via a vacuum pulse when you turn the dash switch to 4H or 4L
  #120
jeronlines's Avatar
jeronlines
OEM hubs are auto locking. If the system is working, you can shift from 2wd to 4wd via the cab switch when the hubs are in auto.
If they're in lock, you still need to use the switch in the cab to engage the transfer case.
