Methanol/Water Injection
Old Jun 6, 2004 | 03:00 PM
  #106
Choctaw Bob's Avatar
Choctaw Bob
Originally Posted by bighoss550
my cell is 16 gallon which is better 4 me cuz i haul heavy alot so it will use it.
i am putting my nozzle in the pressurized pipe from the i/c to the intake, down at the bottom. thats where the pressure switch will be also.
im not too worried about the dealer seeing it cuz i used to work there and they wont say anything. very small dealership. more of a used car lot actually.
once the service manager had me punch a cat out on a customer car!!! not too woried about water injection!
Do you have part numbers and where you got the nozzles? I 'm not sure if my NOS nozzle last too long if I use it often. It appears to be billet steel, black anodized, with copper fittings to screw the lines on to which helps prevent leaks of the 2,000 psi Nitrous oxide. I have never had one fail. There are removable brass jets. I think the one I will use is .032.
I plan on using mine in an occasional trip to the drag strip. I pull a travel trailer every once in a while but the truck doesn't need any help for that.
Old Jun 6, 2004 | 05:04 PM
  #107
jdadamsjr's Avatar
jdadamsjr
Asked and answered... :-)
good in air intake charge theu intake...
bad in diesel intake charge thru injectors...
oops - there I go answering a post when it's not the last page again !!!
too much sun today @ the autocross
Old Jun 6, 2004 | 05:29 PM
  #108
bighoss550's Avatar
bighoss550
the NOS nozzles are supposed to last for 10,000 miles...
Old Jun 6, 2004 | 07:34 PM
  #109
Choctaw Bob
Did you win?
Old Jun 6, 2004 | 07:35 PM
  #110
Choctaw Bob
Great! If the mixture erodes any of it, it will be the brass jets. Probably not at 60 PSI
Old Jun 6, 2004 | 07:51 PM
  #111
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Did it push in the turns
Old Jun 6, 2004 | 08:30 PM
  #112
Choctaw Bob
I'll bet it plowed, then sudden throttle on oversteer
Old Jun 6, 2004 | 09:09 PM
  #113
IB Tim's Avatar
IB Tim
Hope he didn't poke it in a tire wall
Old Jun 6, 2004 | 09:26 PM
  #114
jdadamsjr's Avatar
jdadamsjr
I didn't take the beast
Although I KNOW I would have won my class since NO one thre drove anything bigger than the Lincoln LS I was in !
Placed ninth and not bad for never driving in one of those and this is my WIFE'S car so I never drive it, and the old eyes can't pick up those cones as fast as the car will go
Old Jun 6, 2004 | 10:48 PM
  #115
Choctaw Bob
I did that kind of racing a Looooong time ago '69-'75 in Midland. I would usually forget which side of the cone and direction I was supposed to go. I had a '67 big block Camero with open headers. I smoked the rubber and made noise. I never came close to winning but the crowd loved the show!
We had a new car dealership, Fiat, Volvo, Lotus, Saab. The Lotus Europa was good and also the Saabs. We had fun!
Old Jun 7, 2004 | 06:39 AM
  #116
IB Tim's Avatar
IB Tim
That is why I like road racing, easy to know were to go
1/4 mile should be no problem either
Old Jun 7, 2004 | 10:14 AM
  #117
jdadamsjr's Avatar
jdadamsjr
Yep - Road Course on the Texas Motor SPeedway in a couple of weeks should be more fun - I can tell the difference between concrete and grass !!!!!
1500 cones on a striped parking lot is a lot to pick up at speed...
I was feeling bad until I started looking at the final postings...
MANY DNF's for going off course... so I guess it was a common occurance...
Old Jun 7, 2004 | 10:18 AM
  #118
IB Tim's Avatar
IB Tim
In my career, I have always gone faster going backwards across grass then you ever-good forward. Add a spot of rain and o-wow.
Grass racing has never interested me….but I have participated in it.
Old Jun 7, 2004 | 10:23 AM
  #119
jdadamsjr's Avatar
jdadamsjr
been there, done that too !!!
Not by choice either
Old Jun 7, 2004 | 05:43 PM
  #120
Choctaw Bob
I would drive sometimes in the grass at Kennedale when I was having problems with giant wheel stands. Hard to steer with the front tires off the ground. Hard to back out with all the money changing hands in the stands!
