Methanol/Water Injection
Fred we now understand how you feel and why it is so close to home, that info is of concern for all. We had no idea where you were coming from; not that attacking anyone is good tactics.
Lets keep this thing clean.
Lets get back on track and find out more… on what really gets us going….HP/TQ
Gosh,
I spend some quality time with the wife before I go out of town and misa ALL the "spice"...
Since I'm not emotionally tied to the thread and won't be doing this type of thing....
Everybody take a breath and let's try to honor Pres Reagan's memory in that he could disagree with it becoming a personal attack...
I, personally, have not perfected that either... but it's a nice goal to have :-)
Seems like we have someone that is very close to the issue and has been burned before... I tend to be like that too ! Case in point, if I am invited to a restaurant I've had horrbile service from and am seatd and the same server comes up... I have a preconceived idea that I should expect bad service and immediately develop an attitude :-)
Hey, already admitted I wasn't perfect :-)
I understand the "honesty" of the issue and that's why I haven't weighed in... I figured it would get hashed out in the end and most of the time it is done amiablly here (unlike the OTHER boards :-)
I cannot be the world's policemen, I don't have the resources to do it, but I understand that someone has to... and will support those that can, including my nephew that is in Fallujah RIGHT NOW !
So let's chill and speak nicely to one another - Please ?
And let the cause and effect take care of itself....
See the post on this forum that has to do with the $13,000 Warranty not covered. Even though dealers sell performance devices and other mods, doesn't mean it is covered under warranty. When you buy a new truck, you sign a lot of papers. One of these papers says the dealer went over each of the documents and you read them. Read the Warranty Guide and then make a choice. Is it worth it to you.
Originally Posted by FredsF250TD
The thing is, people try and pull this "I did nothing wrong" on our performance shop. We build high performance turbo motors and warrenty them for a year(no mileage limit). "It just started knoking while I was going 60" is the best line. We tear it down and find smashed rod bearings. The tell-tale sign of detonation. We do not warrenty abuse. But guess what Bob, we have had one or two that admitted right up front that they THINK they may have overboosted it. We will give these customers FREE labor for this rebuild. They just pay for the parts. Of course, if they do it again, well it's on them. So you see, this warrenty issue hits close to home with me.
Not anonymous at all Bob. My full name, where I live, and what I do for a living is all right there in my profile. And ANYONE that feels they would like to talk with me on this subject is welcome to email and I'll be glad to send them my phone number. I'm sorry you don't see my point, but then again it doesnt surprise me. You are a "It's none of my bussness" type of guy. That will come in handy if you see someone getting muged on the street I'm sure.
Originally Posted by jdadamsjr
Gosh,
Originally Posted by SBV45
Fred, I don't think anyone has a problem with your point. I happen to agree that one should not warranty abuse. line. Many years ago when I first got into toying with engines for fun, I found out "Speed costs money".
The biggest tabu Fred violated was jumping on Tim...that is not done.
Well guys, this is gonna be a really long post, so just hang in here with me.
First off, just to let you guys know, I have a new motor ordered and Im keeping the old one for a rebuild. Heres the evident damge. Left side head gasket blown (initial problem). All 8 pistons melted down, 3 just totally demolished. Valves beat up from melted pistons, and cylinder bores slightly scarred (repairable). Turbo vanes not actually melted, but charred and slightly deformed.
The mechanic and I (with a little input from Ken Englesman) have determined the events that took place that led to the damage.
First off was the overall stress on the truck at the time. At 130+, with the aerodyamics of a brick with a trailing parachute, the entire vehicle, escpecially the engine, the stress must have been quite high when you factor in the amount of power I was pushing at the time. The water/alchohol was the initial culprit, however it seems now only to be a partial contributor. The stress, along with the cylinder pressures posed by the water kit put the head gasket over the edge and it blew. (By the way, the slightly strong mixture of methanol and my little edgy finger that just HAD to turn the pump up contributed here too.) Ok here was where I really went wrong. I am running an SCMT. No problem here, until you cumulate the situation. I am sitting on the side of the road with the head gasket blown, and I decide to limp it home. Mistake.
The motor is very weak at this point, and very little boost is available from the turbocharger. However, my chip is still in happy-go-lucky mode and slinging fuel the same as if i was putting out 30 psi boost. It apparently did this all the way home. With no boost, the serious overfueling overheated both the cylinder temperature and the exhaust gas temperature, hence the demolished piston heads and charred turbo vanes.
I could have done several things to prevent the latter steps from happening. First off, I should have left it sitting there and towed it in. Secondly, I could have de-installed the chip before I limped it home. Thirdly, and ironically, I could have left the water on. The temperature drop from the water/meth would have sufficiently cooled the motor to prevent heat damage, within the time frame.
Ill be sending the old motor, minus the valves and bottom end, for the Twin Turbo kit. The new motor will be in the truck within a couple of weeks. We paid for it in order to retain the blown motor for the rebuild.
I took a disposable camera full of pictures; as soon as I get a chance to get them developed ill post them on here. I hope what I have posted has provided a little insight into the risks and returns of the topic of the thread. Im now officially a Beta Tester
Well, now since I owe my stepdad for the entire motor assembly, and sometime in the near future will owe him for the rebuild, I am officially penniless for quite a while. I am, however looking forward to 120 pounds of boost.
Blow off valve? Whats that?
Im gonna baby this brand new stock one...im even debating on wheter or not to put the tuner back on; i most certainly wont until it has a couple thousand miles break-in. Once i get the twin-turbo one, im gonna give it you-know-what all the time, but it will be built to handle it.
Originally Posted by PSD 60L Fx4
Bob, how is your kit coming along? Are you still planning on using it?
Second, the methanol in a mix over 50% adds to the fuel snd raises the cylinder tenp.
I'm sorry that I was right in describing the destruction. I have been there before.
believe me, its worth every penny when ur hotroddin a diesel
