Well, I bet all of you knew it wouldn't take too long
I put my system back in tonight for a little competition on Friday
I will just be running water, because its cheap, and the only reason I'm doing it is to keep the EGT's down. The Edge module really builds some heat (and the power to go along with it) Maybe a little HP as a nice side effect.
Thought I would get the thread going again...
Its amazing how quickly something goes in the second time you install it. I did the full install in wayyyyy less than an hour. It took a full day the first time.
with all that fuel, the water will make a big difference. put a lot of ice in the tank, too.
just make sure to use straight water, man...... and u know, dont blow it up....
Wow! Double stacked with water injection. I predict it will work awsome!
I'm not doublestacked as of this moment. Its just too much timing; as soon as I can get the timing advance removed from one of the units the SCMT will go back in.
I'm actually very pleased with my install this time around
I have my pump mounted on top of my transfer case skid plate so that its protected but I dont have to listen to it like in my console...
I have the lines hidden on the bottom of my boost tube where you cannot see them; I ran my boost switches and activation switches under the dash where you can't see them but I can adjust the boost settings and activate them by reaching under the dash.
I want this to run a 7.50 1/8 mile at 95 mph. I think it will.
I dunno if it will get to 95 or not, but I think the 7.5 is attainable. It is SOOOOO strong low end right now...but the high quite as great. Maybe the water will help to provide some more boost for top end power. I cannot decide if i want to run the WW fluid or not...
Ill find out tonight! We bumped the schedule up a day...I go tonight at 7 oclock, with some of my friends and my stepdad. Almost time to rock and roll
OH my goodness.....
I best start ordering parts now....
I can see it... my 4x4 launch gets you by 3 or 4 lengths while you're spinning your tires to a carcass and then you come by me about half track at twice the speed and half the egt's
OH my goodness.....
Fat chance! If I would get off my lazy *** and get out in the garage, maybe, but it is not gonna happen. I like the easy life under the A/C too much and I'm too cheap to pay someone else to do it!
