Will 15's not work on the truck as it sits? Im sure someone makes an 8 lug, 15 inch wheel. The only compatibilty issue I can think of would be the enormous diameter of the brake rotors.
The calipers and rotors are too big. It's 16s or bigger.
Hey Bob....
That's the truck I saw out at that ford dealer in fort worth when I went out to the Powerstroke trailer IIRC...
They trailered it in straight from the drags in Houston I think...
the guys were DEAD from beiing up most of the night !
Hey Bob....
Bob, do you have any time schedule of when you plan to get your injection system operational?
So far, the count of water/meth users here is only 3. Counting you, 4. We need to open more people up to this idea (especially those who tow). I suppose I can be blamed for scaring everyone off when I blew my first motor on it
People have to be convinced that it won't damage their engine and that it is worth the effort and expense.
I should have some time to finish mine in a couple of weeks.
Ok guys...need some advice.
I got my 3rd and 4th water stages set up and functioning on my injection kit.
I have the first three stages set up on progressive boost switches (14, 20, 25 lbs) all with .010 nozzles. I have the 4th stage set up on a boost switch ( 25 lbs) in series with a WOT throttle switch (used a nitrous switch from a Nitrous Express Kit), with a .030 orfice nozzle
When the first 3 stages kicks on, the pressure on the gauge stays pretty much constant. When the 4th stage kicks on, however, the pressure drops from about 175 psi down to about 135. Im afraid this is going really reduce the flow. What can be done to help maintain the pressure, besides changing orfice size? An extra pressure regulator?
By using regulators and fiddling with the pressure on each line, you can balance the flow some what. The real problem is that you have too much jet area for the volume/pressure of water. You will have to reduce the jet sizes and make them more even or increase the flow and pressure. possibly another pump. There is a limit to how much the engine can use before it starts putting the fire out! Only Big can tell you that.
in a system w a .050 orifice and 150 psi, u will have problems.
if u have 4 nozzles, and 175psi, each nozzle at .030, u WILL have problems thats the equilalent of a single .170" nozzle!!!!
thats waaay to much water. u need to find 4 very small nozzles. like 4 .010" or 3 .010 and 1 .020. or just put one single nozzle in at .030-.035.
if u have pressure drop, u have waaaay too much flow.
Alright guys, thanks. Ill drop the 4th stage orfice to a .020 (Im really too lazy to order ANOTHER, but ill do it )
The thing is, this isnt going back on the truck until I can save the money and time for the twin turbo. When that happens, theres gonna be ALOT of air passing through that motor, and Im going to need ALOT of water to maximize the performance and cooling from it. On my old system, I had (Im 99% sure because I lost them) two .015 orfices. At full throttle and full boost, with the regulator AS FAR DOWN AS IT WOULD GO, it was sucking up every drop. It probably could have utilized more (but god knows it didnt need it)
w 2 tubas u need a .015 after the first turbo and a .030 after the second. u need 150-200psi above boost press. if u push 120psi boost, u need 270-325psi in ur water system. and the lines MUST have check valves so the second stage press doesnt push all the water in the lines out the first stage nozzle after the pump shuts off.
if i knew where the intercooler was in the system, i could help more
Sorry to jump in so late on the thread, I have a 7.3 and have been looking into the injection setup. Great info in here. I am going to try to order a setup this coming week. I am running a scmt at 110 with 4" straight exhaust. Love the power but looking for some more and the lower egt's would just be icing. As soon as I have it in I will post the results.
Thanks for all the Info.
Nuke
P.S. Also have the tymar intake so should have plenty of air to mix with the water. I'm pumped about this whole water/meth injection idea.
