Diablo Chip Report
Old Jan 5, 2004 | 08:53 PM
  #121
true4.2's Avatar
true4.2
Hmm, you have the EXACT same truck as I do...same code and everything. I can't vouch for superchips but my Diablo is great.
I got some coutips, dipped them in rubbing alcohol, and wiped them on the contacts. (I didn't wipe a ton, just enought to get them damp) Then I got the other end of the coutip and dried them back off after scrubbing a little. Also, make sure you cleaned both sides from top to bottom on the connectors. It took me 3 times before it even started.
Other than that, talk to Ken in the computer chips forums.
Old Jan 5, 2004 | 09:01 PM
  #122
FTE Ken's Avatar
FTE Ken
Originally posted by avintage1956
Greetings,
I reciently tried installing a Superchip on my 2003/4.2/Manual Gearbox/ Code VLW2. After installation, my truck ran rough, and would not go any higher than 3500 rpm. I contacted Superchip, sent the chip back, they in turn sent me a new chip, which does the same thing. I have cleaned the contacts several times, and looked at them thru a magnify glass. Any comments, and does anyone know of anything that can be put on the contacts to make them conduct better?
No, its not the contacts. Probably a bad program.
Old Jan 5, 2004 | 09:12 PM
  #123
true4.2's Avatar
true4.2
viola
Old Jan 6, 2004 | 07:13 AM
  #124
Jimmy Dean's Avatar
Jimmy Dean
or...Ken can come and visit us again, he seems to be on this forum alot more as of late.....maybe that is becasue we have the occasional technical discussion now?
info, I am making a thread in the 97-up 150 on my parking brake sometime later today.
Old Jan 6, 2004 | 09:36 AM
  #125
true4.2's Avatar
true4.2
What's wrong with it?
Old Jan 6, 2004 | 09:41 AM
  #126
Jimmy Dean's Avatar
Jimmy Dean
MY parking brake is sticking, may just be the 20 degee weather, it is not used to the cold, but i have to put a little effort to get it to the first click, and I am not getting full pressure out of my drivers side vent with teh heat, I am getting about 3 or 4 ties the pressure out of the middle vents have not checked the far passenger one, but I do not remember this problem last year, when it only had 20k miles on it.
Old Jan 7, 2004 | 09:21 AM
  #127
true4.2's Avatar
true4.2
Are you thinking of getting it replaced? It's a pretty simple procedure.
Old Jan 7, 2004 | 10:07 AM
  #128
Jimmy Dean's Avatar
Jimmy Dean
I dont know, changing the cable has been recomended. I know now that it is sticking or at least rubbing at ALL times...feels alost like a low tire when I start off or do a turn, and when I let of the gas I can feel the truck draggin alittle, almost like hung brakes, but not serious enough to be the actual brakes, and the brakes are not hot enough after a drive for it to actually be the rear discs draggin up.
Old Jan 8, 2004 | 09:37 AM
  #129
true4.2's Avatar
true4.2
Yea, you need to get it changed or fixed pretty quick. That could cause some pesky long term damage.
Old Jan 8, 2004 | 09:44 AM
  #130
Jimmy Dean's Avatar
Jimmy Dean
It warmed up a bit today, above freezing, did not feel anything wrong, perhaps it was just do to the cold, wil still go on jacks in the next few weeks when I finally have time.
Fords4Jason1967
Feb 28, 2013 09:07 AM
AJHEATING
30
May 13, 2011 10:22 PM
LM14
Aug 28, 2007 07:11 AM
MobeyDick
22
Sep 14, 2006 09:14 PM
Dustin_86
29
May 24, 2005 07:08 PM
