Diablo Chip Report
Old Dec 29, 2003 | 09:16 AM
  #106
true4.2's Avatar
true4.2
Directly after the flowmaster the pipe is turned down towards the ground. Creates a nice rumble sound.
Old Dec 29, 2003 | 09:19 AM
  #107
Busa01's Avatar
Busa01
hm, that's different.
So you can't see the pipe coming out anywhere huh? Hmm, "mystery exhaust". What gave you that idea. You know you have to post pictures now, right Joe?
Tom
Old Dec 29, 2003 | 09:25 AM
  #108
true4.2's Avatar
true4.2
I actually already took about 20 new pics of my truck, but I can't upload them to a new gallery for some reason! Talk about pissed off. I already posted a new thread on it or didn't you read it?
Tom, there are tons of people who have turn downs after the muffler. IMO it gets you better low end power, not high end. I've learned that from experience. My old chevy was like that. First and second could just about smoke anything, but the high end on 3rd sucked harshly. In other words, you don't loose torque with the turn down....at least I think.
Old Dec 29, 2003 | 09:28 AM
  #109
Busa01's Avatar
Busa01
Regarding your pictures, you know you can only upload 15 pictures per folder, so you may have to create another one. Just like I had to create 2 folders for my nitrous pictures. Try that.
Old Dec 29, 2003 | 12:15 PM
  #110
true4.2's Avatar
true4.2
Yea, I tried to create a new album...wait. Is a new folder the same thing as a new album? hummmmmm! You might have answered my question!
Old Dec 29, 2003 | 12:23 PM
  #111
Busa01's Avatar
Busa01
yes, try it.
Old Dec 29, 2003 | 12:26 PM
  #112
true4.2's Avatar
true4.2
If an album is the same thing as a new folder, then that's the problem. I created a new album that was empty and none of my pics would upload. I even deleted 4 of my old pics out of my old gallery and tried to upload them their, but I still got errors.
Old Dec 29, 2003 | 12:28 PM
  #113
FTE Ken's Avatar
FTE Ken
Please post User Gallery issues in the User Gallery forum section and I'll follow up there.
Old Dec 29, 2003 | 12:33 PM
  #114
true4.2's Avatar
true4.2
Ok, I posted it in the user gallery forum. wow, I didn't even know we had a user gallery forum.
Old Jan 1, 2004 | 04:41 PM
  #115
mentalmeltdown's Avatar
mentalmeltdown
I have a Ford F-150, 4.2, 5 speed stick,(agreed Joseph, manual is the only way to go) I ordered a jet chip for it, along with a Airforce one cold air intake and 3" Gibson exhaust system for it. Right now my speed limiter is at 95mph. I hope that with this performance package I will see a significant improvement, along with the removal of the limiter software restrictor. At least until She goes in for a check up.
Mental1
Old Jan 1, 2004 | 09:56 PM
  #116
true4.2's Avatar
true4.2
Hey man!
Welcome To FTE!
I think the Intake and Exhaust will definately boost your power. I'm unsure about JET chips though. I've heard mixed reviews.
Old Jan 2, 2004 | 12:13 AM
  #117
horizonhuskies's Avatar
horizonhuskies
I like mine, but it will not erase or remove or up the rev limiter. You need a custom burned chip for that. JET Chips come out of the box, you plug and play. The easy breathing you are giving your ride will help quite a bit, good luck on your build.
Garrett
Old Jan 2, 2004 | 07:04 PM
  #118
mentalmeltdown
Thanks for the Info. I hope the return policy is good for that chip. Dude, told me it would have no problem over-riding the speed limiter. If it does not, I'm sending it back. Maybe I should not open it at all. I hope he is right, I hate to spend money on things that don't work. . Joseph, I read you are pretty happy with you're diablo, is it?
If any one has any more info. I would really appreciate hearing form you.
Thanks,
Mental1
Old Jan 2, 2004 | 10:51 PM
  #119
true4.2's Avatar
true4.2
I'm definately happy with my Diablo Chip. Here's the scoop on it:
It's $239 for the chip I got which is a Stage 2 Diablo Chip. Keep in mind that with chips, you gain power (primarily) by the octane you use. The higher the octane, the more power the chip can be worth to you. I have 93 octane in my town, and that is the highest. Most places have 91 octane which is still nice. You can order the chip at www.motorhaven.com or call Ken at Motorhaven at 1-770-806-1955. Calling is the best way to go...it's toll free.
Questions you need to know before calling:
-What are your mods if any
-What is the Octane premium in your town
-Is your truck auto or standard
-What is your ECU Code - You can find the code on the passenger side door frame when you open the door. It will have 3 letters and 1 number like VLW2.
-What kind of truck is yours? ie: SCREW, SCAB, so on and so forth
Typical gains are 19 hp/28 lb-ft torque which are really nice gains for a chip on a V6. When you order the chip (if you order it) you will need to specify everything you want. Tell them you want it to take the speed limiter off and give you all the power.
Another good thing about the chip is that it works at all Throttle levels where the JET and Hypertec chips only work at WOT. (wide open throttle)
Oh yea, and installation is pretty easy too...if you take your time.
Any more questions?
Old Jan 5, 2004 | 06:45 PM
  #120
avintage1956's Avatar
avintage1956
Greetings,
I reciently tried installing a Superchip on my 2003/4.2/Manual Gearbox/ Code VLW2. After installation, my truck ran rough, and would not go any higher than 3500 rpm. I contacted Superchip, sent the chip back, they in turn sent me a new chip, which does the same thing. I have cleaned the contacts several times, and looked at them thru a magnify glass. Any comments, and does anyone know of anything that can be put on the contacts to make them conduct better?
