Backpressure - Necessary or not...
Back pressure is NEVER desirable. For high-performance purposes, backpressure in an exhaust system increases engine pumping-losses and decreases available engine power. Maximum mid-to-high RPM power will be always be achieved with the lowest possible backpressure
IMO the whole “engines require backpressure" thing is a myth.
An engine needs the highest flow velocity possible (intake and exhaust) at any given RPM for quick throttle response and torque. The problem stems from the fact that the flows are dramatically different across the RPM range. A small diameter exhaust pipe might give you maximum unimpeded gas velocity at 2000 RPM. This would give you great off-idle acceleration, but after 2000 RPM the exhaust gas volume begins to exceed the amount that can flow unimpeded through the pipe and you have BACK PRESSURE. To overcome the limitations of the undersized exhaust pipe your engine needs to literally pump the exhaust out the end of the pipe. This seriously inhibits peak performance for any number of reasons.
If we install a larger diameter exhaust pipe, we now have enough pipe volume to flow the unimpeded gas velocity at mid-to-high RPM without BACK PRESSURE. However, at lower RPM’s the gas volume is not large enough to maintain the flow velocity in the larger pipe and low-end throttle response suffers.
exhaust systems are a compromise, you can maximize for low-range and mid-range performance or mid-range and high-end performance but you cannot simultaneously maximize for all three because of the differences in flow volume and velocity.
A year or so back, I got into a LONG thread in the exhaust forum. I'll see if I can find it and post a link.
Gas flow dynamics are complicated, but the key to it is exhaust gas velosity and the timing of very high velocity energy pulses that travel up and down (i.e. with the flow and against the flow) of exhaust gases.
These pulses can assist with the scavenging of spent gases.
Anyways, I'll see if I can find the old thread.
edit to add:
here's the thread.........
https://www.ford-trucks.com/forums/s...2Bbackpressure
Reducing the backpressure lets your engine flow higher volumes of air during each intake and exhaust stroke. Earlier cars, truck, and motorcycles with carburetion could not automatically adjust to the increased airflow and ran lean. Without carburetor adjustments to deliver more fuel, the result was possible burnt valves. Today’s engine computers use sensors to actually measure the airflow and automatically increase/decrease the fuel injection to maintain the correct air to fuel mixture.
1. The intake valve opens and the piston travels downward creating a vacuum to pull in fresh air/fuel.
2. Intake valve closes and the piston begins it’s upward compression stroke squeezing the full volume of fuel/air mixture into the combustion chamber.
3. Just before top-dead-center the sparkplug ignites the mixture and you have an explosion which forces the piston back down.
4. The exhaust valve opens and the piston begins it’s upward travel as the spent gasses dump into the exhaust system
The whole issue of BP comes into play (mainly) when speaking about the exhaust stroke. For it is here that the supersonic pulses, traveling in the exhaust gases, can (and will) affect the expulsion of spent gases. These pulses of high and low energy can either help suck the gases out of the cylinder or help to keep them in.
There is also consideration to be given to that brief period of time where both intake and exhaust valves are open (valve overlap) The more valve overlap, the more impact exhaust tuning and intake tuning can affect efficiency.
It is somewhat easier to think about the impact exhaust pulses have when thinking about a two stroke engine. Lacking valves (not all do) these engines rely heavily on the tuning of the exhaust for their operation. Two stroke exhaust "expansion chambers" exist to create energy pulses at various fixed rpm ranges (fixed, but variable based on size and location of expansion chamber). They function by allowing the exhaust gases to expand. This send a pulse back upstream. (nozzle effect).
This is what accounts for the phenomenon known as getting "on the pipe". you hit that rpm range where the engine works very efficiently and WOW all of a sudden a nice boost in power. It is also noticeable on 4 stroke (in particular in-line 4) bikes. They too have an rpm range where breathing becomes "more efficient". When breathing becomes more efficient, power increases.
Make any sense ????
