Final drive ratio
Old Mar 18, 2024 | 04:50 PM
  #106
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by OBS460
This isn't a genset peak torque also means peak fuel consumption. You are making plenty of torque at 1700rpm to maintain 70mph. Why would I want to turn 2100rpm when I dont even need as much torque as the engine is producing at 1800rpm? No vehicle produced is designed to be at peak torque cruising at 70mph.
With 4.30 gears you must be ready at any given moment for peak torque even if not needed.
Old Mar 18, 2024 | 05:42 PM
  #107
twobelugas's Avatar
twobelugas
Originally Posted by 00t444e
4.30 gears with 33" tires in 10th gear is about 2100 RPM, great cruising RPM for a gas engine, still well below the torque peak. The 3.73s or 3.55s would put it even further away from it so no advantage there.
I get 18 mpg, sometimes a little more, cruising at 70mph with the motor spinning at 1600 RPM. There is PLENTY of torque to maintaining speed on flat and even slightly uphill situations even with a little headwind. Always spinning at 2100 RPM is just wasteful on the non towing trips. If your trucks needs 2100 RPM just to maintain 70mph on the freeway when not towing, you need to get it checked out because something has gone very wrong.
Now why does someone buying a 3/4 ton care about MPG when not towing? because I use it for work, and I don't get paid for miles that don't carry cargo, but I still have to get there to get it. That's the same reason why professionals sometimes stick to the smallest tires possible, every penny counts in this day and age trying to make a living. My work has gotten tough enough in my region that I am gradually shifting away from what I do now and pretty soon may not need a 3/4 ton anymore. Y'all balling with your 35s just to commute can do that but you are not getting 18-19mpg at 70mph running 35s and 4.30, but if that's how you choose to spend your hard earned money, who am I to say don't do it.
If someone is towing 10k+ 100% of the time, sure, go ahead and get 4.30, I will be the first one that recommends you to get the lowest gearing you can. But I highly doubt anyone here is towing that much every mile the truck is in motion.
Old Mar 18, 2024 | 05:43 PM
  #108
bigwin56f100's Avatar
bigwin56f100
here here! That's what I was trying to say. My Jeep Cherokee is 1600 rpm's at 70mph and it too has a tow package. Obviously not as much capacity as the f250
Old Mar 18, 2024 | 05:52 PM
  #109
twobelugas's Avatar
twobelugas
It boggles the mind that Ford spends all this time and effort to produce a pushrod motor that generates something like 80% of its max torque at 1500 rpm, yet some buyers insist to run it at at least 2100 rpm at all times for...reasons.
Old Mar 18, 2024 | 05:56 PM
  #110
GAZZILLA's Avatar
GAZZILLA
For me I can never have too much money, a girl too pretty, a car/motorcycle/truck too fast/powerful, so on and so forth. I want more power, not less. Marginally better gas mileage isn’t something I’m consider about.
Old Mar 18, 2024 | 06:03 PM
  #111
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by GAZZILLA
For me I can never have too much money, a girl too pretty, a car/motorcycle/truck too fast/powerful, so on and so forth. I want more power, not less. Fractionally better gas mileage isn’t something I’m consider about.
Less power and more MPG is the new thing for 8,000lb trucks these days. Geeze,..get with it! They can't afford an extra $4 per fillup after buying their ultimate platinum limited diamond edition
Old Mar 18, 2024 | 06:12 PM
  #112
twobelugas's Avatar
twobelugas
people who run businesses care about operating cost. It may be an alien concept to some, but believe it or not, some buyers buy SDs not as a commuter or weekend toy tower, but to make a living with.
Old Mar 18, 2024 | 06:14 PM
  #113
twobelugas's Avatar
twobelugas
….yet you are driving around in a gas truck that is significantly slower and less powerful than a power stroke. so you have just enough extra scratch to blow on gasoline, but not enough to buy yourself a diesel? That’s a strange financial success niche you fit in.
Old Mar 18, 2024 | 06:25 PM
  #114
Rwhjr's Avatar
Rwhjr
he’s going to parrot some stuff about how the 7.3 is the second coming of Jesus but you’re right. The real reason he doesn’t have a diesel is the cost. Plus he tows a 2500lb trailer and doesn’t need one. He doesn’t even need a super duty at all. He should really be in a 150 but he (the one who preaches to diesel guys about not needing diesel) doesn’t even need a super duty at all.
he’s full of this sort of backwards crap when you try to understand his logic.
Old Mar 18, 2024 | 06:29 PM
  #115
twobelugas's Avatar
twobelugas
now I’m most curious how he will explain his aversion to diesels after his Marvin Gaye “Ain't No Mountain High Enough” style speech about power and girls.
You make a valid point, it was simply projection when he was telling people like me who actually use trucks for a living to buy a half ton if we don’t get 4.30 gears.
Old Mar 18, 2024 | 06:37 PM
  #116
6.8L_V8_DRW's Avatar
6.8L_V8_DRW
What a worthless thread.
Old Mar 18, 2024 | 06:53 PM
  #117
twobelugas's Avatar
twobelugas
Then your input is even less than worthless.
Old Mar 18, 2024 | 07:12 PM
  #118
00t444e's Avatar
00t444e
That is false, every diesel truck almost is like that.
Old Mar 18, 2024 | 07:39 PM
  #119
00t444e's Avatar
00t444e
Your not averaging 18-19 MPG hand calculated on the highway, our 2wd single cab with 3.55s didn't even get that, the digital readout doesn't mean anything. Running at more RPM along with the torque advantage of lower gears means it takes less throttle input to go the same speed which can get you better fuel mileage in some cases. More RPM= more fuel used is only true if the throttle input is the same for both, which it often isn't, what is more important is where the engine makes it's peak torque.
Old Mar 18, 2024 | 07:42 PM
  #120
00t444e's Avatar
00t444e
Another false number pulled out of nowhere. Remember just because you don't own a 4.30 geared truck doesn't mean they aren't better.
